Didgeridoo: Anyone here play one?
Discussion in 'Entertainment' started by David K, Jan 15, 2011.
Thread Status:
Not open for further replies.
  1. Jan 18, 2011 at 7:39 AM
    Titan
    Titan Well-Known Member
    Joel
    Sheboygan, WI
    07 TRD Sport DC-LB
    OME Lift Kit
    one of my buddies brought over a video about didg playing last weekend, we couldn't watch it because, well, who has a VHS player that works anymore?
    anyways, he's a little obsessed about it but doesn't have one and has never tried to play so after doing some reasearch here http://www.didjshop.com/physicsDidj.html
    I made 2 PVC didges last night, one tuned to C (52") and a longer one tuned to G (69") (supposedly a C and G will work hormoniously assuming we don't both entirely suck at this and cause neighborhood animals to go berserk :D)
    I've got a pretty good drone going so far, hopefully he can get his going as well, my wife will probably shoot us LOL
  2. Jan 18, 2011 at 8:22 AM
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Thanks Judy!
  3. Jan 18, 2011 at 8:34 AM
    David K
    I have some pieces of PVC pipe in my garage (I am an irrigation installer), and one of them is an 1 1/2" PVC at 57" long... makes a good sound. The other I have played with is a 1" pipe at 50" long... to which I added a coupling on the end for a mouth piece (the pipe without a coupling is too small).
    I also have a 2" pipe which is the same diameter as the didgeridoos we got for Christmas. We bought a block of bees wax from the hobby shop to modify our mouth pieces on the didges and to add one to the PVC pipe. I can play the 1 1/2" and 1" PVC without the wax.
    Practice, practice, practice...
  4. Jan 18, 2011 at 8:39 AM
    Titan
    Joel
    Sheboygan, WI
    07 TRD Sport DC-LB
    OME Lift Kit
    I find it interesting that you needed to increase the diameter in order to play the 1"
    My PVC is 2" and I currently have a 2>1-1/2" and 1-1/2">1" and 1">3/4" reducers to make it small enough to get me started, I can play the 3/4" or the 1" but the larger pieces without these adapters have me stumped so far
    I'm currently playing with only one side of my lips also, can't get the whole mouth to buzz yet
  5. Jan 18, 2011 at 8:54 AM
    David K
    Adding a coupling to the end of the 1" pipe made droning much easier. The 1 1/2" pipe I can make the drone easily without anything on the pipe... but will add a ring of bees wax to make it more comfortable. The 2" pipe has to have a reducer or wax mouthpiece...
    I am sure we all have different mouthes and lips... so that will play into what size opening on the end of the pipe will work.
    I played with the didge (the bamboo one) for a couple weeks before I figured out how to make the drone. Reserve the air that you let out... it isn't a volume of air that makes the sound like a trumpet needs, it is the lips vibrating... I use my teeth to channel the air to get the drone started. Bottom teeth against top lip when mouth is in didge and ever so gently blow through/ over bottom teeth.... real gently... then you get the vibration that produces the low drone... and using so little air, you can make it last 10 seconds. The goal is 20 with practice and exercising our lungs! Perhaps that is just how it works for me... but it worked.
    It is a thrill to get the drone the first time after you begin to wonder how they do it!
  6. Jan 18, 2011 at 9:00 AM
    CB6979
    CB6979 Active Member
    Mason, OH
    06 Tacoma SR5
    Tinted Tail Lights, De-Badged, Murdered Grill and Rear Bumper, DVD Head Unit, Tinted Windows. More to come when $$$ allows
  7. Jan 18, 2011 at 9:15 AM
    Titan
    Joel
    Sheboygan, WI
    07 TRD Sport DC-LB
    OME Lift Kit
    Sweet, I'm doing pretty good then, I only played for like 20 min before I started getting it, there was a lot of terrible noises in the process and then *BOOM* I hit the perfect frequency and it sounded like a didgeridoo, it was really exciting
  8. Jan 18, 2011 at 9:18 AM
    Paul's TRD
    Paul's TRD I'm Not Your F***ing Brother
    TX
    2011 Z71 4x4 5.3L V8
    I'm suprised how many people here actually have a didgeridoo. I don't have one. I play the harmmonica decent enough, but only for amusement, but reading this makes me want to get a didge myself. Sounds fun. When I go camping, I always have my harmonica, of course (stereotypical), but how cool would it be to have a didge while camping.
