diff drop poll
Discussion in 'Suspension' started by kessler89, Dec 13, 2010.
diff drop did...
Poll closed Jan 12, 2011.
  1. helped or cured your vibrations
    14 vote(s)
    42.4%
  2. did nothing or made it worse
    19 vote(s)
    57.6%
  1. Dec 13, 2010 at 9:37 AM
    kessler89
    kessler89 [OP] Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    i wanna know if you installed a diff drop kit and if it fixed your vibration issues or did nothing
  2. Dec 13, 2010 at 9:55 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    It put the mounts in harm's way and resulted in a shattered oil pan and bent cross member on my truck. Recommend against it.
    Oh, and...
    Overlay of the angle difference with and without the drop:
  3. Dec 13, 2010 at 2:00 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Another thread on diff drops ??? And not needed in my opinion !
  4. Dec 13, 2010 at 2:16 PM
    mjp2
    NJ
    "Search" function has apparently been broken for a few years now.
  5. Dec 13, 2010 at 5:53 PM
    kessler89
    OH
    12' Pro4x 6MT
    TBA
    Yeah search brings up it helped or it didn't help, this is so I can see how many people it really did/didn't help
  6. Dec 13, 2010 at 6:07 PM
    757southpaw
    757southpaw Well-Known Member
    Jay
    757
    07' DC LB TRD Sport 4x4
    BAK BakFlip Tonneau cover, 30% front tinted windows, AVS vent shades, Black Billet Grill,Pop& Lock, secondary air filter removed, Goodyear Duratrac's, Billies @ 2.5" on front, Billies on back w/ 1.5" AAL, Toytec Diff drop, NOKYA Hyper Yellow fog light bulbs, LaminX Weathertechs, Rear diff breather mod, BHLM
    I didn't have any vibrations but after I installed my toytec diff drop, it helped with the CV angles.
  7. Dec 13, 2010 at 6:09 PM
    Blktaco16
    Blktaco16 The juice was worth the squeeze!
    Heath
    Orange Park,Florida
    07 TRD Off-Road(4x4)
    Satoshi Grill w/ Hella 500's,Toytec coilovers, rear 5100's,diff drop, toytec AAL,sway bar relocated, rear axle shims,laminx fog light covers,UWS black low pro box,17x8 Procomp 7089,285/70/17 BFG KM2's,K&N short ram intake,diff breather mod,tailgate mod.
    Didn't notice anything before or after the toytec diff drop, so nothing changed :D:D:D
  8. Dec 13, 2010 at 6:18 PM
    Taco4Fish
    Taco4Fish Well-Known Member
    j
    i think its a waste spent $35 for something that doesnt do shit
  9. Dec 13, 2010 at 9:18 PM
    '02TRD
    '02TRD Well-Known Member
    Portland, OR
    2002 Tacoma Xtra Cab 4x4 SR5 TRD
    Billstein 5100's & AAL, 285/75R16 Toyo Open Country M/Ts on Black 16x8 Raceline Renegades, Pro-Tech Toolbox, Wet Okole covers, K&N air filter, Tow package, Alpine digital media receiver, Kenwood Amp, Rockford Fosgate 10" sub, Cobra 75 hand held CB, front differential drop
    ^ doesn't do shit??
    My diff drop kit from toytec was $20, and well worth it. Corrected CV angles in a great way. Inner CV boot fins were touching after installation of 2.5" lift. Touching fins = torn fins in a short time. The diff drop is worth saving the CV problems which may come without it. Didn't have any vibes before the lift, after the lift without the DD kit, or after installing the DD kit. If you're going 3"+ I would personally have the drivelines re-done or go another route as the DD is not going to help. Also, I have read quite a bit about the 2nd gen. DD kits not playing as much benefit as the front differential mounting brackets are different from the 1st gen.
  10. Dec 14, 2010 at 6:54 AM
    mjp2
    NJ
    Totally different animal. The Gen 1 trucks do benefit from them, but the OP has a newer model. They do nothing beneficial on the 05+ trucks.
  11. Dec 17, 2010 at 1:16 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    I took off the diff drop to fit Bud Skids. More smooth without.
  12. Dec 17, 2010 at 7:14 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    There is nothing in the OPs question or poll to indicate this is a 2nd gen only question. This poll is posted in a non-generation forum. If you want to exclude 1st gen feedback, that should be clearly stated up front.
    You are correct in your statement the 1st gens can benefit from a diff drop. That fact sometimes gets lost when the question about effectiveness of these kits is raised.
    To answer the OPs original question. Adding a 1" diff drop did eliminate post lift vibs on my truck. It also lowered the axle angles just enough so that two fins on the inner boot that were touching no longer touch.
  13. Dec 17, 2010 at 7:28 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    so here is the end of all diff drop threads....
    1st gens: useful, if you have vibes try it out.
    2nd gens: save your money, not worth shit.
    my work here is done.
  14. Dec 18, 2010 at 10:08 PM
    KColoTaco
    KColoTaco Well-Known Member
    Kevin
    N. Colorado
    08 TRD O/R DC
    3 inch OME complete lift, Light racing UCA's, Bed comp. locks.
    I think the validity of the benefits of a diff drop are completely tied to your vehicle use.
    If one is building a rig to run gnarly trails with more than 60% of the time then the diff drop is counter productive. It could also cause some serious carnage if you don't protect the mounts.
    For the rest of the folks that do the majority of there driving on the road the diff drop makes sense. *If your u-joints in the front drive shaft can take without vibration* Small price to pay to save the cv's/diff bearings.
    Just an opinion though, I like the poll.
  15. Jan 8, 2011 at 11:53 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    I put in the diff drop with my lift and I never felt any vibrations. IDK if I would've had vibes without.
  16. Jan 10, 2011 at 11:02 PM
    kessler89
    OH
    12' Pro4x 6MT
    TBA
    well i think i'm gonna give the diff drop a shot, if it sucks i'll just take it off and chalk it up as a loss since i have some vibes now, cant hurt and it's prett cheap
  17. Jan 11, 2011 at 2:03 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    I am quite sure I don't follow the math but, raise the truck is the same as lowering the wheels making the cv angels for extreme. lowering the diff. lessons the cv angels. Am I wrong? I have a drop kit and no problems at all. If you crush the oil pan and wreck the cross member, I am thinking it was not a result of dropping the diff. but maybe pushing it a little to hard.
  18. Jan 11, 2011 at 2:16 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The Diff Drop is not really for fixing vibration issues. It is to take a little of the angle off of the CVs. Too much angle on the CVs can cause the fins on the boots to rub together, which can cause the boots to wear quicker. If the boot fails, it allows dirt and debris to get into the joint and cause CV joint failure.
  19. Jan 11, 2011 at 2:28 PM
    mjp2
    NJ
    Re-check the way the differential is mounted on your truck.
    Dropping the mounts in the front only pivots the differential and does not actually drop the thing. Note that in the process you're shifting differential fluid away from the pinion bearings in the rear so make sure you keep the thing topped off.
    1" spacers lower the point where the axles insert by around 3/16" and changes the CV angles by 1.34 degrees.
    Toyota understood the need to protect the front diff mounts, which is why you have that hunk of metal sticking down in the middle of the cross member. It's there to protect important stuff. Adding the spacers drops the mounts below the piece that's designed to protect them and puts them in harm's way.
    I push my truck far harder than most, but if the results of my testing help someone else keep their truck in 1 piece, it's worth it.
