Did your fan belts suddenly break?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Caslon, Feb 10, 2023.
  1. Feb 10, 2023 at 9:49 PM
    Caslon
    Caslon [OP] Well-Known Member
    2003 Base Cab. 2 whl drive. 5 speed
    120k now. Belts don’t look frayed to me, but 5k ago a mechanic dutifully pointed out some fraying, but how much seems to me questionable. Damn, I don’t notice it. The idler wheel starting to squeal now , but only for a few seconds on startup. The belts were probably replaced when I bought this truck “certified” from a Toyota used car dealership at 59k. Should the idler wheel squeak and mileage driven since be a major wake-up call? I’m on a super low income budget. Can I get by longer, or is roadside assistance in my future? No tools to do it myself.
    Bivouac likes this.
  2. Feb 10, 2023 at 10:03 PM
    02hilux
    Planet: EARTH
    Put a new belt on and call it good.
    tinker_troy and Superdave1.0 like this.
  3. Feb 10, 2023 at 10:19 PM
    Caslon
    Wish I had the financial resources to take care of every potential crisis. I don’t. I’d rather hear from those who a mechanic said he sees some belt “fraying” 30k ago and it’s now 30k later. Get it? What about idler pulleys and now momentary squeaking at start up? They probably can’t be lubricated. Signed…destitute Tacoma faithful.
  4. Feb 10, 2023 at 10:30 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    If you can't afford a belt, then I'd hate ask what you will do if your vehicle broke down at all for anything else.
    As for your belt fraying, you would actually look for cracking.
    TACOTU3, b_r_o, Cucvfan and 3 others like this.
  5. Feb 10, 2023 at 10:43 PM
    Caslon
    Can’t say thanks enough!
  6. Feb 10, 2023 at 10:57 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just noticed you stated you don't have the tools to work on it; bring it down and we'll get new belts swapped in place in no time.
  7. Feb 10, 2023 at 10:58 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Where are you located? If you can't afford a belt replacement that's rough. I'd hook you up on the labor. Just bring the parts over.
    Also unless you live in the complete boonies, you can take up doordash or uber eats for a little side cash. I've seen disabled people doing it for extra money.
  8. Feb 10, 2023 at 11:03 PM
    HIYota
    HIYota Well-Known Member
    Angel
    Las Vegas, NV originally Kauai, HI
    09 Silver 6 spd TRD Sport DCSB 4x4
    Check my build thread...too much to list.
    I’ll give you the life lesson I learned. One of my idler pulleys broke and tore the belt as well. I replaced only the broken parts not thinking anymore about it. A year later a different pulley broke, destroyed the belt causing it to wrap around more pulleys and my crank pulley and ruining the crank seal. Ended up costing me more money but luckily I could fix all that myself. Preventative maintenance 99% of the time will be cheaper than reacting to things breaking. If you can’t afford to pay someone I suggest learning because maintaining a vehicle is just one of those things that comes along with owning a car.
    koenbro, Nessal and Superdave1.0 like this.
  9. Feb 11, 2023 at 12:17 AM
    JustADriver
    JustADriver Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    How did you determine that it's the idler pulley squeaking and not the fault of the belt, another pulley, misalignment, or belt tension?
  10. Feb 11, 2023 at 1:39 AM
    02hilux
    Planet: EARTH
    Your betting on that Toyota changed all the belts when you bought the truck "certified" from them at 59k miles? Highly unlikely, they go through a multi-point inspection and hit the used sales lot right away. You got 120k miles out of them so far and if you're still refusing to change them with associated parts, yes, stranded is in your future. Hopefully your 2wd 5-lug is a 2rz/3rz and not a timing belt driven 5vz cause you'll run into more issue, thus equal more $$
  11. Feb 11, 2023 at 1:50 AM
    02hilux
    Planet: EARTH
    Check for cracking is one thing. The inspection will vary base on every individual. One person will say yes, you have to get that change right away and shouldn't wait while another will say I'll change it when it break. I would definitely do PM on a 20 y/o belt among other things regardless. Especially the water pump. A few hundred buck now is 2-5x cheaper than an engine replacement down the road.
  12. Feb 11, 2023 at 1:56 AM
    02hilux
    Planet: EARTH
    Sweet, I'll bring you my truck to work on. You're not too far from me and I have a laundry list of things that I want done :rofl:
    LBJ is #1 on my list :D
    Horn gasket is #2 o_O
    Struts change is #3 :thumbsup:
    :fingerscrossed:
    Kwikvette[QUOTED] likes this.
  13. Feb 11, 2023 at 5:17 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    If you were close no big deal I have no problem helping those with issues not allowing them to work on their own vehicles.
    A few hours work though it would be nice know just what vehicle since it has Struts I changed a few over the years .
    02hilux[QUOTED] likes this.
  14. Feb 11, 2023 at 5:26 AM
    Bivouac
    I have learned not to mess around with serpentine belts 2 on company trucks let me sit .
    Not my Bill the alternator seized took out the belt.
    Belts can be tricky some look likely to fail at any minute last for sometime.
    I always carried the Alternator Water pump/fan belt and means to change it that will get me home.
    I only ever had one fail while driving on my vehicle when I was a young kid.
  15. Feb 11, 2023 at 6:20 AM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    I had an AC belt that only made noise when the AC compressor clutch was engaged. The belt felt a little stiff but looked fine, no cracks or fraying but it made a hell of a racket when the AC was on.
    Replacing belts should be part of routine maintenance no matter how good they look.
  16. Feb 11, 2023 at 6:43 AM
    02hilux
    Planet: EARTH
    Mod Day.... :thumbsup:
  17. Feb 11, 2023 at 7:19 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Of course.
    Me, I'm just about that preventative maintenance -
    Bivouac, b_r_o and 02hilux[QUOTED] like this.
  18. Feb 11, 2023 at 7:21 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    OH we can replace our LBJ same time!
    I just did my horn gasket and headlight fluid so I'm hI good there
    Strut not for another 60k km :laughing:
    Bivouac likes this.
  19. Feb 11, 2023 at 7:41 AM
    Bivouac
    Being in California I guess you don`t need the Winter blend Headlight fluid good to - 50F or need the auxiliary headlight heaters.
    Kwikvette[QUOTED] and Kevins60 like this.
  20. Feb 11, 2023 at 8:07 AM
    Caslon
    As the original poster, didn’t mean to cause a stir. Although the belts have mileage on them, I truly don’t see what the guy is talking about. Hehe, the belts show no obvious cracking. Yes they got 50k on them, but they are quality belts. The monetary squeaking seems to be coming from the idler pulley. Does that need immediate attention? Seems every mechanic recccomends changing the belts when they look as if they have 50K left on them. “Change the belts! change the belts! 60K later.doing fine.
