Diesel tent heater install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JDSmith, Nov 21, 2021.
  1. Nov 21, 2021 at 6:30 AM
    JDSmith
    JDSmith [OP] The Overland Shop, VT
    Jesse
    Essex Jct, Vermont
    21 Pro MGM MT
    Always changing
    Figured I should make a thread on this to keep it all in one spot. I’ve been trying to figure out where and how I wanted to install a heater. I wanted it easy to get to, out of the way, easy to remove, close to the tent, easy to refill, blah blah blah, blah. I’ve been working on this for a couple weeks now, mostly just staring at the truck going back and forth on where to put everything. I even considered installing it in the truck on the floor behind the passenger seat. Here’s where I finally decided to mount it and why…
    I wanted another load bar for the tent anyways because the rear of the tent is barely on it. Just the way it has to be because of everything else mounted. This also gave me a rear mounting point for the box and with the Leitner system, mounts and un mounts extremely easy. I used a pair of maxtrax mounting bars I had because they lined up perfect on the top of the case. The case is a pelican 1600. I wanted to be able to easily hinge down the case and grab the components (duct, filter, etc) without crawling in the bed. I can easily reach it, even with the tailgate open.
    Going to swap out the rear water pax for a diesel. I kept thinking about the easiest way to fill the tank at a station and those smaller tanks would have been a PITA. Didn’t want to carry a fuel can to fill the fuel tank either. I’ll be able to pull in to a gas station and fill the diesel pax easy. It will also allow me to use minimal fuel line.
    The run for the hot air to the annex will only be about 2-3’ (to the pass side) so minimal heat loss and I’ll be able to store that small section right in the box.
    Remaining parts will be here this week so I’ll continue posting as I get stuff together. A couple more pics, misc bolts holding the heater in the box for the mock up.
    D401EB52-4F9C-4044-BBC6-EE1E6DC009BF.jpg ECC8C681-425F-48AA-80F4-ADC7E7EC29F0.jpg 3319202A-3E7D-4E3C-9C4B-BA19646391D1.jpg 9CA9A0F3-BA31-4C24-A403-333D3BEF5654.jpg 42735D33-3667-4110-B80D-55D5C6E866AA.jpg EFD08BDF-9AF3-4A6E-886B-B79D7D555B7F.jpg
    @Taye would be absolutely comfortable in 0 degree weather, I’m cold at 65…
  2. Nov 21, 2021 at 6:31 AM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    Pretty damn cool.
    JDSmith[OP] likes this.
  3. Nov 21, 2021 at 6:38 AM
    Mark77
    Mark
    Nothing yet
    So when you use it, whats the whole set up look like? Is that just where you store it?
    SR-71A likes this.
  4. Nov 21, 2021 at 6:40 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    What could go wrong? :bananadead:
  5. Nov 21, 2021 at 7:57 AM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    It's not rocket science. Pretty simple actually just not easy.
    JDKred and JDSmith[OP] like this.
  6. Nov 21, 2021 at 2:03 PM
    4x4engr
    4x4engr Well-Known Member
    Pete
    2017 Quicksand TRDOR 4x4
    I'd prefer mine further away from the truck in the open to avoid emissions
    Kev250R likes this.
  7. Nov 21, 2021 at 4:40 PM
    JDSmith
    Jesse
    Essex Jct, Vermont
    21 Pro MGM MT
    Always changing
    That’s where it will be when it’s in use.
    SR-71A likes this.
  8. Nov 21, 2021 at 4:54 PM
    AntonXIV
    AntonXIV Member
    2010 Access Cab 6 speed
    Total Chaos uppers and lowers, spring under with bumps, regeared diffs with an ARB locker in rear
    What kinda temperature increase are you thinking you're going to get with this setup?
  9. Nov 21, 2021 at 5:04 PM
    JDSmith
    Jesse
    Essex Jct, Vermont
    21 Pro MGM MT
    Always changing
    Made a little more progress. Fit the intake/exhaust ports for the heated air. Rotopax get delivered tomorrow or Tuesday so I’ll start running the fuel lines after that gets here. Sliver of tubing is to hold the inner hot air cone centered while the silicone dries.
    D86EB76B-9B4B-48E0-88AC-436887159EEC.jpg E0860B6F-B015-4F86-A073-01F7DA8862B6.jpg 8DAA7E5A-2AD4-4EA6-99C1-A06280F88370.jpg C2BFABD7-8395-4ADF-BB7E-20AEB222F52F.jpg 86A89128-5A9B-4BBC-BD4E-E5DA10BD4E1E.jpg
    tcBob, AusBerg, deanosaurus and 5 others like this.
  10. Nov 21, 2021 at 5:09 PM
    JDSmith
    Jesse
    Essex Jct, Vermont
    21 Pro MGM MT
    Always changing
    Heater stops working and I get cold. Other than that, nothing
  11. Nov 21, 2021 at 5:11 PM
    Rexfordian13
    Rexfordian13 Well-Known Member
    J
    Albany/NY Capital District
    2015 TRD Sport DCSB MT
    That’s pretty cool, reminds me of the heater on an old tractor. And it sure beats the Mr. Buddy Heater option. Keep us posted on your progress!
    D.A.S. Taco, SR-71A and JDSmith[OP] like this.
  12. Nov 21, 2021 at 5:13 PM
    JDSmith
    Jesse
    Essex Jct, Vermont
    21 Pro MGM MT
    Always changing
    From what I’ve researched, these will roast you out of the tent. I plan on running mine to the annex and letting the heat rise. Also gets rid of the condensation. Going to do a couple test runs at the house before the trip just to make sure everything’s working right. I’ll post that when I do.
    honda50r, B_Quad, Anton338 and 2 others like this.
  13. Nov 21, 2021 at 6:16 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    This technology was developed in Europe back in the 40’s and started showing up on our shores in the 80’s, very safe and hot enough to cook a chicken!
  14. Nov 21, 2021 at 6:24 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Why diesel instead of gasoline?
  15. Nov 21, 2021 at 6:53 PM
    Captqc
    Tigard, OR
    Safer, better mileage. There’s gasoline units also available but more risk to them because gas goes boom!
  16. Nov 21, 2021 at 6:57 PM
    GrundleJuice
    Michigan
    2016 TRD Bro
    Requires an alternate fuel tank, pump, etc, though.
  17. Nov 21, 2021 at 6:58 PM
    Captqc
    Tigard, OR
    Yup but it comes with some of the kits.
  18. Nov 21, 2021 at 7:11 PM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    Of course it depends on the temp outside, but according to this guy you would need the big version of the China heater for an annex.
    https://youtu.be/LvHJdjIwjao
    sicofit and JDSmith[QUOTED][OP] like this.
  19. Nov 21, 2021 at 7:19 PM
    Mark77
    Mark
    Nothing yet
    This thread is great. Typical for TW. Someone does a "new" mod, informative. And half the posts are on why this guys avenue is shit.
    Id want propane or diesel because of altitude issues that gas heaters are known for.
    Philrab, Phlogiston, AusBerg and 9 others like this.
  20. Nov 21, 2021 at 8:27 PM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    How will you control it from inside the tent? Do you set it on a timer? Just warm it up and try to run in after turning it off and hoping no heat escapes?
    This is a super cool build. Looks like you have an ikamper or something similar? What kind of annex is it?
