Diff Drop Question/Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DangerPudge, Jul 9, 2021.
  1. Jul 9, 2021 at 12:00 PM
    DangerPudge
    DangerPudge [OP] Well-Known Member
    Lift, wheels/tires, Snugtop
    I need some quick help. I started installing my Ironman 4x4 skid plate set and found very quickly that there was fouling on the diff supports at the front crossmember.
    I called Ironman and they said that diff-drops are a common installation issue. I measured the pucks for the diff-drop and they come in somewhere around 1.5".
    The folks said that given my lift, which I assume is 2" or less (the rear blocks are 1.5"; I bought the truck from a Toyota dealer with the lift already installed) said that removing the diff-drop pucks wouldn't be an issue with my lift height.
    Before I do that, I wanted to check to see what y'all thought.
  2. Jul 9, 2021 at 1:19 PM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    the general opinion is that diff drops are pointless under around 3 inches of lift.
    You may get front diff needle bearing noise after removing the diff drop, as its a common issue for guys who lift their tacomas. Makes a sort of rotational howling noise that goes away when you put the truck in 4wd. easy fix tho.
  3. Jul 9, 2021 at 4:17 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Yep, pull the diff drop, you'll be fine.
  4. Jul 9, 2021 at 6:32 PM
    DangerPudge
    Thanks y'all. I pulled it out and everything seems quite fine. The skid plate Install went mostly good and it feels like a really solid product.
  5. Jul 10, 2021 at 7:02 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Great.
  6. Jul 10, 2021 at 7:06 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I also ditched the diff drop when I realized my skid wouldn't fit snug
