Did your door ever pop open when driving?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by maxmk8, Sep 11, 2021.
  1. Sep 11, 2021 at 10:09 AM
    maxmk8
    maxmk8 [OP] Well-Known Member
    2022 Electric Lime M/T Taco
    Well sure, I had plenty of instances since I don’t like slamming doors, of the doors not fully latching, especially when it’s the last one being shut. But it is very obvious from the getgo and sets off the door alarm and causes obvious noise due to not being latched. My situation was not like that.
    I must have closed the door 1000 times 900 of which it was fully shut, 99 of which id open and close again. The 1 incident was quite dangerous and generated this thread.
    I’m not incapable of operating a car door.
    Hope this helps others and just keep em more vigilant.
  2. Sep 11, 2021 at 10:22 AM
    jakbakcrak
    jakbakcrak Well-Known Member
    Jack
    2020 Quicksand TRD Off Road Tacoma
    Several aesthetic
    poltergeist...100% sure
  3. Sep 11, 2021 at 10:24 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Incorrect at least as far as my Utility package goes, the molded back cover is over the vents (there is a narrow gap at the bottom to let air flow through the vents). And the testing I did (see above) proves doors and windows closed does make a difference. I also don’t think trucks with the vents exposed are going to let enough air pass through quickly enough to overcome the back pressure from a door swinging closed. They can help but no way that small vent area totally can instantly overcome the area and volume of a door closing. But you can do your own testing. ;)
    Not an expert but from what I’ve read the rear vents are for equalizing pressure in the cab, whether a pressure increase is due to AC or fan drawing in outside air, door closing, etc. It’s just not going to be able to do it fast enough to totally get rid of the spike in pressure as a door closes with all other doors and windows closed.
  4. Sep 11, 2021 at 11:02 AM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    davidstacoma[QUOTED] likes this.
  5. Sep 11, 2021 at 11:03 AM
    davidstacoma
    David
    NC
    :rofl:
    “But I’ve never heard of any vehicle having a door issue in my life.”
    That’s an “any vehicle” link lol.
    LivinOnEdge[QUOTED] likes this.
  6. Sep 11, 2021 at 11:09 AM
    LivinOnEdge
    Land of The Lost
    Touché
  7. Sep 11, 2021 at 11:10 AM
    davidstacoma
    David
    NC
    It does sound like you had an unusual problem there. If you can’t get the problem to repeat yourself then I doubt the dealer will be able to and likely to just blow it off unfortunately.
  8. Sep 11, 2021 at 11:40 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Check your door alignment to the striker . Mine was off from factory and needed adjustment .issue I had was difficult to close .
    shakerhood likes this.
  9. Sep 11, 2021 at 12:14 PM
    Greene368
    Greene368 Well-Known Member
    Metro Atlanta, GA
    2021 Toyota Tacoma TRD Sport 4X4 Predator, Black
    I know my driver's door is hard to close. Always requires a hard slam. Probably isn't adjusted correctly. I thought it would get better with use, but it hasn't so far. I figured I'd take it in whenever I get my 5000 mile service.
  10. Sep 11, 2021 at 12:17 PM
    davidstacoma
    David
    NC
    Try this. Lower the passenger side window before you close your door, you’ll notice how much easier it is to close. Not that you should do this every time, just so you see why it’s harder to close with all the other windows and doors closed.
    Greene368[QUOTED] and zoo truck like this.
  11. Sep 11, 2021 at 1:28 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    My door are still pretty tight where i have to give them a good slam to make sure their closed. Sometimes they cause my ears to pop. If anything when i rest my arm on the center arm console the lid keeps making a clicking sound every time more pressure is applied to it like its opening, and latching shut again. Its probably my biggest beef with this truck.
    davidstacoma likes this.
  12. Sep 11, 2021 at 1:31 PM
    davidstacoma
    David
    NC
    If that’s your biggest beef you’ve got a damned good truck, right? :D
    zoo truck[QUOTED] and shakerhood like this.
  13. Sep 11, 2021 at 2:00 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Despite the cab vents, the last door to close will always be a little harder than the rest.
    Unless, of course there's a window rolled down.
    My wife is perpetually the last one to shut a door, and I swear it takes her two goes at it 90% of the time.
  14. Sep 11, 2021 at 2:45 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    My testing is closing my door with my pinky finger. Y’all must have some defective trucks
  15. Sep 11, 2021 at 3:02 PM
    #35
    C-Rok275
    C-Rok275 Well-Known Member
    2017 TRD Pro
    6112/5160s with Icon stage 2 leaf’s.
    I had a 92 Eagle Summit and the door popped open once. I guess I hit a bump just right, and the driver door opened right up. Worst part was it had automatic seatbelts, so that started coming off of me when it happened.
  16. Sep 11, 2021 at 5:36 PM
    #36
    Greene368
    Metro Atlanta, GA
    I tried it. You're right. MUCH better! I have never had that happen with any other vehicle I've owned. Live and learn! Thanks for that trick!
  17. Sep 11, 2021 at 7:10 PM
    #37
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    Yes. My access cabs Passenger door popped but latch caught it. I was making a left turn. This was when the truck was newer and the doors still had to be closed fairly briskly as they hadn’t “worn in” yet. Must have not quite closed correctly the last time I opened it but it hasn’t happened since. Truck went apeshit with the beeping which was far more startling than the door lol.
  18. Sep 11, 2021 at 7:20 PM
    #38
    jmneill
    SE
    ^LOL
    Reminds me of a girlfriend's Hyundai back in the day with the auto belts, only the car would close the belts on you when you opened the doors and unbelt you when you closed them. :rofl:
    South Korean auto manufacturing has come a long way since the 90's.
  19. Sep 11, 2021 at 7:46 PM
    #39
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    The vents are there primarily for pressure equalization. If the car was sealed and parked in the hot sun the expanding gases would have no where to go.
    The vents are not designed to displace enough air to equal the volume of air the door introduces. There is no way to calculate for that. It would depend on the weather that day, wind entering the car, how fast the door was closed, objects in the car, etc.
    The door in this situation must have been just shy of full close. I do not see anyway a fully engaged latch would fail. In 20 plus years of inspecting wrecked cars I had never seen a door popped open in an accident. The door would have to have been ripped off and latch destroyed before it failed.
    Scary situation glad everyone is ok.
  20. Sep 12, 2021 at 11:33 AM
    #40
    maxmk8
    Well thankfully the door was held by the secondary latch, after which the air resistance is hard to overcome also.
    that said … a tight right turn no seatbelt and sub 20mph would be quite scary if this was to happen.
    Mastiffsrule[QUOTED] likes this.
