Diff and transfer bolts stuck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Danno13, Aug 9, 2025.
  1. Aug 9, 2025 at 12:37 PM
    Danno13
    Danno13 [OP] Member
    2013 TRD Off Road
    Trying to change all my diff fluid and not a single bolt will budge. Any tips would be appreciated
  2. Aug 9, 2025 at 1:11 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Put the socket in place then hit it hard with a hammer a few times first
  3. Aug 9, 2025 at 1:14 PM
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [ED] Entune Audio+ [TO] V6 Tow Package
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass and Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All Weather Floomats (summer).
    Try spraying them with PB Blaster or equivalent. Wait a few minutes and then place the correct-sized socket (6pt) on the bolt/plug and give it a few firm hits on the end of the socket with a small hammer. Don't beat on them or over-do it. Let sit five minutes and try removing the plug. If it doesn't want to budge, move on and repeat the steps on each. If you are doing all three unit's, by the time you spray and tap on them all and get back to the first, it will be time to try moving them. If not: repeat the spray and the tapping. One or two repeats will usually do it.
    Remember to verify all of the the fill plug(s) will come off before touching the drain plugs, or you'll end up having a real bad day. :eek: :facepalm: :proposetoast:
  4. Aug 9, 2025 at 1:14 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Use a shallow 6-point socket and a longer breaker bar. A good impact wrench works as well. On my 2010 4Runner I had to use my Milwaukee mid-torque, rated for 550 ft-lb.
    O'DubhGhaill and Williston like this.
  5. Aug 9, 2025 at 2:48 PM
    Danno13
    Danno13 [OP] Member
    2013 TRD Off Road
    @Williston I used your technique with fluid film and it finally work. Took about 4 rotations on each but they finally gave way. Thanks for the help!!
    joba27n, Williston and OffroadToy like this.
  6. Aug 9, 2025 at 4:53 PM
    Williston
    Nice! Glad it worked! I saw a video on the web by a local mechanic and did mine using that technique. He pointed out that it was especially important with the front diff plugs with those hex head bolts that can strip out so easily trying to remove them. I remember he made sure the hex on them was cleaned/wire-brushed well, and used the spray and tap method with I think a dedicated hex socket of the correct size. He spent extra time on them making sure it was fully seated and tight in the bolt. It came out almost as easily as the others.
  7. Aug 9, 2025 at 4:57 PM
    O'DubhGhaill
    O'DubhGhaill Well-Known Member
    2008 Tacoma TRD Sport Access Cab 4.0L V6 VVT-i6spd manual
    This. I had to use the 6 points and 1/2" breaker to get my front diff forsaken hex plugs off. Replaced them with the Lexus 6 point plugs. And yes, fill plug off first, always!
  8. Aug 9, 2025 at 5:50 PM
    Wallsjm1
    Wallsjm1 Well-Known Member
    Justin
    Tennessee
    2007 Speedway Blue 4x4 TRD-Off Road
    XD Rockstars 18's, Nitto Terra Grapplers, Billies all the way around, set to 3 inches, AAL, Chrome push bar, Westin step bars
    Do you guys prefer impact or ratchet on rusty bolts?
  9. Aug 9, 2025 at 5:54 PM
    Palomar Taco
    Palomar Taco Well-Known Member
    Aaron
    So FL
    '23 Taco SR5 2wd Street Truck
    Don't force it, get a bigger hammer!
  10. Aug 9, 2025 at 6:12 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I know this isn’t the answer you are looking for…….
    But it depends on the bolt.
    And where the bolt is located.
  11. Aug 9, 2025 at 6:14 PM
    Wallsjm1
    Justin
    Tennessee
    yeah I get that. It’s always a gamble. I broke 3-4 skid plate bolts so now I’m shook.
    I feel like every bolt I take out is going to break. The truck isn’t even really rusty. It’s probably 9/10 condition
  12. Aug 9, 2025 at 7:05 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Impact is the least amount of work. However, if the bolt is long and slender, or if the location requires extensions, there will be enough flex that the impact forces won't be transferred sufficiently to the threaded joint. At that point use a breaker bar, not a ratchet.
    The exception is if you think either the bolt will break or the weld nut inside the frame/body will break. In that case use heat and loosen with a ratchet. The sway bar bracket bolts are known for this. In my 4Runner, I've also encountered it with running board brackets and rear bumpstop brackets.
