Diesel Swap
Discussion in '4 Cylinder' started by caseytfc, May 10, 2011.
  1. May 10, 2011 at 6:21 PM
    caseytfc
    caseytfc [OP] New Member
    Casey
    New Hampshire
    01 Taco
    Does anyone know if there is a diesel toyota motor that will swap into a 2001 tacoma with a 2.7liter in it? I know they make a hilux in europe that has a diesel and I'm just looking for a swap that I won't have to do to much fabrication.
  2. May 11, 2011 at 6:04 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    welcome to TW. I have no real answer, but maybe advanced adapters might or they can steer you where you need.
  3. May 12, 2011 at 8:37 AM
    gt4som
    gt4som Active Member
    Nelson
    Tampa, FL
    Thats actually an interesting thought that I've had before. I know the Hilux trucks in Latin America Run a 2.7 Liter Turbo diesel. They are slow but torquey.
  4. May 12, 2011 at 10:20 AM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    Yep you can get that and it will fit. But you will need to change everything from the radiator to the fuel tank. Even most of the exhaust.....
    They installed a diesel from a VW into a Samari on extreme 4x4, so anything my work besides a Toyota diesel.
  5. May 12, 2011 at 12:26 PM
    Racerboy221
    Racerboy221 Well-Known Member
    Bill
    Litchfield Park, AZ
    Tacoma 2.4, Std cab/bed, 18"wheels,airshocks
    18" Wheels & Tires, Airshocks, CB Radio
    My first Toyota was an 82. It was bought in Germany and was a diesel. Throughout my travels I have seen quite a few newer units with diesels but none here in the states. Most recently in the Bahama's. You are in NH so if you are able to locate one from there, shipping will be only thing which could make the cost prohibitive. G/L!
  6. May 12, 2011 at 7:07 PM
    slo13zx3
    slo13zx3 Well-Known Member
    Brian
    forest city pa
    14 trd off 6speed nav
    4bt if u have the cash
