Did you have vibrations with a 2.75" lift on a Double Cab Short Bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DrRabbitFurHead, Feb 5, 2010.
After lifting your Double Cab Short Bed did you experience vibrations?
Poll closed Mar 7, 2010.
  1. No vibrations after my lift
    7 vote(s)
    46.7%
  2. I had vibrations but added the carrier bearing spacer and it went away
    2 vote(s)
    13.3%
  3. I had vibrations and the differential spacer made it go away
    0 vote(s)
    0.0%
  4. I installed a 1 piece drive shaft to make the problem go away
    0 vote(s)
    0.0%
  5. I installed some combo of the above to make the problem go away
    0 vote(s)
    0.0%
  6. Some other option not listed fixed your vibrations
    1 vote(s)
    6.7%
  7. I scratch and sniff my taint
    5 vote(s)
    33.3%
  1. Feb 5, 2010 at 4:00 PM
    DrRabbitFurHead
    DrRabbitFurHead [OP] Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    I'm trying to see how many people have had issues lifting their double cab short beds. Please let me know your experience so I can determine if I want to spend a little more money right now. :D
  2. Feb 5, 2010 at 8:15 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    it varies from truck to truck. a cb drop fixed mine, but you can also unbolt your cb bearing and flip it over and it will drop it a bit. I did not know that but the guys at Je Reel driveline were telling me this. worked for me but i have a little more than 2.75" lift.:eek:
  3. Feb 5, 2010 at 8:54 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    i'll say! looks fantastic!!!! how high up are you?
  4. Feb 5, 2010 at 9:27 PM
    bajamoon
    STEVE
    Whittier
    ^^^uuummmm not sure, 4-5" i guess.:eek:
  5. Feb 8, 2010 at 10:38 AM
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    13 Taco Double Cab TRD
    Bilstein 5100's all around, front set at 2.5", Toytec AAL, 265/75/16 Duratracs, Pro Comp 5001, Weathertech's, AVS In Channel Visors, Nokya Hyper Yellow fogs, CB Set up, Color matched grill surround, ATC Camper Shell with Yakima Racks, SOS Concepts Regular Rear Bumper.
    You should add a option to the poll " I still have vibrations and I have installed a diff drop and a carrier bearing drop and have taken each out seperately to try and solve."
    I have the above set up, 5100's at 2.5.
  6. Feb 8, 2010 at 10:42 AM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    Same here, sort of. I'm a prerunner so I didn't need a differential drop, but I do have a carrier bearing drop and 3 degree shims and I have the slightest vibes from 5-10 mph and again at 20-25mph. I have to accelerate really slow to feel them and under normal acceleration i don't feel it. At some point, I will switch to a 1 piece driveshaft.
