Dies and won’t start back
Discussion in '1st Gen. Tacomas (1995-2004)' started by yotaBox86, Jan 7, 2023.
  1. Jan 7, 2023 at 5:03 PM
    yotaBox86
    yotaBox86 [OP] Member
    Justin
    1997 Toyota Tacoma 2.7L 4x4
    I have a 97 Tacoma 2.7L. After driving for a few hrs it starts sputtering the temp gauge goes too hot (it’s not running hot) and it dies. Right after it will spin over but not crank. Then after a few mins it will start again. I have checked relays fuses changed temp sensor. It has fuel psi. Any suggestions?
  2. Jan 7, 2023 at 6:30 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Welcome to the forum!
    Any codes tripped?
    A few hours? High speed interstate? Local stop and go city driving ?
    A few minutes 2 or 5 or 10 or more?
    Check your ecm ground.
    EFI relay Circuit Opening relay How did you check your relays? They were checked when the truck would not start?
    Fuel pump? The pressure was checked while cranking at the time of a no start condition?
    Heat related electrical issue.
    Best of Luck!
  3. Jan 8, 2023 at 6:30 PM
    yotaBox86
    Justin
    Only code shown are 02 sensors bc cat has been cut out.
    driving around in hunting club checking traps. Drive for 5 min cut truck off for 10min drive to next trap location and so on.
    I swapped efi relay with taillight relay. Taillights work after swapping.
    I loosened fuel line on fuel filter and turned key over to crank. Fuel sprayed. Also when truck won’t crank you can’t hear pump when turning key on. But pump comes on for about 2 seconds after shutting key back off.
    When temp gauge is showing hot the engine is not overheating.
  4. Jan 8, 2023 at 7:08 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Like he said....something electrical and hot.....
    I would search everything from coils back to battery.....
    grounds and battery are easiest to test.....
    In the middle of all that is an ignition switch.....thats a problem spot....
    nothin lasts forever.....even aisin...
  5. Jan 9, 2023 at 4:42 AM
    yotaBox86
    Justin
    So this morning it’s throwing 1310 and 1300 so is that gonna be coils?
  6. Jan 9, 2023 at 1:39 PM
    Bivouac
    #1 and #3 It is a igniter circuit problem
    It can be anything in the circuit not just the coil/igniter .
  7. Jan 10, 2023 at 6:11 AM
    yotaBox86
    Justin
    I have changed both coils, went ahead and changed plugs and wires, EFI relay and Put a new fuel pump on. It is still doing the same thing. At an idle it misfires about every 3 minutes for about 5 seconds. When misfiring the temp sensor pegs out. When going down the rd after about 5 miles it misfires loses power and dies with temp sensor pegged on hot. What else is on the circuit?
    in doing all this I realized the thermostat was not opening. Top radiator hose warm lower hose cold. Changed thermostat and still not circulating. ???
  8. Jan 10, 2023 at 9:59 AM
    yotaBox86
    Justin
    Ok update!! After 300$ + in parts I sprayed the MAF sensor with break cleaner and problem solved. No misfiring!! Thank y’all for the help!!
  9. Jan 10, 2023 at 10:05 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Get ready to buy a new MAF Sensor, cause you just gave that one a death sentence :facepalm:
    1997tacomav6, JasonLee and Bivouac like this.
  10. Jan 10, 2023 at 11:52 AM
    Bivouac
    How often do we tell people just use a dedicated MAF sensor cleaner!!:frusty:
    OP that still does not explain the temperature gauge problem or the fact none of the MAF sensors codes did not trip as well.
    I just hope the OP does not get stuck in the worse possible location.:fingerscrossed:
  11. Jan 10, 2023 at 5:54 PM
    O'Silver_Taco
    MD
    Yeah I keep a backup maf sensor under passenger seat......
    its pretty damn important....and the non oem ones are a crap shoot.....
    delphi .......my ass........
  12. Jan 10, 2023 at 6:00 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    RIP.
    Bivouac likes this.
  13. Jan 10, 2023 at 7:10 PM
    ArizonaBrian
    ArizonaBrian Well-Known Member
    That maf sensor will be fine for a long time to come.
