Did Outlaw Fasteners Come Out With the World’s Best Screw?
Discussion in 'Garage / Workshop' started by surfsupl, Oct 2, 2013.
  1. Oct 2, 2013 at 5:33 PM
    surfsupl
    surfsupl [OP] Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    http://www.youtube.com/watch?v=6qkmSoz8pJw
    The Hype
    No more stripped screws.
    No more dropped screws.
    No more screw wobble.
    No more deck board jacking.
    No more bit changes.
    No more pilot holes.
    No more hole splinters.
    Less frustration, quicker work, saved time.
    Reality Check
    In the literature Outlaw sent over, there is a chart that compares their fasteners to slotted, Robertson (square), Phillips, and Torx screw styles. There, Outlaw points out that their UniGrip driving bit engages their fasteners with 18 points of contact, compared to at most 6 points of contact with Torx drive bits and screws. This is the only marketing claim I find to be disagreeable, and that’s because I feel the comparison of points of contact to be factual but misleading.
    So let’s take another look at Outlaw’s marketing claims.
    No more stripped screws. True, at least compared to Phillips screws.
    No more dropped screws. True, at least when driving new screws, and without magnets.
    No more screw wobble. True, there’s no room for side-to-side play, which allows for more precise placement.
    No more deck board jacking. I didn’t test for this, but can see how it works.
    No more bit changes. True, thanks to the UniGrip design.
    No more pilot holes. True, but only when working with certain materials (such as decking boards).
    No more hole splinters. True, the countersinking head works quite well.
    UniGrip Driving System
    The UniGrip driving system is based on a stepped hexagonal design. Smaller fasteners have a 2-step recess, larger ones have a wider 3-step recess to allow for higher torques.
    I should mention that bit-fastener engagement at the widest hex step seems to be a little shallow. This doesn’t seem to affect screw driving one bit, and if the larger screws had deeper 3rd step recesses, their heads might become comically large. Still, it’s an observation worth mentioning.
    Outlaw’s UniGrip screw fitment is designed to hold tight and never cam out.
    The Screws
    As mentioned, forget about the 18 driving points part, it’s misleading. But to Outlaw’s credit, a substantial amount of engineering went into their new screws.
    First, there’s the UniGrip screw head that ensures you can use the same screwdriver bit for any Outlaw screw. On the under side of the screw heads are rigid ribs that helps the screws sit a little better in self-countersunk holes without requiring a separate operation.
    At the opposite end of the screws, self-drilling points allow you to skip over the need to drill pilot holes. You should still drill pilot holes when working near edges or with harder wood materials, but even then self-drilling points are a boon.
    The sharp self-drilling tips, 1/2-length partial threads (compared to 2/3-length partial threads) and self-cleaning ribbed knurls help prevent board jacking, where the a top board lifts up as the screw starts to engage the bottom board.
    Right now there are two material options – stainless steel or steel with ACQ finish coating for use in pressure-treated lumber. These fasteners have corrosion resistant enough to have passed 1,000 hour salt spray testing certification.
  2. Oct 2, 2013 at 5:35 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I would tend to think that a pornstar holds that title currently but :notsure:
  3. Oct 2, 2013 at 5:38 PM
    surfsupl
    Gregg
    WestCoast
    You have to get past the cheesy video:cool:
  4. Oct 2, 2013 at 5:42 PM
    Pugga
    Massachusetts
    F-150 Mod
    It's a cool product, but I don't see it being a huge hit. I'll bet those screws are fairly expensive and torx-head exterior screws are already doing pretty well (and the old fashioned Philips head will not die out any time soon).
  5. Oct 6, 2013 at 7:33 PM
    surfsupl
    Gregg
    WestCoast
    They need to outlaw flat head screws :evil:
  6. Oct 6, 2013 at 7:34 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    I see what you've done here
  7. Oct 6, 2013 at 7:43 PM
    ChamYota
    ChamYota Crash Bandicoot Or Groot, Just Depends
    Cam
    Clemson,South Carolina
    05 PreRunner and 2004 Lexus IS300 Sport Design
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    :eek: Porn puns inbound...
  8. Oct 6, 2013 at 7:48 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Screw the porn puns ;)
    I'm waiting for pete to weigh in on this :popcorn:
  9. Oct 6, 2013 at 7:49 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Robertson FTW
  10. Oct 6, 2013 at 7:53 PM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    New.. Sure fine and dandy. 10 years on a deck or wall and say you wanna take a few boards off... 18 points of contact sounds like to me it wont fit anymore. Even using a Philips or Robinson bit full or dirt and corrosion sucks
  11. Oct 6, 2013 at 7:54 PM
    benbacher
    Anchorage, AK
    Looks pretty good though pete, explain your argument, which was notably short and predictable :)
  12. Oct 6, 2013 at 7:54 PM
    Ghost848
    Tony
    Alberta,Canada
    :canada:
  13. Oct 6, 2013 at 7:55 PM
    OZ-T
    Peter North
    British Columbia
    I would be interested in trying them
  14. Oct 6, 2013 at 8:22 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    The screw head design needs tight forging tolerances for it to work. I think once they put the screw to mass production, they'll realize each screw costs 3 times as much to manufacture as robertson or torx screws, and never gain traction with any distributor...
