Diff Drop Install Question
Discussion in 'Technical Chat' started by tacomakid96, Aug 15, 2010.
  1. Aug 15, 2010 at 8:10 PM
    tacomakid96
    tacomakid96 [OP] Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    I am going to be installing a diff drop on my 96 Tacoma, In the instuctions it says torque the differential bolts back down to spec, but I dont have anything but simple tools so will it be a problem if I torque them down as much as I can without straining myself and call it good? Any help from someone who has done this would be much appreciated.
  2. Aug 15, 2010 at 9:05 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    After you get it back together, go down to your local autozone or checker and borrow a torque wrench to tighten it up to spec.
    On 2001-2004, the Diff front mounting cushion to frame gets torqued down to 101 ft lbs. Not sure on your year and kinda too lazy to look it up, but I would guess its pretty much similar. Personally, 101 ft lbs is a bit on the heavy side to just be guessing it and you'll probably be hard pressed to get that much from a standard length socket wrench.
  3. Aug 16, 2010 at 3:54 PM
    tacomakid96
    Phil
    Out n' about
    Alright thanks alot:D
  4. Aug 16, 2010 at 4:05 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    i used a air impact on mine.. and locktite..
  5. Aug 16, 2010 at 4:07 PM
    tacomakid96
    Phil
    Out n' about
    Ya Im going to use locktite, I wish I had a air impact haha that would make it alot quicker.
  6. Aug 16, 2010 at 7:10 PM
    tacomakid96
    Phil
    Out n' about
    Where can i find the correct torque specs for the diff bolts?
  7. Aug 17, 2010 at 12:04 AM
    Manlaan
    Greg
    Riverton, Utah
    See Signature
    It should be in one of the FSM for your truck. (btw, impact wrenches are fantastic for removing bolts, but very poor for putting them back on due to high torque and hammering effect. It's very easy to over tighten a bolt with the impact wrench, so just dont do it. Always use a torque wrench to put bolts back on.)
