Diff drop or Not??
Discussion in 'Suspension' started by toyo freak, Oct 3, 2010.
CHOOSE ONE-DIFF DROP OR NO?
Poll closed Nov 2, 2010.
  1. Cheap and easy go for it
    15 vote(s)
    53.6%
  2. Only helps about 3%, avoid messing w/ diff
    13 vote(s)
    46.4%
  1. Oct 3, 2010 at 2:54 PM
    toyo freak
    toyo freak [OP] Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Yea thats the question. 5100s are in the near future for me at 2.5 and I have heard alot of debate about the diff drop. Is it better to have it and not worry about vibes, or is their a chance of problems when unbolting the diff and not re-aligning it correctly?
  2. Oct 3, 2010 at 2:57 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Wait and see if you develop vibes- I have not seen enuf folks have issues to say it needs to be used every time.
  3. Oct 3, 2010 at 5:06 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Purpose of diff drop isn't really to solve vibrations - you're more concerned with correcting the increased angle on the cv boots and cv joint within the front diff.
    This is a long term wear durability issue.
    That being said, I haven't decided if I want to go with a diff drop or not. Once it's on, you're changing the angle of the front driveshaft, and that's just one more change in the total system dynamic.
  4. Oct 4, 2010 at 2:04 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    This.
  5. Oct 4, 2010 at 11:24 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    I did the diff drop when I did my 5100s but I don't really know if it helped or not. I do have some slight vibrations (although I haven't had my alignment done yet because I have only installed my drivers side wheel spacers, haven't gotten the passenger side ones yet) so hopefully the very slight vibrations will be fixed when I get the alignment done, but if it doesn't I might try taking off the diff spacer to see if it changes anything. If anyone has any comments on that I am open for suggestion. Thanks.
  6. Oct 4, 2010 at 12:01 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    One thing that people fail to remember is that the differential drop on the 05+ Tacomas messes with your ground clearance. The stock mount is big, flat, wide, and distributes loads across that front cross member.
    A differential drop pushes that mount down using a cylinder between the mount and the cross member. You're now more prone to catching the mount on something, and if/when you do, you have less surface area supporting it on the top side.
    The end result on my truck is a mangled cross member and a cracked oil pan, even with the skidplate modified to work with the diff drop. I thought that thing was a stupid idea when I first installed it and am only more convinced of that now.
    When I get around to pulling the skids I'll take details pictures of just how mangled everything is. The differential drop punched right through to the top of the cross member.
  7. Oct 4, 2010 at 1:51 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
  8. Oct 4, 2010 at 3:45 PM
    6spdtaco
    6spdtaco Well-Known Member
    VT
    Taco
    I've heard it isn't as helpful with the 2nd gens compared to 1st gen. I have an OME 3" lift w/o diff drop. I would recommend new UCA's with the lift, that will help alignment more. The angles with a 2.5-3" aren't too bad.
  9. Oct 4, 2010 at 4:48 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Thanks guys. Bump for more opinions
  10. Oct 4, 2010 at 5:07 PM
    trd09
    trd09 Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    5100s at 2.5, no vibes worth mentioning, alignment within specs, and CVs are fine.
  11. Oct 4, 2010 at 5:12 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Anything else-diff drop, c/b drop aaxle shims?
  12. Oct 4, 2010 at 5:22 PM
    trd09
    Chuck
    NW Ark
    17 TRD Pro 6AT
    sorry for not mentioning, c/b drop, homemade with 1/2" washers
    before that i had a slight ~25 mph vibe under acceleration, now i just get it ever so slightly upon decel
  13. Oct 11, 2010 at 9:29 AM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    i just had the diff. drop installed to help fix my cv angle because my driver side cv axle was not level with the passenger side. so after i had it installed it cured the angles. so answer to your question does it help the vibes? no, it didn't cure the vibe. your best option is to get the carrier bearer drop from beef taco and have your wheels balance. but my truck is a 1st gen.
  14. Oct 11, 2010 at 9:59 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    A lot of people will so it's not worth it but i'll disagree with them all day.
    I put mine on it about 5 minutes or less and it makes a very noticable difference on the cv angles
  15. Oct 11, 2010 at 10:01 AM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    I've driven for the past 3 months & 9k mi on my OME lift with 881s w/o a diff drop. No vibes to speak of and my cv boots could be better but are at an acceptable angle for me. IMO diff drops don't do enough to be worth the effort.
    Carrier bearing drop would be a good idea though. I plan on that in the not too distant future.
  16. Oct 11, 2010 at 10:17 AM
    mjp2
    NJ
    I would much rather have to replace another set of CV boots, but because of the drop kit I instead have to cut out and replace the frame cross-member and my oil pan.
    It'll work fine on a street truck or something that just sees dirt roads. If you wheel, it's a terrible idea and causes FAR more problems than it solves.
    Side note -- those speaker rings are great! :thumbsup:
  17. Oct 11, 2010 at 10:38 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    I don't have one. Haven't had any problems. Would probably stay away from installing one too.
