Diff Breather Mod for Dummies (Pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Neubs, Oct 2, 2008.
  1. Feb 3, 2013 at 1:59 PM
    #381
    NuTacoma18
    NuTacoma18 Well-Known Member
    Orlando, FL.
    2016 Tacoma Double Cab TRD OR 4X4 MGM w/Tech Pkg.
    Weathertech Digital Floor Liners, Front Tint, Tacoma Bed Mat, Tacoma Door Sills, OEM Mudflaps.
    Well I finally did it. Put it in rear bed storage compartment....
  2. Feb 3, 2013 at 2:10 PM
    #382
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    5100's and 883 OME Coils TRD Exhaust Rear Differential Breather Extension, 4WD Light, Tailgate Pipe clamp, Fog lights on while High Beams on,2" Custom Rear Lift, Carrier Bearing flip
    This is where I mounted mine.
  3. Feb 3, 2013 at 2:17 PM
    #383
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    When i did my rear breather mod i duplicated the front breather setup and ordered the bracket,clip, bolt and then i mounted this inside my bed compartment. It makes it a little bit more secure then just sticking it through the side and hanging there.
  4. Feb 3, 2013 at 3:37 PM
    #384
    NuTacoma18
    Orlando, FL.
    Never mind I was able to track the small one goes to the actuator for the diff and the large one to a port in the diff.
  5. Feb 16, 2013 at 12:36 PM
    #385
    AaronArf
    AaronArf Well-Known Member
    Aaron
    Chesapeake, VA
    2012 DCSB LT 4x4
    Check the build thread!
    Completed this mod today. Was going to run it up to the rear light but went with the storage compartment. If water makes it up to that point there are bigger concerns then the diff breather IMO.
  6. Feb 18, 2013 at 11:49 AM
    #386
    western88
    western88 Chris b.
    ny countryside
    2014 SR5 4x4 taco Barclona Red
    beather mod Bugsheild backup light mod egr vent
    done this mod today.. ran the hose behind the rear light frame. pretty much like the other had done this fashion...
  7. Mar 5, 2013 at 2:10 PM
    #387
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    So is everyone ordering
    90404-51319 (This Thread )
    or
    90404-51026 (OP said this)
    with 90930-03136
    What the hell?! I ordered what the OP said to use.
  8. Mar 5, 2013 at 6:40 PM
    #388
    Yoshio
    Yoshio Well-Known Member
    Scott
    Central Coast, CA
    2007 SW 2.7L 4x4 SR5
    Double Cab Step Tubes, 35% Tint Front Windows, Husky Mud Flaps, Illuminated 4x4 Switch, Debadged, DEPO LED tailights, Undercover SE Tonneau Cover, Panavise In-Dash Mount, Plasti-Dipped Front Bumper Lip, OEM Front Fogs, Rear Fog Lamp, LEDs throughout, Door Sill Protectors, Color Matched Satoshi, Rear Window Security Bar, ImMrYo Rear Mirror Bracket, Added factory DTRLs & DTRL kill switch, Rear Diff Breather Mod, 17" FJ Alloy Rims, Sport shocks coils leafs, DEPO black headlights, off-road recovery hook, skid plate, BT-35 TOY Bluetooth kit
    +1, I ordered the OP's version of parts... does it matter? It looks like the 51026 is plastic and the 51319 is metal?
    EDIT: so one of them is painted black and the other is not? Sounds like it doesn't really matter which setup you run...
  9. Mar 5, 2013 at 7:27 PM
    #389
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    Here's a picture of the parts with #'s
    I used 51026 & 03136
  10. Mar 6, 2013 at 7:34 AM
    #390
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    Thank you!!! Finely someone clarifies the difference.
  11. Mar 6, 2013 at 10:49 AM
    #391
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    Clemson
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Window Rain Guards Bed Liner Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges
    yep, 51319 and 03136 with 5/16" ID hose is the best way to go imo
    but i actually used 03136 and 51026 with 5/16" ID. 5/16 is a little to large for 51206 and 1/4" is a little to small for 03136 but i wasn't going to pay for new parts and it is a good enough fit
  12. Mar 12, 2013 at 9:27 AM
    #392
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    Just completed this today! Thanks for the write up!
  13. Apr 8, 2013 at 1:51 PM
    #393
    Jetman1979
    Jetman1979 Well-Known Member
    Michael
    North Texas
    2009 tacoma 4X4
    Did my mod today only my location is the storage box in the rear on drivers side if you open the little door you will see it. One other thing besides having enough hose for axle travel is keep it off the brake hoses you dont want any rubbing there. I put a space of a good 3 inches away from them. Worst part for me is removing spare tire. You can do it with it on but I wanted to check my spare and clean up around it.
    Finding that spot the hook goes in in a bit of a pain but a flashlight helps.
  14. May 2, 2013 at 9:54 PM
    #394
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Columbia, SC
    2015 DCSB 4x4 trd offroad
    Ome 885, dakars, lr uca, bed bars sos sliders
    I am thinkin about mounting mine to the top of my spare tire mount...i'm a prerunner and honestly if i'm over the tire mount, I probably have more issues than just my rear diff breathing...ie. stuck....is this an okay location?...
  15. May 2, 2013 at 10:01 PM
    #395
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
    If you do it just do it right and go as high as you can. People don't like the gas door because sometimes when pumping gas it wont let the nozzle properly seal. The cubby will be easy and do good for your needs.
  16. May 2, 2013 at 10:03 PM
    #396
    kbraunphoto
    kbraunphoto mountain bike haulin' & off camping
    Kevin
    Atlanta, GA
    '15 Inferno Orange TRD Pro
    Just a few expensive things...
    Went ahead and bought these parts, cost me $21.02!!!!
    thats a joke!
  17. May 3, 2013 at 7:02 AM
    #397
    custom90gt
    custom90gt Well-Known Member
    Colorado
    05 SWB TRD Off Road
    The only problem I see with this is that beer is optional. Come on now.
  18. May 3, 2013 at 3:27 PM
    #398
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Your choice, but I wouldn't. You don't need to be 4 wheeling to run through lots of water.
  19. May 5, 2013 at 7:34 AM
    #399
    Stockmonester
    Stockmonester Well-Known Member
    Nick
    Rome, Ny
    2010 reb reb black trim
    Satoshi chrome grill deep lip, 5100 set at .85, 2 hella 500 fog/2 hella 500 driving on n-fab light bar, k&n drop in
    Im changing out my rear diff fluid so i figured do this mod while im under the truck. Instead of getting 1/4 fuel line i got 1/4 clear plastic line, looks bout half as thick. My question will that be take the heat and pressure coming out of the rear or is it just going to melt?
  20. May 5, 2013 at 7:56 AM
    #400
    ImpulseRed008
    Susan
    SC
    :notsure: I'd go get some fuel line. It's not that $$ and I wouldn't want to take the chance of it melting or getting torn up...
