Did my S/C die?
Discussion in '1st Gen. Tacomas (1995-2004)' started by trmarshall1, Apr 24, 2013.
  1. Apr 24, 2013 at 5:02 PM
    trmarshall1
    trmarshall1 [OP] The Least Interesting Man In The World
    Tim
    San Jose, CA
    02 Tacoma 4x4 TRD Supercharged
    4" Pro-Comp Lift, TRD cat back exhaust, grey wire mod, clutch pedal linear spring mod
    So last night, I was driving home on the freeway about 68 mph with the cruise on. It was probably running around 2800 rpm. Out of nowhere, the rpm spiked to close to 5500 before going back to a normal rpm range. I noticed that after that, almost immediately under acceleration, it seemed to shudder. I checked the boost gauge, and it wouldn't go past 10 on the vacuum side. I can no longer hear the whine of the S/C either. I was able to drive the truck the approximately
    4 miles home after the incident, and it started fine this morning, though I didn't drive it. I did however leave it in neutral and gave it a bit of gas, and the same thing, it won't boost or go past about 2400 rpm without shuddering like it air starved. Any ideas on what this could be and what it might cost to repair? I have the original intake manifold I got from the second owner (I'm the third), so how difficult of a job is it to swap the S/C out?
  2. Apr 24, 2013 at 7:08 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    start easy, is the belt on?
  3. Apr 24, 2013 at 7:40 PM
    DAMOS
    DAMOS Well-Known Member
    Eugene, Oregon
    04 Dub Cab TRD 4x4
    TRD sc Magna flow cat back
    Its not a bad job. switching the alternator belt is the worse part. make sure you get the hoses hooked up right. Install instructions are handy. Pvc valve hose is the only hidden one though. Ive done it a few times and I am fat and lazy
    Take some good pics before you dig in
  4. Apr 24, 2013 at 8:40 PM
    trmarshall1
    Tim
    San Jose, CA
    I'll have to check the belt when I get home. So my primary concern is that I didn't damage the engine by running it like I did. Will I need new parts like a new intake manifold gasket?
  5. Apr 25, 2013 at 5:22 AM
    DAMOS
    Eugene, Oregon
    04 Dub Cab TRD 4x4
    if you are switching out your sc you will need an alternator belt. You can reuse your intake manifold gasket just make sure it's clean. maybe buy a new one when you put the sc back on
  6. Apr 25, 2013 at 6:44 AM
    DAMOS
    Eugene, Oregon
    04 Dub Cab TRD 4x4
    You will need to make sure you have the correct bolts to re install the stock intake. I think its only 2 different bolts you need for reinstall.
    take the sc belt off and spin the sc by hand
  7. Apr 25, 2013 at 6:47 AM
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    Keyser West Virginia
    2010 white double cab
    8 inch alcan custom leaf packs, ome 885's powdercoated white, bilstein 5100's all the way around with 12 inch travel on the rear, Light Racing Upper Control Arms, Sway bar removed, 17x9 kmc strike. 35x12.50 nitto Trail Grapplers. Satoshi Grill made by (homertaco), Black Headlight housings,retrofits, Tinted Tailights, color matched grill, Bought a TRD sport hood,elite off road front plate bumper,elite off road sliders, 13% tint on the front windows, 5% on top of the facotry rear windows and back glass, 5% tint stip across the windshield, Lo Pro Truxedo tonneu cover, Herculiner bed liner, Weather Tech Window Visors, Exhaust- Flowmaster Super 44 dumped above rear axle, Maglight Mount on side of drivers seat, Scangauge II, Mossy Oak Camo Seat Covers, Weather Tech Floor mats, Spatter painted A-Pillars, Spatter painted headunit trim and shifter trim, Headunit= Pioneer 4300 double din touch screen, Speakers- Precision Power 3 way component stage, Precision Power 8 i
    check everything first. make sure belt is on, make sure all pulleys are fine and check for vaccum leaks
  8. Apr 25, 2013 at 6:55 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Deck Plate Mod; Grey Wire Mod; 1.5" AAL; 1.75" Lift Shackles; Bilstein 5100's; Eiback Coils; LR UCA; Front Diff Drop; Tundra Brake Upgrade; Wheels Offroad Brake Lines; Rear Diff Breather Mod
    I think the RMP spike was the belt comming off.
  9. Apr 25, 2013 at 6:58 AM
    TacoCat
    TacoCat Look away, I'm hideous!
    Johnny-5
    Chantilly, VA
    Silver 2010 OR
    that was my first thought. those belts are under a lot of stress. theyre recommended to change every 10k right?
  10. Apr 25, 2013 at 7:48 AM
    DAMOS
    Eugene, Oregon
    04 Dub Cab TRD 4x4
    coupler could have failed in the snout
  11. Apr 30, 2013 at 3:08 PM
    TacoCat
    Johnny-5
    Chantilly, VA
    Silver 2010 OR
    Any update OP?
