Did the cruise control mod...got some tips for those interested.
Discussion in '4 Cylinder' started by sriley727, Aug 24, 2009.
  1. Aug 24, 2009 at 5:00 AM
    sriley727
    sriley727 [OP] Well-Known Member
    Aiken, SC
    08 Reg cab PreRunner SR5
    Bone stock
    Couldn't be happier with the mod but putting the clutch switch in was a bitch! The instructions on the toyota nation thread are spot on for the steering wheel part of the install but VERY vague on the clutch switch part.
    1. He recommends removing the lower dash...I say you MUST remove it. You just can't get to the bolt that you have to remove to put the switch in without removing it. There is a bolt hiding behind a little door on the right side of the drivers side of the dash. There is another one hiding behind the kick panel on the left side of the drivers side. Unbolt those and the top of the dash will unsnap. It will take a 10mm socket to unbolt these.
    2. You've also got to unbolt the fuse box, remove the wires on the front of it, and then kinda fold it down out of the way. 10mm bolts, again. Then you can access the bolt you need to remove. I think it will take a 15mm socket to undo the bolt in the clutch switch spot but I've forgotten the exact size in the past 3 days since I did it.
    3. There at least 4 connectors hiding in the wiring harness and only one of them is the one you need to unbundle. Its the one that is highest in elevation. I had to unbundle two of them before I found the right one.
    Also, on the test drive afterwards, the a/c wouldn't blow cold. Thought I had left something disconnected or blown a fuse but after a few minutes, it came back on. Must have just been the computer figuring things out again after the battery disconnect.
  2. Aug 24, 2009 at 8:36 AM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    By chance did you take pics? I am thinking of doing this MOD w/ the reference from TN. Overall it looks straight forward.
  3. Aug 24, 2009 at 10:39 AM
    pointtoretrieve
    pointtoretrieve Active Member
    Greenville N.C.
    06 Red Reg cab 4x4 2.7L
    DT header, K&N Filter charger, Flowmaster 44 series stainless tip, Jensen Head unit,soundstream components, 13'' subwoofer, 2 400 watt Autotek Amps.
    Want to do this to mine Part # and info would be great thanks.
  4. Aug 24, 2009 at 10:44 AM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    Here is a link to the TN writeup. Has OEM part numbers.
  5. Aug 24, 2009 at 10:51 AM
    pointtoretrieve
    Greenville N.C.
    thanks ordering the stuff today
  6. Aug 24, 2009 at 12:32 PM
    pointtoretrieve
    Greenville N.C.
    Went to the dealer and ordered one for mine the parts guy put me on this kit 00016-35901 and also needed 00016-35915-02 like this style a little better than the joystick one. Have it wed. can't wait to have cruise control on the drive to work.
  7. Aug 24, 2009 at 5:10 PM
    sriley727
    Aiken, SC
    Bone stock
    Wanted to take some pics but it was too damn hot and I was too busy cursing and bleeding.:D
  8. Aug 24, 2009 at 8:08 PM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    That sucks! I thought I would ask.
