did my alternator just quit?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ltk, Aug 23, 2015.
  1. Aug 26, 2015 at 12:23 PM
    #41
    Ltk
    Ltk [OP] Well-Known Member
    my excuses are heavy in here i guess lol.
    i had about 30 minutes to get them both out before work, will take them tomorrow before work to get them both stress tested and pick up new ones. hoping to have it ready by the weekend if i find another hour or so!
    also sheared 2 bolts on the front factory skid plate.. will be picking those up too
    can anyone tell me how they have their batteries secured down? i can pick the battery up an inch with this piece of junk bolted down all the way ImageUploadedByTapatalk1440616972.073109.jpg
  2. Aug 26, 2015 at 12:37 PM
    #42
    Indy
    Indy Master of all I survey.
    Battery tie downs for factory vehicles just keep it in place. Movement is fine. If you're going baja, they won't do the job.
  3. Aug 26, 2015 at 12:47 PM
    #43
    Ltk
    yea this one has seen better days. this is my hunting truck/offroad truck so it does get quite a bit of bouncing around and treated pretty rough, so i need something more re-enforced, i have some industrial sized thick zip-ties, but id rather find something a little more secure
  4. Aug 26, 2015 at 12:56 PM
    #44
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
  5. Aug 26, 2015 at 1:02 PM
    #45
    Ltk
    thanks for that motivation
  6. Aug 27, 2015 at 12:26 PM
    #46
    Ltk
    little update: had a minute today to run to AutoZone.
    alternator failed the test and battery is just drained pretty good. picked up a new alternator but didnt have time to install today. so the alternator was the problem, thanks for the tips guys!
    going to invest in a good battery charger as soon as money allows.
    would it be okay right now to jump start the truck and let the alt charge the battery up?
  7. Aug 27, 2015 at 12:31 PM
    #47
    Kneeboarder1025
    Kneeboarder1025 member-in-training
    Walt
    Broken Arrow, OK
    '03 Forester
    Glad you got a solution! and yes, once the new alternator is in, you can let it charge the battery.
  8. Aug 27, 2015 at 12:32 PM
    #48
    Ltk
    okay great. thatll save me from buying a charger just yet. thank you
  9. Aug 28, 2015 at 12:52 PM
    #49
    Ltk
    well i got the new alternator in and jump started the truck. let it run about 15 minutes, then noticed its really rough idling.
    could the failed alternator have caused something else to go bad?
    it idles bad and shakes, when i tap the throttle it shakes a little worse before smoothing out. could this be related at all?
  10. Aug 28, 2015 at 1:18 PM
    #50
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    no, check for loose vacuum hoses and all connections in engine bay
  11. Aug 28, 2015 at 1:22 PM
    #51
    Ltk
    okay i will do that
    i read something on toyotanation that says that the computer has to relearn the idle if the batteries are disconnected for a long period of time? ive really never heard this before
    when i first started it the belts squealed really bad then i let it idle for about 15 minutes
  12. Aug 28, 2015 at 9:41 PM
    #52
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    If you go to a place like interstate batteries they will have a multitude of diff sized batteries. They can hook you up with a larger/taller battery to fix your loose/floppy battery situation.
  13. Aug 28, 2015 at 10:22 PM
    #53
    Ltk
    dont really want to buy a new battery, that doesnt really solve the issue lol
    i grabbed 2 industrial zip-ties and put them all the way around the battery and through the holes on the inner fender well for the battery tray to sit on. its really secure now, can rock the truck from the battery so it shouldnt go anywhere now
  14. Aug 28, 2015 at 10:39 PM
    #54
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Yeah the motor shakes bad when you connect a low battery back up and cold motor. It's normal. Once motor is warm and you have enough battery voltage the ecu will start adjusting fuel trims.
  15. Aug 28, 2015 at 11:04 PM
    #55
    Ltk
    thank you! i shut it off because it was worrying me. ill start it up and get it fully warm by driving around my peoperty, im hoping this solves my issues
  16. Aug 28, 2015 at 11:19 PM
    #56
    TrdSurgie
    TrdSurgie revised
    Oahu
    Nice
    Ltk[OP] likes this.
  17. Aug 29, 2015 at 10:50 AM
    #57
    bry838
    oregon
    U asked/wanted to know how we get our batteries bolted down tight.....
    That battery is too short....
  18. Aug 29, 2015 at 1:46 PM
    #58
    Ltk
    well i fixed mine cheaper than buying a new one. thats a win in my book
