Did not expect to find this
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nastruck, Oct 23, 2021.
  1. Apr 9, 2022 at 3:18 PM
    #41
    nastruck
    nastruck [OP] Well-Known Member
    Harold
    Mills
    Running boards Soft bedcover Ventshades
    I agree!!!!
    I have a nephew that is a metal fabricator and he is going to fix it for me!
    Lucky lucky lucky
  2. Apr 9, 2022 at 3:29 PM
    #42
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Yup, my 10 was done with that black stuff.
    They didn't take it? Why?
  3. Apr 10, 2022 at 4:04 PM
    #43
    nastruck
    Harold
    Mills
    To tell the truth I don't trust them to do any work on my truck. Once I found out my nephew would do it for me I didn't care any more!!!!
  4. Apr 10, 2022 at 6:18 PM
    #44
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    A new frame that is almost free is absolutely 100% worth it over patching an old one.
  5. Apr 11, 2022 at 8:38 AM
    #45
    ABA180
    East Bridgewater MA
    I'm fortunate to have a good dealership nearby, though I try to do my own stuff when possible. That said, passing on a brand new frame that's no cost to you is totally your choice.
    nastruck[QUOTED][OP] likes this.
  6. Apr 11, 2022 at 8:57 AM
    #46
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    I’m sorry to hear about your troubles and I hope this gets resolved.
    Toyota really screwed us in North America with these junk Taco frames made of scrap steel.
    Sure they replaced some under warranty but now every other thread on here is about frame rot, and most owners I’ve seen with these issues have been given the run around by the dealer.
    It’s honestly mind-boggling they didn’t solve this issue after the first gen debacle.
    nastruck[OP], Blockhead and Chris2009 like this.
  7. Apr 11, 2022 at 12:33 PM
    #47
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    Fixing an issue you created for someone implies that you are admitting fault for the issue in the first place. I'm guessing the settlement terms for Toyota and the class action that sued them have something to do with it.
    I don't understand why they don't galvanize or provide some other protective coating for the frames either.
  8. Apr 11, 2022 at 6:09 PM
    #48
    Ozark_RegCab
    Nick
    Northwest Arkansas
    I think the main reason they did the frame replacement program was they figured the cost of replacing them would be cheaper than all the possible lawsuits resulting from failed frames causing accidents etc. A lot of them literally starting rotting from day one in the salt belt.
    Dana took part of the blame for it, I'm not sure about the actual supplier of the steel though, whether that was Dana, Toyota, or some other third party.
    Toyota and Dana both would've saved money by doing it tight the first time, so I'm really astounded as to why it's been an issue for so long.
  9. Apr 12, 2022 at 12:25 PM
    #49
    ABA180
    East Bridgewater MA
    Remember too that by the time this started coming up with the 1st gens in 2008 you already had a ton of 2G's out there..April 2008 was when my wife's 96 was taken
  10. Apr 13, 2022 at 12:00 PM
    #50
    nastruck
    Harold
    Mills
    That was a dead end street!!!!
  11. Apr 13, 2022 at 12:03 PM
    #51
    nastruck
    Harold
    Mills
    That was a dead end street. They were not going to replace my frame no matter what!!!!
  12. Apr 13, 2022 at 2:10 PM
    #52
    fxntime
    gotcha.
  13. Apr 14, 2022 at 1:00 PM
    #53
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I didn't catch why the dealership said no to a new frame? Were you past the timeframe?
  14. Apr 14, 2022 at 2:08 PM
    #54
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    You apparently don't understand how steel is made, used and recycled. Most of the steel used in automotive production (and everything else) is recycled. So why doesn't everything rust like Tacoma frames? The finishing process - as I've said many, many times. Recycled steel is no more (or less) prone to corrosion than virgin steel. It's how you protect the steel that makes all the difference. The finishing / painting process used on Tacoma frames just wasn't as good as it should have been.
    nastruck[OP] likes this.
  15. Apr 14, 2022 at 2:13 PM
    #55
    fxntime
    Dear Toyota, galvanize, galvanize, galvanize.
    Is that so darn hard to do?
    You could even advertise your frames are the longest lasting in the automotive industry.
