Did my transfer case just explode? Please help!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jkish17, Mar 11, 2021.
  1. Mar 12, 2021 at 7:47 AM
    #81
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
  2. Mar 12, 2021 at 7:48 AM
    #82
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    It's always nice when we can get the 'work' part of our day out of the way before noon! Now who can tell me the best way to secure my MTB in the back of my truck when I stop at gas stations :rolleyes:
  3. Mar 12, 2021 at 7:52 AM
    #83
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    I usually break in 4x4 on the ground instead of pavement. Even after re-gear, drive the truck to the park then engage 4x4 for a few miles. Back to 2wd before getting on the road.
    The hammer likes this.
  4. Mar 12, 2021 at 7:52 AM
    #84
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :poking:
    1/2in dia cable through the cab windows. Someone might steal your axle.
  5. Mar 12, 2021 at 7:52 AM
    #85
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    10 feet of anchor chain from the USS Iowa. String the chain thru the wheels and frame then padlock to the bed tie downs.
    Jojee117 and Kev250R[QUOTED] like this.
  6. Mar 12, 2021 at 7:57 AM
    #86
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
  7. Mar 12, 2021 at 7:57 AM
    #87
    therealprotaco
    therealprotaco Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    Yes, and we already established that is not an issue here.
  8. Mar 12, 2021 at 7:58 AM
    #88
    therealprotaco
    Gilbert, AZ
    I think I would downvote every post that guy makes!
  9. Mar 12, 2021 at 7:59 AM
    #89
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Any update on this? No idea your tool situation or mechanical aptitude but incase anyone searches in the future:
    Betting the case exploded as a result of something in the front diff.
    • Jack the front of the truck up and start trying to spin things. If it's locked you found out why your transfer case exploded. The weird part is the front diff is always spinning so it "should" have locked up before then.
    • If evreything moves, then it may be the rear end, check the same things.
    • Check to see if there is fluid in the diffs
    • If the rear end spins then something grenaded in your transfer case.
    My trans popped out of gear leaving a stop light and it sounded like a damn bomb went off and then like a cement mixer and would not go into 1st gear and I had to physically hold it in evrey gear but 4th. Turns out I had a seal let go in my trans and it was running without fluid for an unknown period of time and went bang. Same thing could have happened in your diff.
    averagejp likes this.
  10. Mar 12, 2021 at 8:01 AM
    #90
    Knute
    I believe diffs and Xfer case are splash lube systems.
  11. Mar 12, 2021 at 8:20 AM
    #91
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Now even more! :angrygirl::pout::rain:
  12. Mar 12, 2021 at 8:20 AM
    #92
    Skydvrr
    Nick
    YMH
    Black '17 OR
    :rofl::rofl:
    How's the ole tundy?
  13. Mar 12, 2021 at 8:23 AM
    #93
    xxTacocaTxx
    xxTacocaTxx Well Unknown Member
    Best Slope CO
    2017 TRD OR DCLB 4x4 OMGWTFLOLBBQ
    RCI skid plates Mobtown sliders Lots of patches and MESO stuff
    Which part, read the manual?
    wolf2600, Tacotj and whatstcp like this.
  14. Mar 12, 2021 at 8:27 AM
    #94
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    Its already been answered multiple times. You read the manual?
  15. Mar 12, 2021 at 8:35 AM
    #95
    racegkrueg
    racegkrueg Well-Known Member
    Fresno, CA
    '18 DCSB TRDOR White
    This is a Friday thread for sure. Engaging 4hi in a straight line on pavement will do nothing to harm your truck. Someone straight up claiming that mismatched tire wear will cause his gearing to explode because of 4hi on pavement? :rofl:
    cosmicfires, Skydvrr and xxTacocaTxx like this.
  16. Mar 12, 2021 at 8:37 AM
    #96
    xxTacocaTxx
    Best Slope CO
    Pretty much cover to cover. First brand new vehicle, first 4x4 truck, I thought RTFM might help me understand how it works, what I need to do to keep it running for the next 20 years, and what the No-Really-You're-Gonna-Break-It stuff might be. I mostly trust the Toyota engineers over TW engineers.
    Tacotj and averagejp like this.
  17. Mar 12, 2021 at 8:38 AM
    #97
    ryanvar42
    None
    Yeah, I wont have this truck for more than 5 most likely as that's when I always get a new vehicle. But, always a great idea to read it over if you have the time or are interested
  18. Mar 12, 2021 at 8:41 AM
    #98
    Itchyfeet
    Itchyfeet Well-Known Member
    Im not sure anyone asked but were the tires all the same size during this test?
  19. Mar 12, 2021 at 8:46 AM
    #99
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    My guess is that its either diffrent gears installed or 4wd on pavement. Even in a straight line it can cause wind up.
    "When traveling with part time 4WD on high traction surfaces like asphalt, concrete, etc. handling of the vehicle will become unsafe (understeer) and the "driveline binding" will eventually cause component failures. Part time 4WD should not be used on high traction surfaces! Even when going straight most of the time, slight differences in tire pressure front to rear or vehicle load resulting in different axle speeds will cause "wind up" and eventually damage."
    The hammer and 79CHKCHK like this.
  20. Mar 12, 2021 at 8:47 AM
    #100
    xxTacocaTxx
    Best Slope CO
    I drive stuff until the wheels fall off. 375k on my B2200 over 20+ years, and 150k on a Subaru over 10ish years. That Mazda is still kicking as a wood/water/whatever hauler at the FIL ranch house.
