Diff Breather Kit
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by TenBeers, Sep 7, 2018.
  1. Sep 7, 2018 at 4:26 PM
    TenBeers
    TenBeers [OP] Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Set of 2 Diff Breather Balloons - $19.97 + $14.32 Shipping and Handling
    Quality differential air is an often overlooked item when maintaining top vehicle performance. As you drive, your differential heats and cools, causing air to escape and be pulled in through the breather. This can result in fouled differential atmosphere by introducing contaminants such as dirt, dust, and moisture, decreasing performance and the service life of the fluid. Don't let your diff air escape or be contaminated, regardless of where you drive! These quality Diff Breather Balloons will keep your system sealed and extend the service life of your differential fluid. Also effective in containing environment-harming fluids in the case of a rollover. No re-routing needed, just attach over existing breather and drive! Best of all, you can share one with a friend!
  2. Sep 7, 2018 at 4:49 PM
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    Aren't the rear diffs only using a one way breather that only lets air escape and not sucked back in?
  3. Sep 7, 2018 at 4:52 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    That's impossible. And don't bring science into this. I need to sell some dang balloons.
  4. Sep 7, 2018 at 4:52 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Do you have any with stuffed animals inside, or similar?
    Might be interested.
    DoorDing and roguegs like this.
  5. Sep 7, 2018 at 4:54 PM
    roguegs
    Angelo
    V8 T4R
    Are you able to make them into animal shapes? Or a little more for the dirty minded folk
    diabetiktaco likes this.
  6. Sep 7, 2018 at 4:54 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Talk to me about "similar."
  7. Sep 7, 2018 at 4:57 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Wow, yours looks defective. You should replace it.
  8. Sep 7, 2018 at 4:58 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    Yes, Diffs have one way valves. These would fit into the expandable diff breathers category, which is still sealed to stop contaminants from getting sucked in. idk if I'd trust a balloon.. but same concept as the Trail Gear ones.
    https://www.4wheelparts.com/p/trail...MI59vDoIyq3QIVFNNkCh2Bsw73EAQYBCABEgLSN_D_BwE
  9. Sep 7, 2018 at 5:03 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    can't bag on his sale. it's his choice.
    peep the B/S/T rules.
    roguegs[QUOTED] likes this.
  10. Sep 7, 2018 at 5:05 PM
    roguegs
    Angelo
    V8 T4R
    Not baggin' I am actually curious as to how these work and would love to see a write up of said breather mod. These third gens are known for having issues and some are alluding to it being because of the OEM breather. I, like many others, have used the extension hose and filter/"2 way breather" but having more options is always good
    t.hornstra[QUOTED] likes this.
  11. Sep 7, 2018 at 5:06 PM
    T4RFTMFW
    .. realistic looking penis toys. :anonymous:
    austin2009 and t.hornstra like this.
  12. Sep 7, 2018 at 5:15 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Those are available from my supplier but are of a much lower quality, do not fit well, and tend to slip off. The result of that failure is expensive and long-lasting.
  13. Sep 7, 2018 at 5:29 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    You guys are smart! Let me explain.
    A one-way breather (that I don't believe in, but let's say it actually exists) allows air out but not back in. This can create negative pressure within the diff, causing air or worse to be drawn into the axle assembly through other routes, like axle seals (which also don't really exist, but the solution for that is still in R&D). The beauty of the balloon is that due to the surface tension of the inflated balloon due to expelled air, it can hold that "one way" fantasy valve open for air to re-enter the diff as needed.
    DoorDing likes this.
  14. Sep 7, 2018 at 5:33 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    Hmmm..
    So you created a thread to troll. Cool story bro.
    Hobbs and roguegs like this.
  15. Sep 7, 2018 at 5:35 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    These fit both the front and the back, correct?
    But are they properly prelubed? If not, what quantity/grade/brand do you recommend?
  16. Sep 7, 2018 at 5:38 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    So, yeah, this was supposed to just be a joke for fun (and there was a double-dog dare involved). Nobody was ever supposed to take it seriously. Not really trolling, but I can see how it could be viewed as that.
    roguegs likes this.
  17. Sep 7, 2018 at 5:40 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Yes, they fit both, but it's more fun to share with friends.
    They come non-lubed, but a little spit should do the trick.
  18. Sep 7, 2018 at 5:46 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    I’m still on the fence. Not sure if the ladies will think it to forward of me to show up with a large red one on the front.
  19. Sep 7, 2018 at 5:59 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Well, you know what they say. Man who sits on fence gets sore bottom! We might be able to do other colors if we can get a group buy going.
    PinnaclePete likes this.
  20. Sep 7, 2018 at 6:44 PM
    PinnaclePete
    PinnaclePete I am what I am
    Pete
    Central AR
    '14 Sport DCLB Pyrite, 2015 DCSB Barcelona Limited
    SwitchPros 9100, Flip Pac, Stealth 6 Bronze, Toyo 255/80/17, MTO Tailgate Skin, RCI read diff plate, StopTech slotted disc and pads, OME 885 w/ NitroChargers, OME HD LeafPacks, SOS Rear bumper with swingout, BAMF Bolt-on Sliders, Rear diff breather, OEM roof racks, ECG perforated grill, BAMF behind grill light bar bracket with PIAA 510 4" yellow spots, US OffRoad bumper, Engo 9k winch, WeatherTech window vents and floor mats, Wet Okle seat covers, RedLine hood struts, Anti Dark hood lights, Baja amber light pods, Lamin-X amber flood covers, amber FlyEyes, Jumpers amber LEDs, Salix glovebox and center console organizer, MagLite mounted, shop made bed mount tool boxes, LogRite bed mount bottle opener
    Will it fit a 2nd Gen without cutting? Asking for a friend :anonymous:
    Willing to ship:confused:
