DID YOU KNOW: 2nd Gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BrokenTusk, Apr 7, 2012.
  1. Apr 7, 2012 at 5:49 AM
    BrokenTusk
    BrokenTusk [OP] I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Figured, we sometimes breakdown, in shitty places. What are some unorthadox ways you've saved yourselves?? Chrome wont get ya home, but knowledge might! :D
    In case of Belt blowing on side of the highway emergancies, and your stranded with a spare belt but no tools, your tire iron can be wedged between the tensioner pulley and the lower right one and you can move the tensioner to replace the belt.
    Ask me how I know.
  2. Apr 7, 2012 at 5:55 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    :rolleyes: :cool:
    Contribute or GTFO :D
  3. Apr 7, 2012 at 7:10 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    There is a coolant line right top center near the main coolant return hose from the Radiator:
    It loops to a connection underneath and behind it about 8 inches worth of hosing away. If your belt blows, there is a rare potential of it taking out this line in the process as the stock clips aren't very heavy duty. You can take the hosing from your windshield washer system, and use it as a temp replacement, zip tieing the ends down, to hold pressure. I refilled my lost coolant and it held under pressure for a few hours till I could get to a car parts store to replace it.
  4. Apr 7, 2012 at 3:16 PM
    sytfu510
    sytfu510 INSTAGRAM: sytfu510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit DMZ LT Kit TRD Supercharger SCS Wheels BAMF
    knowing is half the battle. Thanks for the tip, hope I never need to remember this.
  5. Apr 7, 2012 at 5:33 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    03 F250 CCSB
    Gibson stainless headers, custom free-flow Y-pipe, Magnaflow muffler, 285/75R16 KBro2's
    If you pop the bead on your tire and have a can of starting fluid, squirt some fluid into the seam and light it with a match. The secret to not killing yourself with this one is to go easy on the starting fluid. I've seen a video where the people almost blow themselves up in the process. I've used this trick on our backhoe and it does work.
  6. Apr 7, 2012 at 6:02 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    We used to do the same thing working at a tire shop when I was a teen.
    Helpful tip to people doing that, IT DOESN"T TAKE MUCH.
    Remember, if you used too little, nothings harmed and you can just do it again with a little more, if you use too much, then your fubar'd.
