Did my Parking light to Turn signal / Turn signal to Fog light mod today
Discussion in '1st Gen. Tacomas (1995-2004)' started by Desiel, Sep 16, 2010.
  1. Sep 16, 2010 at 4:52 PM
    Desiel
    Desiel [OP] Well-Known Member
    Kyle
    Morristown, TN
    01 Tacoma XtraCab SR5 4x4
    So far: Tint American Racing Wheels with 265/75-15
    Did my Parking light to Turn signal / Turn signal to Fog light mod today. It was much easier than some of the forums I have read...
    Here's how I did it:
    1. remove parking light & take the shroud hiding the wires off all the way to the main shroud you will find 2 green wires
    2. cut the two green wires
    3. swap the two green wires and solder them back together
    4. you are finished no clean it all up so it will look good and put your parking light back in
    5. I haven't decided on just getting some clear 1156 bulbs or if I wanna try and find something else
    Edit: Instead of using the stock 168 bulb in the parking/turn signal I used a orange 194NA
  2. Sep 16, 2010 at 5:02 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    easy peezy
  3. Sep 16, 2010 at 5:09 PM
    TanSR5x4
    TanSR5x4 Hold my beer and watch this
    William
    Houston TX
    00 Tacoma SR5 4x4
    Deckplate mod, black KC slimlight fogs, hurculined bed, NRA sticker mod, painted rear chrome bumper black, black fender flares and front grill surround, HIDs, All-pro rear leafs and UCAs, Eibach coilovers, billys all around, flat black pro comps, 31x10.5x15 BFG KM2s
    yeah thats how i did it but my blinkers are blinkin way too fast
    and they are kinda weak up front like just not that bright
  4. Sep 16, 2010 at 5:13 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    i think there is a led resistor or something that needs to be put in to stop it from hyperblinkin
  5. Sep 16, 2010 at 5:19 PM
    Desiel
    Kyle
    Morristown, TN
    Ya mine do that too but I'm gonna check into a resistor or equalizer. I kinda like the hyper blink.
  6. Sep 16, 2010 at 5:20 PM
    747 function > form
    1st Gen.
    There's a thread around here about that...I can't find it right now. All I did was change the bulbs in my corner lamps to a different size = normal blink rate and brighter (standard bulbs available at Advance, etc.; nothing fancy). I recommend a search in the 1st Gen section. Good luck!
  7. Sep 16, 2010 at 6:47 PM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    to fix the fast blinking you can pick up an l.e.d resistor kit from Advanced Auto for like $12 bucks works like a charm.
  8. Sep 16, 2010 at 7:46 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
  9. Sep 16, 2010 at 7:51 PM
    huntark03
    huntark03 I'd rather be hunting!
    Maumelle, AR
    2005 Limited Tundra DC 4X4
    Spidertrax Wheel Spacers aFe Pro Dry Drop in Air Filter Weathertech Liners Bilstein 5100s w/ OME 885 coils and ToyTec 1.5" AALs Light Racing UCAs
    Sub'd on phone
  10. Sep 16, 2010 at 7:52 PM
    Desiel
    Kyle
    Morristown, TN
    I kinda like the hyper blink and if you do it the way I did you don't have to cut on your light housing. I did order the lil in line resistors though
  11. Sep 16, 2010 at 7:57 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    you like the hyperblink? hmm haha well in that case your way is perfect
  12. Sep 16, 2010 at 8:03 PM
    Desiel
    Kyle
    Morristown, TN
    or you can do it my way and put the lil resistors in-line and still not have hyper blink and always be able to switch it back.... just sayin
  13. Sep 16, 2010 at 8:19 PM
    tacomaforlife
    Robbie
    AIKEN, SC
    it all depends i have l.e.d.'s in my corner lights and they are really bright and all you have to do is get the resistor kit and install it no cutting your housing or anything like that and your housing seals up like it normally would with out and moisture getting in.
  14. Sep 16, 2010 at 10:21 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    What did you use? Do you have pics of the LEDs and resistor kit or links to where I can see them?
  15. Sep 17, 2010 at 6:03 AM
    tacomaforlife
    Robbie
    AIKEN, SC
    i just picked up some amber l.e.d.'s from advanced auto and also they have an l.e.d resistor kit that you can get there as well and it installs really quick. I Also have clear corners that may make the light more visible.
  16. Sep 17, 2010 at 6:29 AM
    SunDevilTacoma
    SunDevilTacoma Well-Known Member
    Doug
    Gilbert, AZ
    04 Wht Double Cab PreRunner
    Turn signal relocation, built in fog light conversion, 4" deck plate
    That's how I did mine. Plus you keep your corner/parking lights that way so you don't have to worry about getting ticketed for not having them - that's if they're required where you live.
    Got pics?
  17. Sep 17, 2010 at 6:33 AM
    Desiel
    Kyle
    Morristown, TN
    What are some bright bulbs for the fogs there's a 3057 bulb in there now. Are there any brighter bulb that will go in that socket with out over heating?
  18. Sep 17, 2010 at 7:52 PM
    ScootsOFP
    ScootsOFP Well-Known Member
    Scoot
    Wisconsin
    03 PreRunner SR5/TRD
    deckplate, white LED gauges, fog light mod (Beau02 write up), Scion t1814 head unit
    I just did this today using the Beau02 write up. No hyper blinking and I love it. Great mod.
  19. Sep 17, 2010 at 8:06 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Do you have a link to that write-up?
  20. Sep 17, 2010 at 8:37 PM
    ScootsOFP
    Scoot
    Wisconsin