  16. Apr 14, 2022 at 2:36 PM
    #56
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Well I'm not a metallurgist but the best explanation for the way these frames rot from the inside I've seen was from @Fifthwind who cited impurities in the material as well as some shoddy manufacturing processes. Rust proofing or the lack thereof is also an important factor though, but it'd unclear how much of the frame rot stems from poor rustproofing or impurities in the material itself.
    My 97 LC doesn't seem to have the same issue with delamination of the steel. Same with a lot of old truck frames: they might have surface rust all over, but they don't tend to peel off and cause structural issues like in the 1G Tacoma.
    Even apart from the rust issues, Toyota made the frames really thin and weak compared to the Hilux frames overseas.
    Fifthwind likes this.
  17. Apr 15, 2022 at 4:35 AM
    #57
    Too Stroked
    Tom
    I hope I didn't come off as dumping on you because I didn't mean to. I just get tired of all of the internet experts who claim to know the root cause of a problem they know next to nothing about. I'm not a Metallurgist either, but a retired Mechanical Engineer with many years in the metals finishing business.
    "Impurities" are not the cause of the corrosion because every single batch of steel - virgin or recycled - has them to some degree. "Chinese steel" is not the cause because a disturbing percentage of the finished steel in the world comes from there. "Recycled scrap steel with rust in it" isn't the cause because the temperatures and pressures involved in the process take care of it. "Lack of rust proofing" is not the cause because a good metal finishing process (generally) doesn't need additional rust proofing. Besides, if any of the above were really the root causes, wouldn't other products made from the same steel be corroding too?
    The problem comes down to a poorly specified, applied and controlled finishing process. A few dollars (or pennies) saved in manufacturing once again costs a company many times that savings down the road. After 36 years in manufacturing, I've seen it many, many times.
    Ozark_RegCab[QUOTED] and DES2009 like this.
  18. Apr 15, 2022 at 7:47 AM
    #58
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    You may not wish to believe there are impurities, but my observations have been far different when it comes to Chinese steel. For a time I was an R&D engineer in the heat treating industry where I created annealing and hardening processes for a variety of metals from around the world. Single crystal process for titanium air foils, field processes for inconel annealing, tool steel hardening exotics like Rene95. For the Chinese market, the processes looked quite Frankenstein in order to prevent warping and even rupturing during the hardening cycles. What I observed was material that was far from homogeneous, and under the microscope, revealed a wide range of impurities from silica to lead in what should been 99% steel. You can tell yourself whatever you like but the metal is lower quality. Quality steels do not delaminate when they oxidize.
    As for the second gens, after being up close to many more frames, and even taking a look at a pile of swapped out frame at my local dealer, they were further compromised by poor weld quality.
    Torspd and Ozark_RegCab like this.
  19. Apr 15, 2022 at 12:57 PM
    #59
    Too Stroked
    Tom
    Finally, somebody with some actual experience and credentials. I have no doubts that Chinese steel has more impurities in it. (I've been to China on numerous occasions on business.) That said, I truly doubt the impurities cause the corrosion seen on Tacoma frames. As I stated before, a non-robust finishing process is what's leading to the majority of the problems. I will agree that the frame design does exacerbate corrosion issues. For instance, there are several areas where two steel parts are sandwiched together. Very few metal finishing processes will get into the area between those parts to prevent corrosion. On the other hand, water with road de-icing chemicals will leach in there just fine and cause corrosion from the inside out. (This BTW is why you see what looks like delamination even though it is just corrosion creeping from the inside out.) Other issues include where the A/C condenser drain empties and box sections that trap and hold moisture.
    Please don't get me wrong, the Tacoma frame corrosion issue is 100% Toyota's fault and was also very preventable. As I've stated before, somebody saved some money in the short term and it's costing way more in the long term - but only on trucks used where road de-icing chemicals are used.
    Ozark_RegCab likes this.
  20. Apr 15, 2022 at 7:30 PM
    #60
    Chris2009
    Chris2009 Well-Known Member
    Massachusetts
    2013 Reg Cab 4x4
    yep - seems like mostly an issue in the north east and Great Lakes regions. Unfortunately plenty of us need trucks in these areas and Toyota totally shit the bed here…..they seem to be chronic bed shitters at that. Makes no sense.
