DIESEL MOD GONE WRONG
Discussion in 'Performance and Tuning' started by TPain, Sep 30, 2013.
Which one?
  1. Left
    2.8%
  2. Center
    3.3%
  3. Right
    5.0%
  4. Dual (custom y-pipe)
    13.8%
  5. Through Hood
    75.1%
  1. Oct 1, 2013 at 7:16 AM
    #61
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
  2. Oct 1, 2013 at 7:19 AM
    #62
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Great, just the reassurance I needed. Going to buy some diesel. BRB. Or should I say RBP, cause now I can rock some of these POS.
  3. Oct 1, 2013 at 7:23 AM
    #63
    hitmans.army
    hitmans.army Just a guy.
    Myrtle Creek, OR
    '07 PreRunner & '40 Chrysler Coupe
    Bilstein 5100s up front with OME 885s, rear Add-A-Leaf, LED lights (tails, dome, map, plate lights), Kicker 8" in custom fiberglass enclosure under back seat, Kicker speakers throughout and Kicker amp for sub, Pioneer DVD Player, Satoshi Grille with Devil Horns, Leer 100XQ.
  4. Oct 1, 2013 at 7:29 AM
    #64
    Boone
    Boone, NC
    Airbags deployed
    Yeah, and 5lugger95 said that while he is building my prototype 2nd gen 4x4 LT kit he's gonna re-drill the 6 on 5.5 bolt pattern so they work with my stock stuff so I don't have to stick some tons under it. He is a genius.
  5. Oct 1, 2013 at 7:29 AM
    #65
    TPain
    TPain [OP] Boss
    Tanner
    Asheville, NC
    01 Supercharged
    I can give you my uncles number so he can explain everything. I personally would use these instead.
  6. Oct 1, 2013 at 7:31 AM
    #66
    Boone
    Boone, NC
    Airbags deployed
    Sweet. PM it so everybody else doesn't catch on so quick. And I'm going to be SRW, so those won't work for me.
  7. Oct 1, 2013 at 7:34 AM
    #67
    TPain
    TPain [OP] Boss
    Tanner
    Asheville, NC
    01 Supercharged
    Alright, I might actually use these wheels. To counter the offset I might use spacers but I'll probably just use washers.
  8. Oct 1, 2013 at 7:39 AM
    #68
    TPain
    TPain [OP] Boss
    Tanner
    Asheville, NC
    01 Supercharged
    I bet it looked schweet
  9. Oct 1, 2013 at 8:06 AM
    #69
    DavisBladeWorks
    DavisBladeWorks Well-Known Member
    North ATL
    2013 DSCB TRD Sport 4x4
    So, I started this mod today and it's not going so well. Maybe I didn't get the correct diesel/gas ratio? Help guise.
  10. Oct 1, 2013 at 8:10 AM
    #70
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Yeap too much gas not enough DIESEL!
  11. Oct 1, 2013 at 8:17 AM
    #71
    BamaToy1997
    Bill
    Navarre, FL
    There is no way this is real. And if his uncle is the best mechanic in that town, then I suggest everyone MOVE. Gotta be a joke.
  12. Oct 1, 2013 at 8:18 AM
    #72
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
  13. Oct 1, 2013 at 8:21 AM
    #73
    Boone
    Boone, NC
    Airbags deployed
    See, thats proof. All you have to do is believe, and it will expose itself to you and become real.
  14. Oct 1, 2013 at 8:24 AM
    #74
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
  15. Oct 1, 2013 at 8:43 AM
    #75
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    It's got to be true, Bill. He's got 1.5 gallons (about $100 worth) of Sea Foam in there. :D
  16. Oct 1, 2013 at 8:56 AM
    #76
    deog
    deog Well-Known Member
    snicklefritz
    Las Vegas. As far west as you can go.
    work in progress
    gucci interior and chandelier.
    Day old hot dog water runs much better then diesel in a gas engine, and it is cheap, everyone knows this. What ever you do, do not mix in Badger sperm. It lubricates the injection pump very well, but will explode causing slime to come out of the exhaust and it is highly corrosive.
    I have a 4bt and a 12 valve for sale for anyone that really wants to run diesel.
    engines only. I believe the 12 valve will need to stick out of the hood by about 12" in a tacoma or 4runner to make her fit, but i am sure the OP's uncle can shoe horn it in.
    CUMMINS for the win.
  17. Oct 1, 2013 at 9:22 AM
    #77
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    Excellent advice. I hope I can remember it. :thumbsup:
  18. Oct 1, 2013 at 10:03 AM
    #78
    TPain
    TPain [OP] Boss
    Tanner
    Asheville, NC
    01 Supercharged
    You need to start with very low amounts of diesel and then when your truck starts misfiring it means you need to add more diesel. So if your problem is that it is sputtering and cutting out then you just need to add more diesel.
  19. Oct 1, 2013 at 10:14 AM
    #79
    DavisBladeWorks
    North ATL
    Well I ran out of diesel for a bit and put about a gallon of kerosene in the tank until I could get some more diesel. Did I screw up?
    I hope not, because I can't wait to roll coal in my Taco.
  20. Oct 1, 2013 at 10:31 AM
    #80
    acdronin
    acdronin Well-Known Member
    I think I'm gonna covert mine to run on dead hookers and midgets, ya know, clean up the 'ol gene pool a bit
