Diesel finally coming in 3rd gen ....
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PROseur, Dec 10, 2017.
  1. Oct 3, 2018 at 4:47 PM
    #341
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Ya oil changes are a bit more. My 06 Jetta TDI oil changes are around $110CAD
    Think the taco is around $65?
    And on the towing note it's not all about power but how the frame is etc.
    So the capacity might be close due to braking, frame etc but how the engine handles towing that will be significantly different.
    Tow a 5th wheel with a hemi then Cummins you'd notice a huge difference in acceleration and what not.
    shakerhood likes this.
  2. Oct 3, 2018 at 4:49 PM
    #342
    Joe23
    Most diesels don't actually get better mpg in the truck/commercial vehicle aspect .It's just better towing.
  3. Oct 3, 2018 at 4:56 PM
    #343
    tdnick
    tdnick Go Vols!
    Alabamer
    2018 Cummins 4x4
    I manage a fleet of 25 semi’s that run 24/7. Y’all can keep your diesel option.
    Side note: there has been massive improvements in the last couple years but there’s still a lot of issues.
    stun gun, phsycle and Hank Heel like this.
  4. Oct 3, 2018 at 5:00 PM
    #344
    Hank Heel
    Hank Heel Well-Known Member
    WA
    Def/dpf/egr ruins reliability/performance/longevity of diesel cars/trucks
    98tacoma27, RedBeard1 and stun gun like this.
  5. Oct 3, 2018 at 5:34 PM
    #345
    VegasTool
    VegasTool Well-Known Member
    Las Vegas
    2017 TRD OR
    Wow I never knew that
  6. Oct 3, 2018 at 5:47 PM
    #346
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    you always claim OTHERS are the emotionally invested ones. I think you’re projecting. Some of us ACTUALLY deal in diesel. Diesel just won’t compliment the Tacoma, it’s not a better option.
    Joe23 and Hank Heel like this.
  7. Oct 3, 2018 at 5:56 PM
    #347
    stun gun
    Aaronski
    Tacomas.
    I help maintain a fleet of 160 units comprised of Detroit diesel series 60s and DD15s, from DDEC 3 up. EGR to SCR. As well as Cummins and Volvo that take up about 1/3 of the total number. I am completely with you.
  8. Oct 3, 2018 at 6:19 PM
    #348
    SSingh1975
    SSingh1975 Well-Known Member
    Elk Grove, California
    2011 BMW X5 Diesel, 2017 GMC Yukon Denali
    Dunno why all the hate towards diesel Taco. Yall do realize that in other parts of the world Diesel Hilux have been around over 10 years. I've owned/driven my X5 for over 7 years now incl hiking/camping and annual 600miles road trip from Sacramento to Oregon once a year.
    Getting 25mpg on average and still can make it from Sac to Portland, Oregon on a single tank of diesel. On highway, I easily get 30mpg with a lighter foot. It's basically the gas mileage of a 4 cyl with the torque of a V8 engine. I've had some issues with the electronics but the oil burner itself has been trouble free for over 80k miles.
    And out of the 3 trims offered on the X5 back then, the diesel is the LEAST maintenance and highest resale value plus reliability.
    My brother in Aussie has owned 2 gens of diesel Hilux and owns a farm up in the mountains and both are his daily drivers for over 10 years. To each his own, I guess.
    AlabamaBlackSnake and Joe23 like this.
  9. Oct 3, 2018 at 6:20 PM
    #349
    Joe23
    The problem is the diesels made for here are not the same for over there
    specter208 and El Duderino like this.
  10. Oct 3, 2018 at 6:24 PM
    #350
    SSingh1975
    My X5 is made here ...lol. On our bimmerfest forums, there are some diesel owners with over 150k miles without a single issue. Just saying.
  11. Oct 3, 2018 at 6:50 PM
    #351
    Joe23
    Different though .You're talking German diesel.
    I was referring to Hilux btw .
  12. Oct 3, 2018 at 7:01 PM
    #352
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    These emission systems require the use of ultra low sulfur diesel fuel. Diesel fuel that has more sulfur content tends to cause clogging issues with the DPF. This requires more frequent regens to clear the filter. If the system cannot complete a burn off, the DPF may clog putting the vehicle in limp mode.
    The early DEF systems were extremely sensitive to DEF quality...as DEF degrades rapidly in some temperature conditions (or outright freezes in others). GM was having still having occasional DEF issues in many of the LML Dmaxes in 2014.
    I have no experience with the new Mercedes diesels. We looked at the GLK a few years ago - after they had added the DEF systems - and the dealer mechanic told me to run , not walk, away from the idea. Mercedes, BMW, Chevy, Fords and the clean diesel VWs and Audis all ran similar variants of the Bosch CP4.X high pressure fuel pump which was notorious for having cam roller issues directly related to the low lubricity of American diesel fuel. This caused markedly increased failure rates in diesels using this HPFP.
