Didn't get enough lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Yoda910, Jul 4, 2023.
  1. Jul 4, 2023 at 7:22 PM
    Yoda910
    Yoda910 [OP] Active Member
    2018 SR5
    None
    Hey yall! I installed 3 inch iron man lift but I didn't get enough lift in the back, only about 2 inches. Is there anyways to add a little in the back? If so what are the best options? Ty
    Blackmanic likes this.
  2. Jul 4, 2023 at 7:34 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    A new leaf pack might do it. Maybe not though since 3” is already a lot higher than stock.
    Chew likes this.
  3. Jul 4, 2023 at 7:36 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    What was included in the package to achieve lift in the rear?
    eurowner and Chew like this.
  4. Jul 4, 2023 at 8:11 PM
    Clearwater Bill
    Billy
    Largo Florida
    'feel'?
    A tape measure might be helpful. Or did you not take 'before' measurements?
    Mark77, Junkhead and Chew like this.
  5. Jul 4, 2023 at 8:13 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    When she says "3 inches isn't enough" :bananadead:
  6. Jul 4, 2023 at 8:16 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Good question. Did your lift kit come with a leaf pack or blocks? Anything? Or just rear shocks?
    from what most people say, the iron man rear leaf pack lifts the truck more then 3”
  7. Jul 4, 2023 at 9:24 PM
    Blackmanic
    Blackmanic Member
    Adrien
    2022 tacoma trd offroad
    Basics so far, led lights, plug and play dashcam, console vault, bed mat.
    I just recently did the standard bilstein 5100 lift with emu springs and rear aal from icon.. "I still needed a 1 inch block in rear"---is what SHE said.
    bkhlrTaco's and Yoda910[OP] like this.
  8. Jul 5, 2023 at 6:05 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Ironman doesn't sell blocks. What leaf pack did you get...they sell two. If you got the heavy load (+440lb constant load) leafs, you can get an add-a-leaf from them for like $80 and install it between the overload springs and the leaf pack. This will bring your total leafs to 8 so you will need to buy the Tundra U-Bolts from them as well. If you got the medium load (+0-440lbs load) leafs, you can either get the heavy load or add a leaf to them as well.
    Yoda910[OP] likes this.
  9. Jul 5, 2023 at 6:07 AM
    Yoda910
    2018 SR5
    None
    I got the medium lift and I did measure before and after and only got 2 inches in the rear. My bad on the info. Came with leafs and new shocks.
    pahaf likes this.
  10. Jul 5, 2023 at 6:10 AM
    Yoda910
    2018 SR5
    None
    Exactly the answer I was looking for. Thank you.
    pahaf likes this.
  11. Jul 5, 2023 at 6:13 AM
    airforceb2cc
    Don
    KCMO
    No problem. Also note, they had a recall on the UCA ball joints...so if you bought your lift a few months ago, might need to check into that.
  12. Jul 5, 2023 at 6:22 AM
    Yoda910
    2018 SR5
    None
    Damn didn't hear about that. Bought it about 4 months ago. I'll check
  13. Jul 5, 2023 at 6:28 AM
    LiquidArrogance
    LiquidArrogance Well-Known Member
    Streets of Bakersfield
    2021 SSM Sport 4x4
    They're being clowns about the whole thing. In Aus they recalled every proforge UCA made in the past four years. Stateside they're pretty much just telling us all not to worry about it. Doesn't make any sense.
    https://www.ironman4x4.com/recall/
  14. Jul 5, 2023 at 6:29 AM
    airforceb2cc
    Don
    KCMO
    Who told you not to worry about it in the states? I contacted them and they took good care of me.
  15. Jul 5, 2023 at 6:32 AM
    Yoda910
    2018 SR5
    None
    Wonder how many failures they've had? Seems like it could be a dangerous situation or is this just a precaution? I'm on a road trip in Outer banks and now I'm worried a little lol
  16. Jul 5, 2023 at 6:33 AM
    LiquidArrogance
    2021 SSM Sport 4x4
    That's good to hear. I had an excellent experience when I installed my kit a few years ago. I got a bad batch of leaf springs with bolts installed backwards. Gouged a nasty gash in my fuel tank and they covered entire cost of replacement.
    Was hoping for a similar response on this. I contacted them last week and still haven't gotten a response. Will try again.
    Have seen several screenshots of people in the states who have gotten replies from them saying the recall doesn't cover USA products.
  17. Jul 5, 2023 at 6:43 AM
    airforceb2cc
    Don
    KCMO
    I was on Rimrocker trail when mine gave out. It was still holding together but was super loose. Managed to limp it to Moab to change it. You can check yours pretty easily...grab the top of the spindle just below the ball joint and pull outwards...see if it moves.
    Yoda910[QUOTED][OP] likes this.
  18. Jul 5, 2023 at 6:45 AM
    airforceb2cc
    Don
    KCMO
    Call them, don't message or email. If you can get Bubba, he will take care of you right then and there. John takes a little longer to get things going.
  19. Jul 5, 2023 at 6:47 AM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    If it was me I'd look into a 1", 2° tapered block. That 2° will help with driveshaft angles and the 1" block won't hurt the ride.
  20. Jul 5, 2023 at 6:50 AM
    LiquidArrogance
    2021 SSM Sport 4x4
    Right on I appreciate the heads up. I've worked in government for too long and operate under the "of it ain't written down it didn't happen" philosophy... So I usually avoid phone calls.
