Did the dealer put rubber on my frame without my permission? New 2023 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NjTaco23, Aug 17, 2023.
  1. Aug 18, 2023 at 12:25 PM
    #41
    Kwikvette
    Fresno County
    4 run, 2 don't
    OP needs a bubble
    Junkhead[QUOTED] and Just_A_Guy like this.
  2. Aug 18, 2023 at 12:26 PM
    #42
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    FWIW I drive a lot on FSRs and bottom rear shock hanger gets peppered with rocks well as well as other random spots on frame. Exposed metal/frame can be seen, nothing is “making its way in”.
    Don’t believe everything you read on the internez. If you would like, I can snap a few pics of my tacos undercarriage of said areas when I go pick up my truck today.
    Just_A_Guy likes this.
  3. Aug 18, 2023 at 12:29 PM
    #43
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Haha!
    If your truck is brand spanking new and never been driven, you can do rubberized if you would like. Get it professionally done though at a shop with good reviews.
    Otherwise I would do FF and cal it a day.
    I still FF suspension components and random exposed metal parts underneath my truck twice a year.
    513Mugsy likes this.
  4. Aug 18, 2023 at 12:29 PM
    #44
    NjTaco23
    NjTaco23 [OP] Active Member
    This is interesting because I've always heard that rubberized coatings are the devil and basically sabotaging the frame long term. Do FSR's have galvanized frames?
  5. Aug 18, 2023 at 12:31 PM
    #45
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    That’s what everyone says yes, I think cuz folks apply rubberized coatings over rust and that actually accelerates rusting process.
    FSR is a Fire Service Road sir.
    Phlogiston likes this.
  6. Aug 18, 2023 at 12:32 PM
    #46
    NjTaco23
    I definitely don't won't to rubberize. Cosmoline would be a decent option, but I'd have to remove the rubber most likely. I will probably just use fluid film or surface shield and assume it will creep into any area of the rubber that lets in moisture.
    Does fluid film work for you?
  7. Aug 18, 2023 at 12:32 PM
    #47
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    For his Tacoma so it doesn’t rust?:p
    Kwikvette[QUOTED] likes this.
  8. Aug 18, 2023 at 12:34 PM
    #48
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    If a hard or semi hard coating gets compromised then fluids can surely make their way underneath over time. Not always, but it is certainly possible.
    Same reason why on rusty Toyota frames if you go chipping away at some surface rust you may end up chipping away what looked like good condition adjacent coating and still find surface rust underneath. I’ve chipped off spots that started as an exposed .5-1” rust patch and not hit good frame surface til 2-3” beyond that.
    Regardless if it was me I wouldn’t be worried about it coming clean like that from factory. I’d just blast over it with whatever my favorite rust protectant is making sure it was something compatible with rubberized-like coatings. The rubberized coat is already a semi fixed/solid coat. I’d do something semi-fluid over it, like consistency of fluid film or similar. Idk if fluid film screws with rubber, I recall someone saying it may have caused some swelling of rubber components.
    Junkhead likes this.
  9. Aug 18, 2023 at 12:34 PM
    #49
    NjTaco23
    I thought you were driving Isuzu FSR's lol
    wayupnort likes this.
  10. Aug 18, 2023 at 12:35 PM
    #50
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Sir, leave that gooey stuff applied at the factory, it will help you in the long run. You trying to scrape it off will just make it worse.
    Long story but I actually met with a guy from Toyota that was involved in this rust proofing campaign on 2018+ Tacomas. That stuff is good and is there to help you.
    FF is good but washed away quickly and needs to be reapplied at least twice a year. Cosmo line definitely lasts longer.
  11. Aug 18, 2023 at 12:36 PM
    #51
    NjTaco23
    I'm think an oil based coating might degrade the rubber, but hopefully the oil will continue to creep, protecting any exposed area.
  12. Aug 18, 2023 at 12:37 PM
    #52
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    :rofl::rofl::rofl:
  13. Aug 18, 2023 at 12:38 PM
    #53
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Yes I’ve heard something like that, I haven’t had issues yet though.
    NjTaco23[QUOTED][OP] likes this.
  14. Aug 18, 2023 at 12:40 PM
    #54
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    FRIGGIN’ PISSED
    Junkhead and Kwikvette like this.
  15. Aug 18, 2023 at 12:48 PM
    #55
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    NjTaco23[OP] likes this.
  16. Aug 18, 2023 at 12:56 PM
    #56
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    It's usually a good idea to get underneath the vehicle if you can before you buy it. You could have addressed your concerns with the dealer before purchasing the truck.
    Kwikvette and Junkhead like this.
  17. Aug 18, 2023 at 1:00 PM
    #57
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I think the dealer owes him a PRO, it’s only fair.
    whatstcp and NjTaco23[OP] like this.
  18. Aug 18, 2023 at 1:01 PM
    #58
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
  19. Aug 18, 2023 at 1:03 PM
    #59
    NjTaco23
    Yeah, I can't believe I forgot to inspect the rear side of my c-channel for factory rubberized coating.:rofl:
    Now this thread is getting somewhere...
    Junkhead[QUOTED] likes this.
  20. Aug 18, 2023 at 1:06 PM
    #60
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    Toyota totally screwed you over an pulled a fast one on you. You should be beyond pissed. I'm surprised it hasn't started rusting already...
    FRIDAY FRIDAY FRIDAY FRIDAY FRIDAY....
