Did Something Stupid When Changing My Oil...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MATacoma2014, Dec 14, 2024.
  1. Dec 15, 2024 at 10:32 AM
    Positraction
    Positraction Member
    SoCal
    2005 TRD Off-Road PreRunner
    New 2020 tires and wheels
    Years ago, After going to a Jiffy Lube, by the time I got home there was oil leaking from their install of the oil filter. So just say no to oil changes at JL!
    Everyone has some good suggestions for you but if it were me, I’d steam clean all the oil off everywhere. Then change out the filter checking for any mistakes made there. Good luck!
    1 Limited Toyota likes this.
  2. Dec 15, 2024 at 12:29 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’ll decipher this for other.
    OP changed the oil in his truck.
    He went to turn the truck on and allow oil to flow into the filter so that he could get the correct level on the dipstick. After starting the truck he realized he left the oil FILLER CAP off. And also noticed a mist of oil all over the engine. He then added 1/2 quart of oil “extra” to make up for the oil that “splashed” out the cap.
    Then he noticed oil dripping out of his exhaust.
    What we don’t know is,
    Was it really oil? Or condensation?
    You’d have to have gallons of oil in the engine to have it drip “puddle” out of the exhaust.
    We are missing some important information.
    None of which is matters. As I think this is a classic case of “overthinking it”.
    rblalliance likes this.
  3. Dec 15, 2024 at 3:37 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    1) you didn't hurt anything leaving the cap off for a second while you run the engine
    2) that's not oil coming out of the exhaust. It's water formed by condensation and it has an oily-like color because there is combustion byproducts and soot in the exhaust pipe. Stick your finger in it, it will feel like water not oil
    OffroadToy likes this.
  4. Dec 16, 2024 at 8:53 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Just wanted to clear this one point up.
    The Tacoma 2.7 liter 2TRFE Engine takes 6.1 US quarts with a filter change as per the owners manual.
    Williston and TnShooter like this.
  5. Dec 16, 2024 at 9:18 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Used to be a common query in the 2nd gen section. Usually 5.5 qt is sufficient to bring the oil level to the full mark on the 2TR dipstick. And dipstick reading takes precedence over the reference capacity, according to the owner's manual.
    Float your rings? Wut?
    While the engine is cold, thoroughly hose down your engine bay and exhaust manifold with a degreaser. Run the engine and visually inspect the oil filter interface for leakage. Usually you'd see oil bubbling out if there's leakage.
    Most dealer quick lube lanes have a pressure washer wand hanging from the ceiling to blast away spills.
    Until they start the engine with the oil filler nozzle still hooked to the fill port, causing camshaft/valvetrain damage...
  6. Dec 16, 2024 at 1:43 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    You emptied the transmission thinking it was the oil pan,then added 6 more qt's of oil in the engine for a total of 12 maybe.
    Positraction likes this.