    The problem is that when the HPFP would fail, it would throw shrapnel into the fuel system, destroying various common rail components, including the fuel lines and in some cases the injectors. The average repair bill on the VW TDIs was in the low 5 figures.
    This was a big issue in 2011 and 2012 and my wife's TDI ultimately suffered from it. I stopped following the issue when we sold it back to VW.
    If you're planning on taking that future sprinter to any place that does not have our mandated emission systems, I would recommend staying with a gasser...
    Jaque8[QUOTED] likes this.
  13. Oct 3, 2018 at 7:04 PM
    #353
    skiploder
    FZJ80/XJ LS swap
    The don't have our EPA mandated emissions systems on them. The hate is not towards the diesel per se, but the complex components bolted to it to reduce emissions. The EGR and DPF shorten the life span of these motors and burden the owners with increased maintenance intervals and costs.
    specter208 and stun gun like this.
  14. Oct 3, 2018 at 7:10 PM
    #354
    skiploder
    FZJ80/XJ LS swap
    The DPF and EGR certainly have negative impacts to engine longevity and performance. The DEF is an after treatment and does not impact the longevity of the engine...but admittedly adds maintenance complexity with many early systems being prone to failure.
    Its important to note this because the next wave of diesels will do away with EGR and DPF and focus on less complex after treatment in the exhaust stream. If those new systems prove to be reliable, it could slowly begin to repair the damage done to the reputation of diesel engines over the last ten years.
    specter208 and Hank Heel[QUOTED] like this.
  15. Oct 3, 2018 at 7:15 PM
    #355
    skiploder
    FZJ80/XJ LS swap
    My 2016 Cummins (non -deleted) will get 21 to 22 mpg driving on the highway (from Idaho to Norcal). I get an average of 17.8 mixed. I average about 16 towing our 5th wheel.
    My buddy's tundra gets about 10 mpg towing a much lighter TT. He cannot get close to my highway mpg.
    My old man's 3.5 ecoboost gets about the same as a tundra towing a 27' TT. His highway MPG is about the same as mine. Maybe ever so slightly better.
    AlabamaBlackSnake likes this.
  16. Oct 4, 2018 at 12:10 AM
    #356
    MidCitiesMildMan
    MidCitiesMildMan Well-Known Member
    2017 Toyota Tacoma Limited
    Stock and staying that way
    I get the potential fuel economy gains, but do they result in an actual monetary savings with the generally higher cost of diesel fuel compared to typical 87 octane E10?
    Why haven't those that want a diesel so badly bought the Colorado with it?
    BillsSR5 likes this.
  17. Oct 4, 2018 at 3:02 AM
    #357
    Joe23
    Ya when it comes to towing it's different but otherwise it's not like a massive savings on fuel like some think.
    Some seem to think diesel means they'll be getting 35+mpg
  18. Oct 4, 2018 at 5:45 AM
    #358
    skiploder
    FZJ80/XJ LS swap
    Well, in passenger cars, 35 mpg+ in a diesel is very real. But I agree, not in HD or light duty trucks. Mold 5.9 cummins with no smog on it could barely get 23 going downhill with a tailwind.
    Let's do a fun comparison. Here's two pictures from my 2016 Ram Cummins Crew Cab 4x4. One is the current tank of fuel (18.7 MPG). The other is the last 12,034 miles (18.2 MPG). My hand calc numbers are slightly higher.
    Type of miles is a mix. My commute is 23 miles one way. In the morning, no traffic. Coming home, stop and go. There a re couple of long trips in those past 12K miles, some running around town and some serious idling.
    Diesel fuel where I live can vary in cost. Some months it's the cost of 87 octane, other months 89.
    Now if I go to Fuelly and search on the 2018 Ford F150 Crew Cab with the 3.5L Eco-Boost , the average MPG I'm getting is 16.8 MPG. In 2016 and 2017 it's showing 16.2.
    So, yes, diesel numbers are not dramatically higher. But comparing displacement (6.7 vs 3.5), horsepower ( 385 vs. 375) and torque (900 vs 470), I'd say that there are still advantages. I mean, shit, when a HD truck weighing 7400 pounds can get better fuel economy than a light duty truck weighing 4900 pounds I'd say that's pretty remarkable.
    Jaque8 and 98tacoma27 like this.
  19. Oct 4, 2018 at 7:41 AM
    #359
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    not as easy to work on as a gas powered Toyota, spark plugs every 30k miles,oil change every 10k miles, brake shoes that will last 70k miles with easy replace for the front pads pull 4 pins ur done, and it runs on cheaper widely available gas, and best of all they start right up when the temp dips below freezing. without putting additives in the gas tank or an engine block heater to plug/unplug every morning.
  20. Oct 4, 2018 at 7:44 AM
    #360
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    60k on 3rd Gen Spark plugs
    BillsSR5[QUOTED] likes this.
