Did my transfer case just explode? Please help!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jkish17, Mar 11, 2021.
  1. Mar 11, 2021 at 8:23 PM
    jkish17
    jkish17 [OP] Well-Known Member
    Roseville, CA
    2018 DCLB TRD OR
    -Dobinson’s IMS shocks on C59-354 coils -Dobinson’s rear shocks -Dobinson’s L59-111-R heavy leafs -Wheeler’ off road super bumpstops -Wheeler’s off road U-bolt flip -JBA Upper control arms. -35x12.5r17 Yoko Geo MT’s -17x7.5 4Runner spare steel wheels (Part #42611-35430) -Trailgear 1.5 spacers -C4 fabrication rock sliders -Relentless Fabrication High Clearance Rear Bumper, no swingout. -CBI T3 front plate bumper, no hoop/bullbar. -Ironman 4x4 12,000lb synthetic winch -Victory 4x4 roof rack -China camper from Alibaba -CVC tuned -ExtremeLED lightbars in the roof rack and front bumper. -Baja Squadron's in the rear bumper -MESO customs stuff everywhere -Dobinson’s Zenith air compressor mounted under the hood -Homemade S-pod relay box -Entire sound system replaced and sound deadening added
    Hello everyone,
    I just regeared my tuck last week to 5.29's last week and finished the break in period for the rear gears a few days ago.
    Tonight I was going out to grab dinner and figured it would probably be a good idea to put a few miles at a a time on the front gears to help break them in also (I've already been doing this a couple of miles here and there this week.)
    Tonight I did this and my truck came to a screeching halt and scared the crap out of me. I was at a stop light engaged 4wd and started driving when the light turned green. Luckily no one was behind me and I was in a light traffic area. I was not going fast, maybe 30 mph, by the time the truck made a horrific sound and came to a stop.
    I was stuck couldn't move, the engine was still running but I was dead in the water. I put my hazards on and tried to gain my senses back and figure out what the hell just happened. I was able to eventually able to get it out of 4wd (but with a loud bang) by giving it a little gas. I drove to the parking lot next to me and it seemed fine in 2wd. I tried reengaging 4wd, same situation as before, truck was stuck in place and hard to disengage 4wd.
    I drove home in 2wd (obviously) and everything else seems fine so far. Shifts fine, drives fine. I looked underneath and there is oil splatter every where all over underneath past the transfer case.
    I have no idea what to do now. I'm going to call the shop I did my regear at tomorrrow because that's my first most likely culprit. The thing I'm now worried about is obviously the front diff, but also the transfer case, and possibly transmission? I can't tell where exactly the transfer case is leaking from in the dark or if it's a steady leak. I'll climb under there tomorrow to see if it's still leaking and from where.
    What all do you guys think I need to worry about at this point. For all I know I could have just grenaded the front diff, possibly the transfer case, and maybe even hurt the transmission for all I know. I feel sick right now thinking the potential cost and time to fix these.
    Any input will be appreciated. Thanks.
  2. Mar 11, 2021 at 8:26 PM
    Bishop84
    Bishop84 Well-Known Member
    Shit luck, sorry to hear. Did you supply the parts or did they? Hopefully they fix it and don't put the blame on you.
    Best wishes.
    Chew, xxTacocaTxx and Grossomotto like this.
  3. Mar 11, 2021 at 8:29 PM
    jkish17
    Roseville, CA
    2018 DCLB TRD OR
    They supplied parts. But at this point I’m not just worried about the diff, I’m worried about my transfer case too
  4. Mar 11, 2021 at 8:30 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    the loud bangs almost certainly are gears. Recently bombed my rear and needed to move it out of the way. Each bang is a tooth snapping off. The fluid is interesting. Are you missing any bolts for the fill anywhere? Also does it smell like gear oil? You will know as that stuff is potent.
    frenchee, SR-71A and Gunshot-6A like this.
  5. Mar 11, 2021 at 8:31 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Did you feel around on top of the T-case? (obviously be careful, there might be a cracked case or hole.)
    Gunshot-6A and shakerhood like this.
