Did my transfer case just explode? Please help!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jkish17, Mar 11, 2021.
  1. Mar 11, 2021 at 9:24 PM
    #41
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    True if kept straight.
    I really hope its just his diff breather tubes or something along those lines that werent on all the way.
  2. Mar 11, 2021 at 9:24 PM
    #42
    sbb
    sbb Active Member
    CNY
    2020 Red OR DCSB, 2006 Indigo OR
    Highly customized radio presets / Metric fuel adapter
    RatDaddy, Slick Taco, Skydvrr and 2 others like this.
  3. Mar 11, 2021 at 9:25 PM
    #43
    jkish17
    jkish17 [OP] Well-Known Member
    Roseville, CA
    2018 DCLB TRD OR
    -Dobinson’s IMS shocks on C59-354 coils -Dobinson’s rear shocks -Dobinson’s L59-111-R heavy leafs -Wheeler’ off road super bumpstops -Wheeler’s off road U-bolt flip -JBA Upper control arms. -35x12.5r17 Yoko Geo MT’s -17x7.5 4Runner spare steel wheels (Part #42611-35430) -Trailgear 1.5 spacers -C4 fabrication rock sliders -Relentless Fabrication High Clearance Rear Bumper, no swingout. -CBI T3 front plate bumper, no hoop/bullbar. -Ironman 4x4 12,000lb synthetic winch -Victory 4x4 roof rack -China camper from Alibaba -CVC tuned -ExtremeLED lightbars in the roof rack and front bumper. -Baja Squadron's in the rear bumper -MESO customs stuff everywhere -Dobinson’s Zenith air compressor mounted under the hood -Homemade S-pod relay box -Entire sound system replaced and sound deadening added
    In my head I assumed that the first time I go to engage 4wd should probably not be when I’m being hard on the truck because I’m actually using the 4wd capability.
    I thought a couple miles here and there would be better for it to help break in the new gears
  4. Mar 11, 2021 at 9:26 PM
    #44
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    I don't think pavement was the issue at hand unless, as previously stated, you were taking sharp turns. Which you likely would have felt the resistance through the tires before something mechanical broke.
  5. Mar 11, 2021 at 9:27 PM
    #45
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I think it was probably something else. There was a guy in the first gen section the other day that had significantly different sized tires front and rear, and when he ran it in 4wd the input shaft to the front diff popped. It took a surprisingly long time for that to happen. If you're just throwing it in 4 on mostly straight roads on occasion, there's no reason it should blow up. Something was actually wrong here.
    xxTacocaTxx, slander and ktbell444 like this.
  6. Mar 11, 2021 at 9:29 PM
    #46
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    I remember back when some shop in Cali did a group buy of gears, something like front and rear installed 1500 or some cheap price. Mixed up a few diffs and put mixed 4.88 with 5.29s, or stock front gears with 4.88/5.29s rear and caused all kinds of havok.
    cosmicfires, tonered and Grossomotto like this.
  7. Mar 11, 2021 at 9:34 PM
    #47
    jkish17
    Roseville, CA
    2018 DCLB TRD OR
    No it was a straight line. All the way to the restaurant would have been a straight line. My plan was to put it in 2wd before I got there and had to make any turns
  8. Mar 11, 2021 at 9:39 PM
    #48
    jkish17
    Roseville, CA
    2018 DCLB TRD OR
    Well I drove all of like a few hundred feet before it stopped. Would have been probably 1.5-2 miles to where I was going. Also the tires are 3 weeks old.
    xxTacocaTxx, boston23 and Lt. Dangle like this.
  9. Mar 11, 2021 at 9:40 PM
    #49
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    You driving in 4hi in a straight line on pavement had nothing to do with causing this failure.
    max_o, 44-16 Taco, Anton338 and 27 others like this.
  10. Mar 11, 2021 at 9:44 PM
    #50
    jkish17
    Roseville, CA
    2018 DCLB TRD OR
    This is how I felt too. I think if this were the case, people who don’t know any better would accidentally be blowing up there trucks
  11. Mar 11, 2021 at 9:47 PM
    #51
    KingZee
    KingZee Well-Known Member
    Z
    Los Angeles
    2018 TRD OR
    Bootleg Pro Grill / 16” SCS Ray 10 Black / 265/75/16 KO2s / Voodoo 10” Rack / DA Warrior XL
    Yeah let’s put that theory to bed. Obviously that’s not the reason for this failure.
  12. Mar 11, 2021 at 9:50 PM
    #52
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    I agree if he was straight should be "ok". But I would delete this post. Tell them you hit a dirt road near your house just to get some turns on the front, made it about 100ft, bang. Truck seized up. Took a bit to get back to 2hi. Then drove home.
    Again its the internet. Delete this thread.
    79CHKCHK likes this.
  13. Mar 11, 2021 at 9:51 PM
    #53
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    There's always the one guy who is willing to throw integrity out the window for a few bucks.
  14. Mar 11, 2021 at 9:59 PM
    #54
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Seems like the fluids drained themselves ;)
    And what’s he supposed to say else? That this happened in 2wd? Or lie about the whole thing? Nah, if they wanna blame him they’ll blame him anyway
  15. Mar 11, 2021 at 10:01 PM
    #55
    jkish17
    Roseville, CA
    2018 DCLB TRD OR
    That and they seemed like a good shop. Mistakes happen. Or the gears could have been bad.
    Big tall dave likes this.
  16. Mar 11, 2021 at 10:25 PM
    #56
    MilkDud
    MilkDud Well-Known Member
    2021 MT DCSB Off-Road
    And risk the shop screwing this guy over on some BS reason if they see this thread? That be some chucking of integrity too, don't you think? He's not compromising his morals, merely simplifying his problem. If what he says on here is true, I see nothing wrong with the suggestion.
    Skydvrr likes this.
  17. Mar 12, 2021 at 1:07 AM
    #57
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    I'll bet it's mix matched gears.
    wolf2600, jetfishn and Skydvrr like this.
  18. Mar 12, 2021 at 3:27 AM
    #58
    1776Taco
    1776Taco Well-Known Member
    2019 2.7 4x4 SR
    added rear seats access cab LEER 100R Curt hitch receiver Curt trailer lights Carthart seat covers 255/85/16 Toyo MT for trails 265/70/16 W/ OR wheels for DD TRD PRO skid OR fuel tank skid Warn tubeless winch bumper Smittybilt XRC 9.5k winch HS 1/4 inch coil spacers RCI rock sliders Wheelers 1.5 AAL Bilstein 5100 rear Decked
    Need to make sure your gears , both front and rear, are matching ratios.
  19. Mar 12, 2021 at 3:41 AM
    #59
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    I'm leaning to a gearing issue. Did you check to see if the front diff is leaking. Many times I have seen fluids on the under side of a vehicle come from a component in the front only to show up towards the rear. The fluid will get pushed/splashed back while driving. Also check the 4WD actuator make sure it has its connections in place. Good luck.
    Please keep us informed on the process.
    RyanDCLB likes this.
  20. Mar 12, 2021 at 6:58 AM
    #60
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Let me get this straight you engaged 4x4 on dry pavement ?
    The hammer and 79CHKCHK like this.