  9. Jan 18, 2011 at 9:23 AM
    Titan
    Joel
    Sheboygan, WI
    07 TRD Sport DC-LB
    OME Lift Kit
    I paid $10.03 for both of mine at the hardware store last night, it involved 2 cuts a little trimming with an exacto knife and zero pvc gluing, it's super easy
    I'll post some pics late tonight when I'm home so everyone can see how I pieced mine together
    and if you decide you hate it, replace some plumbing in the house LOL
  10. Jan 18, 2011 at 10:13 AM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    For you folks with smaller lips, it's easier to play with one side and a smaller opening (I quote what my buddy said). As for people with larger lips, like me, the opening feels better when it's larger letting you fit most of your lips into the opening making the drone easier to do.
  11. Jan 18, 2011 at 10:56 AM
    Titan
    Joel
    Sheboygan, WI
    07 TRD Sport DC-LB
    OME Lift Kit
    I assume it is incorrect to only use 1/2 of your lips and it will eventually stall my progress, I learned this technique from a guy who plays a conch shell, apparently those and didges are very similar, using lip vibration
  12. Jan 18, 2011 at 11:00 AM
    Paul's TRD
    TX
    Interestingly enough, as soon I got off this thread, I started looking at different options for didges, and I think I would like to make my own. I'm pretty good with the hands and tons of patience. I think i have project coming up.
  13. Jan 18, 2011 at 11:26 AM
    Titan
    Joel
    Sheboygan, WI
    07 TRD Sport DC-LB
    OME Lift Kit
    well it seems this has become kindof a hot topic today....
    here's the website with the parts list I used to make mine http://www.subatomicglue.com/didjl0g/index.php
    some interesting dimensions, when discussing mouthpieces above, the ID of fittings vs. pipes is a little misleading
    a 1-1/2" pipe that David K is playing without wax has an ID of 1.590"
    this is close to the ID of the fitting I am using 1/2 my lips on, the 1-1/2">1" fitting's ID is 1.315" on the 1" side
    the 2">1-1/2" fittings ID seems too big at 1.900" even using my whole mouth
    Maybe I'll pick up a 1-1/2">1-1/4" fitting tonight (1.660" ID) and try that
    can you guys post the ID of your mouthpiece for me?
  14. Jan 18, 2011 at 2:23 PM
    David K
    Actually, I am using sch. 40 PVC and the size of the pipe (all types are based on the inside diameter of sch. 40) is right on 1.5 inches. Thinner wall PVC (Class 200 for example) is bigger on the inside... all are the same on the outside so they all can use standard sch. 40 or sch. 80 fittings.
    However, whatever the size... it is great to raise some interest here... Something new to discuss other than A-TRAC and 4 wheeling in Baja!
    I hope we can help each other master the circular breathing... that is the key to keeping interested in this, I think!
    Right now, I am able to do rapid puffs of air with my cheeks while breathing in and out through my nose. But, these 'cheek puffs' are not (yet) able to make the drone. Am I on the right track, you think?
  15. Jan 18, 2011 at 2:36 PM
    #35
    David K
  16. Jan 19, 2011 at 7:18 AM
    #36
    Titan
    Joel
    Sheboygan, WI
    07 TRD Sport DC-LB
    OME Lift Kit
    you're correct about the ID of pipe, but I'm talking about the ID of fittings which is actually the OD of the pipes
    here's a good reference for people making didges out of PVC http://www.harvel.com/pipepvc-sch40-80-dim.asp
    I use this chart very frequently, I also make a lot of spud guns, DIY super soakers and nerf type weaponry :D
    I did pick up the 1-1/2"> 1-1/4" reducer last night and I can't quite get a seal on it to get the whole didge to properly vibrate using my whole mouth, I think it will be perfect after I add a ring of wax though
    I think using the smaller 1" or 3/4" adapters to use 1/2 my mouth will impede my ability to make different sounds between drones so I want to get this working the right way
  17. Jan 19, 2011 at 8:19 AM
    #37
    David K
    Great to hear of your projects!
    Yes, get a 1 1/2" to 1" reducer bushing to fit in your 1 1/2" coupling if the 1 1/4" is too big... However, with practice I think you will be able to make the drone on different sizes.
    The opening on the end of my bamboo didge is just over 1", made with the wax ring.
    I hope some other Tacomans play a didge and can share their techniques...
  18. Jan 19, 2011 at 10:00 AM
    #38
    Titan
    Joel
    Sheboygan, WI
    07 TRD Sport DC-LB
    OME Lift Kit
  19. Jan 19, 2011 at 5:20 PM
    #39
    Titan
    Joel
    Sheboygan, WI
    07 TRD Sport DC-LB
    OME Lift Kit
    wax mouthpiece and cut down to a "B" 55" = WIN
  20. Jan 19, 2011 at 5:47 PM
    #40
    David K
Thread Status:
