Diesel Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by manethon, Dec 1, 2013.
  1. Dec 1, 2013 at 5:08 PM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    Does anyone know if it's possible to swap a 4.5 L V8 1VD-FTV turbodiesel intercooler into a second gen? I mean people drop ls1s In wouldn't the 1vd for snug? I know the hilux which is very similar to the Tacoma does come w the 3l diesel but I'm looking to go a different direction.
    I know there is an incremental increase on the weight of the motor but with all proper prep and frame reinforcements te weight shouldn't be to much of an issue... Any input?
  2. Dec 1, 2013 at 5:11 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    With a torch, welder, fab skills, wiring skills, MONEY, anything is possible. That will be totally custom.
  3. Dec 1, 2013 at 5:14 PM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    I have some contacts and was looking to find a cruiser that rolled or has soek
    Damage done to it and do a sas at the same time
    Prob look for an fj80 and strip everyone off it that I need and upgrade, however I would
    Love some d60s front and rear with that power and 37+ tires
  4. Dec 1, 2013 at 5:15 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    I'd just go ahead and plan on dumping well north of 10k into the project if you want to SAS it too, more if you can't do the work yourself.
  5. Dec 1, 2013 at 5:17 PM
    FTD
    FTD Well-Known Member
    The mounting will be easy. The engine computer will be the not very fun part. Good luck and take lots of pics!
  6. Dec 1, 2013 at 5:31 PM
    TRD Toy85
    TRD Toy85 Well-Known Member
    CT
    loaded 2013 TRD sport
    If you had lots of money and time to burn , sure anything can be done..
  7. Dec 1, 2013 at 6:01 PM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    I get it,
    Look this might sound rough but lots of people are stating the obvious here. I know it's gonna take time, money, name it, let's face it anything ican he costs a ton.
    I'm looking for info or knowledge like electrical and computer based issue I can expect etc
    I was worried the physical size of the motor won't fit,
    Then there are other issues like trying to line up the drive train and if I was to sas it dealing w a variety of other figment probs like the pan Etx
  8. Dec 1, 2013 at 6:04 PM
    Large
    Large Red
    Is it much bigger than an LS3? I've seen 2 LS3 swaps, one in a first gen and another in a 2nd gen. The second gen fit snug, the first gen needed the firewall recessed back about 4" I think.
  9. Dec 1, 2013 at 6:07 PM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    Not sure, I'll have to find dimensions n compare.
    The plan is to do 2 builds at the same time and use as much off an fj80 as ican.
    02-04 Tacoma w d4d on 37s w fj80 axles
    07 Tacoma w fj80 motor, d60s on 37s
    Damn big projects I know but I'm sure it will be worth
  10. Dec 1, 2013 at 6:07 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
  11. Dec 1, 2013 at 6:13 PM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    My good friend here has a 04 w a d4d on fj80s w 37s and twin stick
    He switched out to manual injectors and avoid all the ecu related issues.
    I will say " winch's" truck is one mean bad ass truck
  12. Dec 1, 2013 at 6:14 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    So I would start with getting dimensions and take some measurements. I've never heard of anyone doing this swap so unless you can find someone who has you're pretty much pioneering this.
    You're also going to need some wiring diagrams and figure out what to connect to what to make things like your instrument cluster work. I think it goes without saying you'll need the ECU for whatever motor you get.
    Transmission bell housing and clutch might be tricky as I doubt they're compatible with the diesel. Might take machining down the bell housing and making a custom adapter plate.
    It will be a fun project though, it's just going to take some serious engineering to get it done as you know.
  13. Dec 1, 2013 at 6:15 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
  14. Dec 1, 2013 at 6:22 PM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    I'm starting all my phone calls this week and more research etc etc coming in dec.
    As I mentioned though, I wonder if it's possible to swap just about the entire drive train over to the 05- the axles and use d60s
    As i can use that entire set up and pass just the fj80s to the 04
  15. Dec 1, 2013 at 7:18 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    I think this is the first time anyone has talked about putting a diesel in a tacoma. :notsure:
  16. Dec 1, 2013 at 7:46 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    that one posted above with the v8 4.5.... sounded M E A N!!!!!
  17. Dec 1, 2013 at 8:43 PM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
