Did they give me the wrong spring? OME 886 and 5100
Discussion in 'Suspension' started by packfan88, Aug 13, 2011.
  1. Aug 13, 2011 at 2:03 PM
    packfan88
    packfan88 [OP] Very Nice !
    Acworth, GA
    Billy Lift, Cooper STT Pro, Westin Step bars, tinted, rain gaurds, EBC rotors hawk pads
    So i had to order from two different places for the front end lift. I ended up getting the 5100s all the way around and the AAL in the back.
    When it comes to installation and assembly, the 5100s should be set at the 0.00 setting or the .85 setting. But nothing higher, correct?
    With the 886 springs, are they too stiff or should I have gotten the 885?
    I read some where that its not advised to use the 5100s with OME coils cause they are not valved? Is this true, and if so whatd should i do?
    I called both Wheeler's and Downsouth and asked their sales reps (oon advise from this forum) for the proper hardware for my needs. Im not sayign I got the wrong thngs or its anyone one this sites fault...im just confused. So much information saying "go this way" then on the next page "that's wrong".
    I have the stuff in my garage and would like to install it but dont want to mess shit up.
    What should I do?
  2. Aug 13, 2011 at 2:08 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    the 885s and 886s are to different rated springs. The 886 is a lil stiffer and made for more loading bearing (like bumpers and winches). Set the 5100s at zero. I'm running 5100s with 885s and the ride is great...
  3. Aug 13, 2011 at 2:08 PM
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    I don't know about the compatibility issue, but I do know that the 886 spring is designed to support the weight of a plate bumper/winch so if you got just a stock front end it will end up being super stiff.
  4. Aug 13, 2011 at 5:18 PM
    packfan88
    Acworth, GA
    what about the issue of the 5100s not being a valved shock? What is that all about? I read somewhere that cause of the higher spring rate assembling the shocks annd coils will be almost impossible. Someone said it could snap off the fitting holding it together. Is installing the 886 impossible to do in my garage?
    So if i dont have the bumper and winch installed anytime soon, th eride will just be much stiffer until its installed?
    What about the lift....is it correct to set the 5100s at .85? That is the maximum height to go along with preloading the shocking?
    on a side note, is there a thread anyone knows of off the tops of their heads with an installation guide for the coils and shocks?
  5. Aug 13, 2011 at 5:21 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The 5100's are fine with 885's but most people frown on running them with the 886 springs
  6. Aug 13, 2011 at 5:26 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Do NOT set the 5100's at .85, leave them at 0. The 886's are very stiff and tall. If I were going to get 886's I would have gone with the Nitrochargers they were meant to work with. I'm sure the 5100's will work but the 886's might overpower them and the dampening may not really be sufficient. Without a heavy plate bumper and winch, it will be a rough ride. The 886's are meant to have 200+ lbs hanging over the front end of the truck. You'll be right at, if not higher than 3" of lift without a plate bumper and winch.
    You can compress the 886's, the shock that you're mounting them on will not dictate how hard of a process this will be. It will be equally difficult on any strut. The 886's have a high spring rate so it will be very difficult to assemble them but it can be done with a good spring compressor (or might be worth paying a garage to pre-assemble them for you).
  7. Aug 13, 2011 at 5:47 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    I have 5100s set at 0 and OME 886 coils. Granted I have the bumper.
  8. Aug 13, 2011 at 6:02 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Can you wait to put the 886's on til you get your heavy bumper? You can put your stock springs on the 5100's and set them at what ever you want your lift at. Then when you get your heavy bumper, set the 5100's at 0 and put the 886's on.
  9. Aug 13, 2011 at 6:15 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Leave the 5100s at 0. And why did you get 886s? 886s are designed for when you want to run a heavy front bumper. The install is easy, did it with a few jack stands but didn't use one of those unsafe coil compressors you rent at Autozone. Brought my struts and coils to my friends shop that has a coil compressor. You can re use the OEM Top Hats, just don't re use U-Bolts. Return the 886s and get 885s if you have a DC or.... If you have an AC or SC get the 884s. Keep the 5100s at 0"!!!!!
  10. Aug 13, 2011 at 7:52 PM
    packfan88
    Acworth, GA
    I plan on getting a plate bumper, but it will take a while to manufacture. Once I get the bumper everything should be fine? I guess i can wait for the install. Problem is its all suppose to go in one shot, new tires (wont fit with out lift) and new shocks/springs.
    If im setting the shocks at 0.00, why is it people recomended getting them? If the functionality of the adjustable height isnt even goign to be used why not go with a cheaper shock that DOESNT have that extra purpose? I assume it would have been cheaper for a standard body shock.
  11. Aug 13, 2011 at 8:14 PM
    OZ-T
    Peter North
    British Columbia
    Who recommended 5100's with OME 886 springs , especially pre loaded ?
  12. Aug 13, 2011 at 8:30 PM
    Bloodhound
    Bloodhound Banned from the Pics Thread
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    +1
    Granted, I'm kinda new to this scene but I thought I'd read on here about 5100's and 886's being a bad combination...
    Disclaimer: Chances are I could be wrong and as stated above, I'm kinda new to the scene of lifting trucks...
  13. Aug 13, 2011 at 8:47 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    People only set it at .85 when they use the 885's
  14. Aug 13, 2011 at 8:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    and thats not a good combo...
  15. Aug 13, 2011 at 8:56 PM
    kinkrider101
    santa barbara
    wheels and tires
    Yeah I know, but I read that. people did it because the 885's were sagging, but I would not reccomend doing that...
  16. Aug 13, 2011 at 9:02 PM
    DWreck
    Derek
    Las Vegas, NV
    I did it! :p
  17. Aug 13, 2011 at 9:06 PM
    OZ-T
    Peter North
    British Columbia
    I thought you said you had billies and 886's ?
  18. Aug 13, 2011 at 9:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Doesnt make it a good set up.
  19. Aug 13, 2011 at 9:08 PM
    DWreck
    Derek
    Las Vegas, NV
    Only because the 885s at 0.85" still wasn't high, or firm enough.
  20. Aug 13, 2011 at 9:10 PM
    DWreck
    Derek
    Las Vegas, NV
    So answer me this! Why is it so bad to put 885s @ 0.85"? Just because it's possible to over extend the billy?
