Diesel in oil before draining
Discussion in '1st Gen. Tacomas (1995-2004)' started by Reney, Nov 12, 2021.
  1. Nov 12, 2021 at 5:25 AM
    Reney
    Reney [OP] Member
    1998 Toyota Tacoma TRD
    What’s everyone’s thoughts about running a detergent like a quart of diesel in with your oil and idling to warm up right before draining for an oil change? I’ve done it on a couple other vehicles I’ve had in the past with no problems and obviously no visible results. Just wanted some other opinions. Thanks
  2. Nov 12, 2021 at 5:30 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
  3. Nov 12, 2021 at 5:54 AM
    dleithaus
    dleithaus Well-Known Member
    Washington State
    2024 TRD OR iForce Max
    Yeah, I agree. Not a great idea for an engine.
    If you really wanted to flush, you would dump the current oil. start over with new oil, run the engine to temperature, then dump again.
    I worked in petroleum refineries. In that application they would often rinse out tanks, vessels, or exchangers with diesel (or other partially refined products called "cutter") to help move thicker materials or products forward in cleaning or tank service transfer operations. It made little difference since those same tanks were at the front end of the refinery and destined for subsequent refining -- contamination was never an issue. Finished product tanks were never flushed with anything but what was supposed to be in them from the get-go.
  4. Nov 12, 2021 at 5:59 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    If your truck has had regular oil changes, it's pointless.
    A vehicle that never had an oil change and is sludged up, it could help.
    NachoTaco96, JJ04TACO and usmc2msu like this.
  5. Nov 12, 2021 at 6:15 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    OP...you have your own answer. "...obviously no visible results."
    Its not needed. Just use an oil that meets the API specs as called in the Owner's Manual.
    JudoJohn and RustyGreen like this.
  6. Nov 12, 2021 at 6:16 AM
    Reney
    Reney [OP] Member
    Might as well not waste it then especially with its current price tag. Thanks
    JudoJohn likes this.
  7. Nov 12, 2021 at 6:21 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
  8. Nov 12, 2021 at 6:34 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Just change the oil and filter regularly and use good products. This like improving your diet -- you see gradual, predictable results.
    Solvents or flushes are like a laxative -- they cut loose a lot of stuff right now with unpredictable results -- this stuff is now floating around in the engine, again with unpredictable results.
    slander likes this.
  9. Nov 12, 2021 at 6:38 AM
    Knute
    Engine laxative..... very good.. :rofl::rofl::rofl::rofl:
    :thumbsup::thumbsup:
    JudoJohn, Kevins60 and RustyGreen like this.
  10. Nov 12, 2021 at 6:40 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Agree with the others, Toyota engines aren't like an old domestic straight 6 still using 1920s engine technology (cough 4.0 jeep cough), they don't sludge up and don't get crazy dirty if you change the oil on a reasonable time frame.
    SR-71A likes this.
  11. Nov 12, 2021 at 6:43 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Thank you, I do try.
    Teaching always works better with a good visual. :laugh:
    Bivouac likes this.
  12. Nov 12, 2021 at 6:44 AM
    Knute
    Agreed....
    Although, some remain unteachable.
    Still cleaning spewed coffee off my keyboard....
    tcjacado and RustyGreen like this.
  13. Nov 12, 2021 at 6:45 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Except for the 1MZ
  14. Nov 12, 2021 at 6:48 AM
    Knute
    A result of not changing your oil as scheduled................. poor engine, stupid owner.
    The owner stepped over dollars to save pennies.
    I'm sure the money saved by skipping oil change maintenance paid for the dead engine repair.
  15. Nov 12, 2021 at 6:49 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    If that were true they wouldn't have redesigned the flawed block.
  16. Nov 12, 2021 at 6:53 AM
    Knute
    Sorry, I don't believe a flawed block will cause sludge of that magnitude.
    JudoJohn and NachoTaco96 like this.
  17. Nov 12, 2021 at 6:53 AM
    aroma
    aroma Well-Known Member
    Snottsdale AZ
    I have used seafoam with good results. A couple of ounces.
  18. Nov 12, 2021 at 6:56 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    It burned more oil than the older versions previously did. It's a known issue.
  19. Nov 12, 2021 at 7:05 AM
    Knute
    Burning oil is typically a result of worn piston rings or worn valve guide seals. To my knowledge the block oil passages do not directly connect to the combustion chamber.
    I have no doubts the block was redesigned. I'm skeptical if "oil burning" or "sludge" was the reason.
  20. Nov 12, 2021 at 7:06 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    The new modern oils already have additives and detergents to resist sludge buildup. I believe that if you are changing your oil at the recommended frequency or more often, you won't have a need to put anything else in it.
    Knute likes this.
