DIESEL MOD GONE WRONG
Discussion in 'Performance and Tuning' started by TPain, Sep 30, 2013.
Which one?
  1. Left
    2.8%
  2. Center
    3.3%
  3. Right
    5.0%
  4. Dual (custom y-pipe)
    13.8%
  5. Through Hood
    75.1%
  1. Jan 1, 2014 at 10:41 PM
    #181
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
  2. Jan 1, 2014 at 11:25 PM
    #182
    WhiskeyWolf
    WhiskeyWolf Member
    Lower Alabama
    14 TRD sport
    Hahaha this guy has killed me!! His uncle must have been smoking crack that day or either he is the only mechanic around :D
  3. Jan 2, 2014 at 7:15 AM
    #183
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    you forget to run diesel you will need to convert to a mechanical fuel pump, with out high PSI to atomize the fuel you aint achieving now coal burnin;)
    Fuck me, wish you would have said something before I bought the 2RZ for my samurai.....
    PHOTO SHOP FTMFW!!!!!!!!!!!
    Or he doesn exist like the ability to do said diesel mod
    This thread is full of so much derp, which I am now SUB'D for.
    BTW Im pretty sure you need to bolt this on, to get the optimum performance out of your diesel mod.0turbo67_404b49b21ff86b22d80d27fc6457e214822a76fc.jpg
  4. Jan 2, 2014 at 7:02 PM
    #184
    TPain
    TPain [OP] Boss
    Tanner
    Asheville, NC
    01 Supercharged
    You're pushing it with those numbers, but I would like to see the dyno when finished
  5. Jan 2, 2014 at 7:34 PM
    #185
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Okay y'all have inspired me. Tomorrow I will top off my tank with water from my neighbor's hose. This way I can convert over to running on steam and I can get free fuel from any unsuspecting homeowner! This is great! Steam engine here I come! :woot:
  6. Jan 3, 2014 at 12:26 AM
    #186
    SteveO86
    SteveO86 Well-Known Member
    South Korea
    2013 Super White TRD Sport DCSB 4x4 (Sold)
    BHLM w/ Retrofit, Window Tint, xB LED Fogs, Rigid Dually D2s w/ Amber Covers, Matt123 Skid & Tow Hook, Cobra 75 CB w/ 3' Firestik on BAMF mount, N-Fab Steps, Tonneau, Scangauge II, AVID Light Bar, Katzkin Seats, Remote Starter
    I think the trick is going to be in the tuning to get those numbers. I believe that with the right ECU hacks, like If I install the Napster.car file, I should be able to download power from other Priuses and then I should get close.
    Edit: I also forgot that I'm going to add my eco-leaf stickers to get more powa!
  7. Jan 3, 2014 at 7:01 AM
    #187
    Phil Dammit
    Your Mom
    Tempe, Arizona
    So close is good enough in your book?
  8. Jan 3, 2014 at 7:34 AM
    #188
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    Besides all the crazy talk, he said he runs 1.5 Gallons of SeaFoam every tank? That can't be good, for the Tacoma or the Wallet
  9. Jan 3, 2014 at 8:17 AM
    #189
    Phil Dammit
    Your Mom
    Tempe, Arizona
    He also said he converted his gasoline engine to diesel :facepalm:
  10. Jan 3, 2014 at 8:28 AM
    #190
    dsjones5
    dsjones5 Well-Known Member
    DSJ
    Georgia
    2011 MG DC Taco
    Seat covers, weather tech digi fit, bug deflector, plasti dip wheels, magnaflow muffler, and many more to come!.. as soon as i get money. Ill probably go broke typing this...
    a gas engine can not run diesel. simple as that.
  11. Jan 3, 2014 at 8:39 AM
    #191
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Didn Citroen, Peugeot, or Renault create an air-powered engine for an automobile.
    Wait found it, was a tag team between C&P
    C&P COMPRESSED AIR 81MPGS
  12. Jan 3, 2014 at 9:34 AM
    #192
    Frogging
    Frogging Well-Known Member
    DEREK
    ORLANDO, FL
    DCLB 4.0 2wd
    ASV vent visors LED tailgate brake light Weathertech floor mats Wish list:Maxtrac Spindles New leaf pack Extended rear shocks Braided Brake lines Konig countersteer Anodized bronze 285/70/18 tires NST Crank lite pulley setup XTP intake manifold spacer Neoprene seat covers Fiberglass fenders Power sliding rear window 1" Spacers for rear wheels
    dont be a debbie downer, anything is possible! just wait for the results, im all for inovation and this is def up there. plus ive see a few others thinking outside the box too.
    makes me wonder if i can pull it off:drunk:
  13. Jan 3, 2014 at 9:49 AM
    #193
    Phil Dammit
    Your Mom
    Tempe, Arizona
  14. Jan 3, 2014 at 10:13 AM
    #194
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh my god. This thread is REdic on SO many levels! I just read 11 pages worth of bullshit because it is that damn hilarious!
    So wait, let me get this straight. An air fueled air pump? Now we're cooking with Crisco!
  15. Jan 3, 2014 at 10:25 AM
    #195
    Phil Dammit
    Your Mom
    Tempe, Arizona
    :rofl:
    Not just crisco, petrol fueled open flame and crisco!
  16. Jan 3, 2014 at 10:28 AM
    #196
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh shyt! :eek: That's beyond my level of expertise!
  17. Jan 3, 2014 at 10:39 AM
    #197
    Phil Dammit
    Your Mom
    Tempe, Arizona
  18. Jan 3, 2014 at 11:33 AM
    #198
    mr optimist
    mr optimist Mr Lazy
    Sam
    Alamosa, CO
    1998 4runner SR5 5 speed
    Supercharged, 5 speed, AOR Sliders, Tundra Front Springs, OME 906 Rear springs, Bilstein Tundra 5100s, Factory Diff lock, Wrangler Authority 275/75/16
    If you ever feel that you need to roll more coal you can always pump diesel into the exhaust...
  19. Jan 3, 2014 at 1:10 PM
    #199
    Frogging
    DEREK
    ORLANDO, FL
    DCLB 4.0 2wd
    serious, very serious!!
  20. Jan 3, 2014 at 4:24 PM
    #200
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Of course you'll have to have your taco certified for diesel. Once you're certified you can no longer use gasoline or you can be charged with tax evasion.:eek: In most states diesel tax is higher than the gas tax. (California is backwards, what else is new)
