Did rear axle breather mod...axle under pressure.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Flash1034, Aug 24, 2018.
  1. Aug 24, 2018 at 9:29 PM
    Flash1034
    Flash1034 [OP] Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    For what it’s worth, I did the rear axle breather mod today on my new Pro. When I unscrewed the factory “vent” it released a fair amount of air pressure. The axle was cold and the truck had been parked all night. My guess is the stock vent wasn’t venting. Might want to do the mod so your sure it’s venting. Pressure buildup can cause leaks past the axle and pinion seals. FYI only. YRMV.
  2. Aug 24, 2018 at 9:32 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Are you sure it wasn’t drawing air in? That would make more sense for a cold axle. The OEM valve is supposed to prevent a cold axle sucking water in.
    Boghog1 and 1bad2k like this.
  3. Aug 24, 2018 at 9:35 PM
    Flash1034
    N/W Montana
    Nope...I’m not sure. Either way, the stock vent wasn’t venting. It was 80 degrees today so no huge temp fluctuations.
  4. Aug 24, 2018 at 10:02 PM
    Stocklocker
    17TRDORDCSBAT
    My understanding is the stock breather is a one-way unit. It will allow expansion of the air in the diff to be vented, as it warms up, but will only allow air back in very very slowly to avoid sucking water in a river crossing etc., when the diff cools down.
    I’ve not proven this, just what I read about it someplace.
  5. Aug 26, 2018 at 11:17 AM
    Ducman82
    Ducman82 Well-Known Member
    jake
    2016 Sand Tacoma TRD
    I just did this mod. after 2 days, the axle was still under "vacuum" when i removed the stock breather. :) wonder if thats how they keep it from leaking! LOL.
  6. Aug 26, 2018 at 11:20 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    That's correct.
    Stocklocker[QUOTED] likes this.
  7. Aug 26, 2018 at 11:22 AM
    Stocklocker
    17TRDORDCSBAT
    That’s actually a positive observation. Clearly Toyota has put some engineering into that OEM breather if it will hold vacuum that long. I believe that is the intention, not to allow suction. When I did my diff oil change the rear diff was under vacuum as well, so the OEM breather was not letting the outer atmosphere into the diff as it cooled down.
  8. Aug 26, 2018 at 11:51 AM
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    same here. also makes sense as to why would they relocate the trans and front diff breathers and leave the rear on the axle. It's not an oversight.
  9. Aug 26, 2018 at 1:22 PM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    I’m confused. I’m right about to do this mod, came here to check for ideas on where to route and place the breather valve. So is this mod not a good idea??
  10. Aug 26, 2018 at 2:31 PM
    EdgeCrusher
    Chicagoland
    I'm not saying its not a good idea if you definitely going to be in deep water a lot. But I think it's not needed for 99.8% of owners including those that go off road. If it was a concern, they would have relocated it higher like the other two in the front is my thoughts.