  6. Mar 11, 2021 at 8:31 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Yeah looks like a blown case to me. Guessing of course. But in terms of the shop fixing it, I hope they do the right thing. Although I wouldn't be surprised if they try to blame you
  7. Mar 11, 2021 at 8:33 PM
    jkish17
    Roseville, CA
    2018 DCLB TRD OR
    I have not felt around the case it’s dark and I didn’t wanna get covered in oil. I will check tomorrow
    TXpro4X4 and ColoradoTJ like this.
  8. Mar 11, 2021 at 8:36 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Hmmn... Shortly after I got my gears replaced, I had fluid under my truck just like you do. I never actuated 4WD though, so it was easy to determine the leak was from a bad transfer case seal. I'm no expert, but I wonder if you had that leak before hearing the bang. Just something to consider, anyone can feel free to correct me if I'm pushing Op in the wrong direction though.
    Bratwurzt and Gunshot-6A like this.
  9. Mar 11, 2021 at 8:37 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Give them the opportunity to fix it...when they blame you file a claim with their liability carrier.
    Chew and Gunshot-6A like this.
  10. Mar 11, 2021 at 8:39 PM
    GOLIVER0131
    GOLIVER0131 TrdMo
    Socal
    '17 Wht Trd OR DCLB(TrdMo)
    TrdPro grille, blackout badges. Pretty much stock.
    Daaang. Reminds me of when I was 19 I was a jeeper and came down hard on my left front axle. Bent my front spring and front drive shaft. The impact actually cracked the case of my transfer case. Being 19 and working for my dad it took me 6 months to save enough money to buy a new case half, replace the front shaft, and leaf spring. Then another 3 months to transfer the internals. I actually rebuilt it 2 times as I forgot a couple c clips in there, lol. What an experience!
    The good news is ur prob not 19 and can claim it on ur insur if it naded and the gear shop doesn't take responsibility.
  11. Mar 11, 2021 at 8:39 PM
    jkish17
    Roseville, CA
    2018 DCLB TRD OR
    I can positively guarantee it was there because of this event. I’ve been crawling all around underneath my truck putting on my lift this past month. I would have definitely seen this much oil, and it’s fresh as can be, like it just got there.
  12. Mar 11, 2021 at 8:41 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    sounds like maybe mis-matched front/rear diff ratios putting a bind in the drivetrain
  13. Mar 11, 2021 at 8:43 PM
    therealprotaco
    therealprotaco Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    Nitro gears? They recently had a batch of 5.29s that were accidentally sent out as normal gears but were actually reverse cut. My local shop had 2 sets in their inventory. May or may not cause the T case issue. Could also have had 5.29 installed in one and 4.88 installed in the other. Good luck!
  14. Mar 11, 2021 at 8:44 PM
    jkish17
    Roseville, CA
    2018 DCLB TRD OR
    Well I’ve been driving it a couple miles here and there in 4wd trying to break it in. It’s been fine up until tonight. I feel like mismatched gears would have had problems right away.
    xxTacocaTxx and ClassyTacos like this.
  15. Mar 11, 2021 at 8:45 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Since you've been running it in 4wd earlier in the week, that doesn't sound like a mismatch to me. Sounds to me like something broke in the front diff.
    henryp, wilcam47, Chew and 2 others like this.
  16. Mar 11, 2021 at 8:45 PM
    therealprotaco
    Gilbert, AZ
    Well that changes everything. Definitely not your typical mismatched gear issue.
  17. Mar 11, 2021 at 8:45 PM
    jkish17
    Roseville, CA
    2018 DCLB TRD OR
    Also quick question, if everything is fine in 2wd do you guys think my transfer case is okay and it’s just the gears in the diff?
  18. Mar 11, 2021 at 8:46 PM
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    It's good that you were inspecting. Unknown variables like that make finding the actual cause, or who is at fault, difficult.
    Hopefully the place that installed them will make the repairs for free - assuming you still trust them after this.
    I find it interesting that the issue didn't exist until later on. That's a good data point for others who know more than I to help with.
    xxTacocaTxx likes this.
  19. Mar 11, 2021 at 8:46 PM
    ColoradoTJ
    Colorado
    I agree.
    Total bummer though.
  20. Mar 11, 2021 at 8:47 PM
    0xDEADBEEF
    Could be as simple as a forgotten bolt backing out. Sucks.
    Gunshot-6A and tonered like this.
