dies after warming up starts after it cools
Discussion in '1st Gen. Tacomas (1995-2004)' started by welderwoman, Sep 17, 2011.
  1. Sep 17, 2011 at 2:20 PM
    welderwoman
    welderwoman [OP] New Member
    Tacoma, WA
    01- 2.7 ltr
    What would cause my 2001 toyota tacoma to stop running after it warms up. It will go about 5 miles and die. I just had extensive engine work done, replaced valves, new plugs and coil packs and a new catalytic converter.:confused:
    cleaned my maf, now what?
  2. Sep 17, 2011 at 2:25 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    always start at the beginning. Check to see if it is the spark or the fuel that is failing when the engine dies. Perform diagnostic from there.
  3. Sep 17, 2011 at 2:39 PM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    This absolutely
