Did something dumb and it is bugging the crap out of me
Discussion in 'Technical Chat' started by gatlin69, Jul 3, 2011.
  1. Jul 3, 2011 at 8:10 AM
    gatlin69
    gatlin69 [OP] Retired?
    Scott
    Tampa
    4x4
    Nerf bars, bug shield,skid plate, coming soon (hopefully) DVD NAV
    Question...I wanted to goof with my 4wd the other day. I have never owned one until recently, so I put it in 4L and drove it up my driveway. It was dry asphalt and concrete. It was only about 30-40 feet. I read a thread that doing that is really bad idea....comments on if I did any damage? Thanks in advance.
  2. Jul 3, 2011 at 8:16 AM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    hahaha
    did you even notice a difference in anything?
  3. Jul 3, 2011 at 8:17 AM
    gatlin69
    Scott
    Tampa
    4x4
    No...just that type that worries for nothing most of the time.
  4. Jul 3, 2011 at 8:18 AM
    RoyR
    RoyR Well-Known Member
    San Diego, CA
    Billies, TSB
    It becomes an issue when you turn....then you can damage something.
  5. Jul 3, 2011 at 8:18 AM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Assuming that's your driveway in your sig pic, it's a straight line so you have zero worries. Even 30-40 ft of curve wouldn't do much... just don't try a winding road with it engaged. :D
  6. Jul 3, 2011 at 8:19 AM
    Bird
    Bird Well-Known Member
    Jay
    Vail, CO
    '11 MGM DCLB TRD Sport
    If thats the worst it sees, I'll buy your truck when you're ready to get rid of it
  7. Jul 3, 2011 at 8:20 AM
    gatlin69
    Scott
    Tampa
    4x4
    I don't recall if I turned...maybe a bit...but if you look at my signature pic, that is how far I went.
  8. Jul 3, 2011 at 8:21 AM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    You'll be fine. I put mine in 4wd once a month and 4-Lo now and then to get the gears turning. It won't hurt anything doing so on dry pavement if you go in a straight line. Calm your fears.
  9. Jul 3, 2011 at 8:21 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Don't do that again...
  10. Jul 3, 2011 at 8:23 AM
    gatlin69
    Scott
    Tampa
    4x4
    Thanks guys
  11. Jul 3, 2011 at 8:26 AM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    hahahahaha..no worries man...they dont want you turning or driving distances in 4lo on pavement thats all moving it around itll be fine
  12. Jul 3, 2011 at 8:26 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    No problem...just don't make a habit of it. If you had made some sharp turns you would have known right away the truck didn't like it. As long as you were going straight your good...when turning it binds everything up and the truck would have made grinding noises and felt like it hopped across the pavement. Read the links below about turning on pavement while in 4WD...
  13. Jul 3, 2011 at 9:54 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    No worries. You could put it in 4lo and drive hundreds of feet on pavement and be perfectly fine. Even if you turned, you'd feel it start to bind up on you. But it's not like the gears are made of glass. Nothing's gonna shatter .. that is unless it's made wrong. There are Tacomas out there with hundreds of thousands of miles that have been wound up, bound up, beat down and still go strong. Hell if 40 feet was all it took, then it sure as hell isn't worth $30k! :)
  14. Jul 3, 2011 at 10:18 PM
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    you worry too much.
    It's fine. Besides - read your manual. It recommends driving in 4H every so often to keep the gears lubricated.
  15. Jul 6, 2011 at 4:05 PM
    csuviper
    csuviper Moderator Moderator
    Brian
    Broomfield, CO
    2012 Tundra Rock Warrior 5.7L 4x4
    3" Toytec Ultimate Lift, 315/70R17 Duratracs, RW Wheels, Grillcraft Grill, Toyota "Raptor" Lettering and more
    LOL! I baby my truck and I have gunned it in 4low and turned to get over a rock. No problems from that. Your truck will be fine.
    Just whatever you do, do not take it off the pavement. The rest of us will have fun with that.
  16. Jul 7, 2011 at 2:54 PM
    gatlin69
    Scott
    Tampa
    4x4
    :rimshot:
  17. Jul 7, 2011 at 2:57 PM
    gatlin69
    Scott
    Tampa
    4x4
    I did and I do really appreciate it.
  18. Jul 7, 2011 at 3:00 PM
    gatlin69
    Scott
    Tampa
    4x4
    Yep learned my lesson.
  19. Jul 7, 2011 at 3:06 PM
    gatlin69
    Scott
    Tampa
    4x4
    This thread turned crazy on me..lol
  20. Jul 7, 2011 at 3:34 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    crocs make good boat shoes...
