Did my transfer case just explode? Please help!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jkish17, Mar 11, 2021.
  1. Mar 12, 2021 at 2:01 PM
    #181
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Ah!
    There's a lot of things that should be in the Subaru lineup there were in the past. If there was as WRX Hatch in 2017 . . .
    pinochle and averagejp[QUOTED] like this.
  2. Mar 12, 2021 at 4:53 PM
    #182
    wolf2600
    wolf2600 Well-Known Member
    San Jose, CA
    2021 TRD-OR 6MT-SOLD
    Coyoza Tuned
    The warning on the Q-Tip box also says "do not use in ears". It's all about limiting liability.
  3. Mar 12, 2021 at 4:55 PM
    #183
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    Don’t forget the tags on pillows that warn people not to remove such tag... them pillow police are watching :D
    cosmicfires likes this.
  4. Mar 12, 2021 at 5:19 PM
    #184
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    Same gimme a new one. The hatch wrx was great too.
  5. Mar 12, 2021 at 5:39 PM
    #185
    xxTacocaTxx
    xxTacocaTxx Well Unknown Member
    Best Slope CO
    2017 TRD OR DCLB 4x4 OMGWTFLOLBBQ
    RCI skid plates Mobtown sliders Lots of patches and MESO stuff
    That only applies to distributors and retailers. You're fine to remove your pillow and mattress tags as an end user.
    https://money.howstuffworks.com/removed-mattress-tag.htm
  6. Mar 12, 2021 at 6:30 PM
    #186
    RatDaddy
    RatDaddy Well-Known Member
    Roy
    2017 Tacoma TRD O/R Premium pkg
    None
    16th street mall and downtown. know it to well. He was flying. lol
    sbb[QUOTED] likes this.
  7. Mar 12, 2021 at 6:42 PM
    #187
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Normally I would not pollute a thread, but instead of the popcorn placeholder I posted this pic, as it's Friday.
    To some of the Armchair Engineers in here ....
    As an Engineer that worked and designed/redesigned things for many Automotive companies over the years (since the 80's) and as a member of SAE...
    let me clear up some of the misinformation on TW and in this thread.
    Without writing a novel .... I will say Google it and come back when you can understand it... but will summarize it by saying...
    Our trucks are NOT 4 wheel drive (by the strictest definition). And how I think some people are interpreting it...
    They are "Part time 4wd"
    The front and read differentials are "open" which means not locked together.
    The transfer case is "locked" otherwise it would be called "All Wheel Drive " (which is also a very misleading name).
    If you turn off traction control, ATRAC etc.
    And get stuck in the mud.... only two wheels will turn.... 1 front and 1 back.... (because of open differentials).
    "Real" 4WD as most people interpret it... all 4 wheels would be turning....
    With a part time 4wd vehicle like the Tacoma,
    I could put 1" smaller diameter tires on one side (but not front vs back)
    and engage and disengage 4wd all day on a paved road, (with drag slicks for traction) going straight,
    and not apply any load on the drive-train whatsoever...
    Reason why turning with a locked transfer case becomes a issue in high traction areas is the turning radius between the front and the rear tires,
    drive across some mud and snow and take a turn, you will see the front and rear wheels do not follow the same path.
    So the # of rotations won't match between the front and the back, and the transfer case is gears are locked together = stress.
    So to sum it up,
    Any part time 4wd vehicle you can drive straight for longer than you can find a straight road without causing ANY stress to the drivetrain.
    Any TRUE 4wd (locked front and rear differentials), assuming same size tires, tire pressure etc can ALSO drive in a straight line without causing stress to the driveline, but ANY turns will stress the axles and differentials more than the transfer case.
    Sorry to the people that are saying otherwise,
    or misunderstanding the "CYA" in parts of the manual, (CYA= Cover Your Ass 'cause people are stupid)
    YOU ARE WRONG
    without a shadow of a doubt,
    please stop giving very wrong information out to people.
    My bet for the cause was in @tonered 's post further up.
  8. Mar 12, 2021 at 6:51 PM
    #188
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    :gossip: from post #69 (a favorite number......)
    ktbell444 and Skydvrr like this.
  9. Mar 12, 2021 at 6:58 PM
    #189
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    Seems sus. You
    Prob work for differential companies.
    xxTacocaTxx likes this.
  10. Mar 12, 2021 at 7:44 PM
    #190
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    If it was the front diff, OP would have had to miss some serious noise for the ring gear bolts to get loose and break the gears.
    ....It probably was, but it'd be cooler if it was a mismatched ratio blew up the TC.
    In other news, one time my friend blew up their transmission activating 4WD on pavement. :stirthepot:
    whatstcp and theesotericone like this.
  11. Mar 12, 2021 at 7:46 PM
    #191
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    I'm calling bullshit.
    You don't have any friends. :crapstorm:
  12. Mar 12, 2021 at 7:49 PM
    #192
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    I would say it's well broken in, and the best thing now maybe to make that call...
  13. Mar 12, 2021 at 7:49 PM
    #193
    tetten
    Andy
    Socal
    I'm not the one that got into a fist fight around a camp fire. :rofl:
  14. Mar 12, 2021 at 7:50 PM
    #194
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Yeaahhhh....but how do u know it wasn't the lift??
    tonered likes this.
  15. Mar 12, 2021 at 7:50 PM
    #195
    theesotericone
    Bishop CA
    I never said I had any friends either. Especially that guy. lol
    Taco-Obsessed and tetten[QUOTED] like this.
  16. Mar 12, 2021 at 8:26 PM
    #196
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    At this point I could not even begin to say with any certainty what caused this failure.
    I agreed that my guess was in agreement with another person's guess based on seeing other failure outside of designed operating parameters.
    Lol
    For all I/we know at this point....
    He could have run over a wooden leg transvestite
    whose leg got wrapped around the driveshaft and locked up the truck,
    their breast implant hit the transfer case,
    and blew up with such a bang,
    they flew off into the bushes,
    and it was the left tit that left that big splash mark on the muffler there...
    :notsure:
    Gear ratio mismatch (major) would be instantly obvious,
    even a _tiny_ variation in ratios becomes obvious within a mile or two, the truck gets sluggish and bogs as it twists up the driveshafts before something lets go with a bang. You will feel it.
    It's also possible that there was a chemical problem with the steel, inclusion in the steel, heat treating issue and a tooth let go or the ring gear cracked/split.
    Bearing failure... drain plug not put in... etc etc
  17. Mar 12, 2021 at 8:49 PM
    #197
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Do u think 5w30 coukd be partly to blame?
    Hooper89, tonered and trktwo like this.
  18. Mar 12, 2021 at 9:28 PM
    #198
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Pretty sure it's the RWDLo switch.
    tonered likes this.
  19. Mar 13, 2021 at 12:24 AM
    #199
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    If it's Auburn gear, they use to be very good. I have not been there in about 12 years.
  20. Mar 13, 2021 at 3:50 AM
    #200
    Chap79
    Chap79 Well-Known Member
    Virginia
    2020 TRD OR DCSB
    Ironman 2” lift, CaliRaised Sliders, 255/80 Toyos, SSO bumper, dual batteries, solar, OBA
    Another great shop in the Sac area is Valley Hybrids in Stockton. They specialize in 4wd Toyota differentials and transfer cases.
    T-yoda likes this.
