Diesel in oil before draining
Discussion in '1st Gen. Tacomas (1995-2004)' started by Reney, Nov 12, 2021.
  1. Nov 12, 2021 at 7:11 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    This is an amazing conversation. I have decided to start taking hallucinogenics before opening up TW on Fridays so the conversations will make sense.
  2. Nov 12, 2021 at 7:53 AM
    Glamisman
    Glamisman Well-Known Member
    Use caution... I have used LiquiMoly Engine flush but this is a band aid. The concern I have is that will this clean too well? There is no easy way that I can see if the crap that doesn't drain out is blocking the pickup screen. I had one of my charity cars make it the 1000 miles to Cabo San Lucas, 2 days of 12 hour driving, with zero problems... it didnt last 100 miles after that. The mechanic pulled the pan and sure enough, the pickup screen was blocked. I guess the long drive loosened all the crap and it found its way to the screen.
    Bivouac and tacomataco2 like this.
  3. Nov 12, 2021 at 10:14 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    My Thoughts break all the dirt loose clog the oil pick up take out the oil pump score the rod bearings
  4. Nov 12, 2021 at 10:18 AM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
  5. Nov 12, 2021 at 10:39 AM
    Wulf
    rock raisin
    yeah, I've seen this backfire on severely sludged engines...
    all that sludge gets freed! Yay! now it's in the pan clogging the oil pickup. Engine died of oiling issues. Whoops
    RustyGreen[QUOTED] likes this.
  6. Nov 12, 2021 at 10:41 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Pennzoil Yellow Bottle regular or Mobil 1 full synth are the most detergent oils I know of I use them for cleaning nasty engines and it works, takes time but it works safely.
    Brake Weight, JJ04TACO and Wulf like this.
  7. Nov 12, 2021 at 6:40 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Hell yeah, 44k is good stuff and Moa too. Use those regularly really seems to help as the miles add up
  8. Nov 12, 2021 at 6:57 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Ditto on the modern oil has detergents in it, as does fuel. Regular maintenance should be all that's required. I did my valve cover gaskets at well over 100K miles more like 130-150k and the valve train was spotless. Normal wear on the cylinders ring's and valves will never be remedied by cleaning or "leaving gunk" in there to fill the gaps.
    If you feel the need to clean off a bit of carbon from the valve's and the piston tops, that will help with detonation by eliminating potential hot spots from carbon heating up. A bit of carbon is normal as engines age for lots of reasons.
    Wulf likes this.
  9. Nov 12, 2021 at 7:12 PM
    Snoman002
    Snoman002 Well-Known Member
    Sno
    21 DCSBORSWMT
    Are you solving a known problem? Or just throwing money at a perceived one?
    if you know you have buildup run a good synthetic with higher detergent levels. If you need a more aggressive cleaner I like Auto RX
    if you have an unknown then run mobile one or penzoil platinum
  10. Nov 13, 2021 at 8:23 AM
    dleithaus
    dleithaus Well-Known Member
    Washington State
    2024 TRD OR iForce Max
    This video shows a Prius engine breakdown at 300K miles.
    The mechanic is great at quickly explaining each component and the normal wear expected.
    At about 7:49 he digs into the oil pan....
    https://youtu.be/ujEJDDB7pBU
  11. Nov 13, 2021 at 10:04 AM
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    99.9% of this advice is crank case.
  12. Nov 13, 2021 at 10:17 AM
    Wulf
    rock raisin
    You mean I shouldn't fill my crank case with Seafoam, ATF, or diesel just because someone on the internet told me it would make my engine run better?
    Speedytech7[QUOTED] likes this.
  13. Nov 13, 2021 at 10:27 AM
    Speedytech7
    You should, others probably shouldn't though.
  14. Nov 13, 2021 at 10:31 AM
    Wulf
    rock raisin
    I did when I was in high school and it worked great. A ton of sludge came out after adding Seafoam to the oil a few miles before an oil change. I put in fresh oil, a new filter and was on my way again.
    Engine only made it a couple weeks before all the redistributed sludge caused oiling issues and the driver's side head seized up. Timing belt sheared the crank key off and all
  15. Nov 13, 2021 at 10:41 AM
    #35
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Well, I guess there is a lesson in there somewhere... ;)
    Speedytech7 likes this.
  16. Nov 13, 2021 at 10:43 AM
    #36
    Speedytech7
    That's about the expected result. I truly haven't found anything seafoam is genuinely good for. It does nothing added to fuel, it's bad for oil shear strength and viscosity, pouring it down the intake makes a fun smoke show for morons but it just ruins the catalyst and wideband/O2 sensors....
  17. Nov 13, 2021 at 11:19 AM
    #37
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    So if you have a dirty old engine then save up for a rebuild while driving it and maintaining it while also running good oil to clean it along the way?
  18. Nov 13, 2021 at 12:05 PM
    #38
    Speedytech7
    Seafoam is basically light premix anyway, imagine it would be pretty good in a 2stroke outboard. Thankfully I stopped fucking around with marine shit, snake oil may eat a lot of money from the uneducated, but I think boats eat more haha
  19. Nov 13, 2021 at 12:05 PM
    #39
    Snoman002
    Sno
    21 DCSBORSWMT
    Could be worse. It could be Lucas oil additive…
  20. Nov 13, 2021 at 12:06 PM
    #40
    Speedytech7
    Mmmm it's like gear oil without the anti wear, tastes especially good in tea. I keep a bottle around for engine assembly, it's good for that, kinda it tho.
