Did not want to start
Discussion in '1st Gen. Tacomas (1995-2004)' started by Karl64, Jan 10, 2012.
  1. Jan 10, 2012 at 2:20 PM
    Karl64
    Karl64 [OP] New Member
    Karl
    Midwest
    98 4cyl Extendo cab
    This morning my 98 2.4l tacoma did not want to start. It cranked a few time making the normal going to start sounds, then like it shifted into a faster speed, almost like it had lost compression. It did this one other time (a couple years ago) and I let it sit for a few days and it started and has run/started fine until this morning.
    So I kept trying the starter on and off, until it started. then the engine made a real high pitched squeal for about 30 seconds. After that it is sounding and running fine.... Any suggestions? I wondered if I had a sensor go bad. The truck has 178K miles, but does not use oil and I get ~21 mpg
  2. Jan 10, 2012 at 2:24 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Squeal-sounds like a belt loose or going bad. does it have an idler pulley--sometimes they freeze and make belt squeal . Smell anything? Burning rubber?
    Check belt tension and idler pulley first. Then water pump,alternator, ect.-thats next!
  3. Jan 12, 2012 at 12:16 PM
    Karl64
    Karl
    Midwest
    98 4cyl Extendo cab
    my AC belt is a little loose, but you may be right about the tensioner. I will look at it this weekend, but that does not answer why the truck would nto start or even sound like it wanted to start....
  4. Jan 13, 2012 at 3:06 PM
    MacGyvR
    MacGyvR Well-Known Member
    Tom
    Arizona
    03 Prerunner SR5 2wd
    Was it making a ticking noise at all, or was it just chugging for too long at start up? I'd try cleaning the MAF.
  5. Jan 15, 2012 at 2:09 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    What did you find?-
    Few possibilities about not wanting to start-lets see what you find!
    i.e. idler pulley frozen-friction-hard to turn over,
    alt belt-no charging--or not enough.
    Keep us posted.
  6. Jan 16, 2012 at 8:45 AM
    Karl64
    Karl
    Midwest
    98 4cyl Extendo cab
    For the time being the truck is starting fine, only the one time.
    Okay, I have tightened all of my belts, so no more squealing.
    I did clean my MAF sensor as I do have a cloth air filter that can cause oil deposits on the MAF sensor.
    No ticking, just the engine whirling over like there was no compression, but it sounded like it would try to start when you let off the key.
  7. Apr 12, 2012 at 3:04 PM
    Karl64
    Karl
    Midwest
    98 4cyl Extendo cab
    Three months later and the truck is starting fine, no issues.
