diff drop and billy 5100's???
Discussion in 'Suspension' started by tacomaman06, Sep 16, 2008.
  1. Sep 16, 2008 at 7:28 PM
    tacomaman06
    tacomaman06 [OP] Carolina Alliance: Enforcer
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    is a diff drop needed at all if just going up a notch or two with the billy 5100's??
  2. Sep 16, 2008 at 7:31 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2002 Tacoma Xcab
    will i wouldnt think so...this is one of those highly debated topics as to whether or not a diff drop is necessary...esp at lower lifts
    i think theyre designed more for when youre going 3+ so that you can correct your angles etc and reduce wear...however for a smaller lift you shouldnt need it
    i dont have one and i have no issues
  3. Sep 16, 2008 at 7:41 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ok...cool.
    with my new wheelers springs, i should gain about an inch and a half in the rear, and im about to order some ome 881 coils to replace the factory coils, so im thinking im gonna need to keep the 5100's at the stock height right?? you arent supposed to preload aftermarket coils, correct??
  4. Sep 16, 2008 at 7:57 PM
    JimBeam
    JB
    2002 Tacoma Xcab
    honestly im not sure...ive heard that you shouldnt preload progressive springs and you shouldnt preload adjustable coilovers...however i havent heard that generalized of a statement...maybe chris can help :confused:
  5. Sep 16, 2008 at 8:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    No diff drop is needed. If you look at the geometry of the diff frop, you will find the shaft angles are only changing a few degrees with a 3" lift. The diff drop should be used if vibrations develop from the front shafts, or ( in a worst case) your CV boot fins are touching. I have seen many 3" lifts and no diff drop and the suspension angles are fine. :)
  6. Sep 16, 2008 at 8:21 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ok, sweet!!! thanks for clearing that up buddy!!
    my truck oughtta be riding pretty damn good after the new leaf packs and 881 coils are installed. and later on down the road...........tc uca's and maybe a tom woods drive shaft if i ever need one!!!:D
