Diff Drop Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ejewels, Jan 16, 2019.
  1. Jan 17, 2019 at 1:41 PM
    eon_blue
    Azusa, CA
    boot failure happens because of fins rubbing, yes. CVs are always spinning so if the fins are rubbing, they will start to tear in short order.
    CV axle failure happens either because you're wheeling hard, have a front locker engaged and using it too liberally, or your lift is too high and the CV angles are so steep that it compromises the integrity of the axle. Or a combination of any of those 2 or all 3. I had one CV axle actually fail on me, you'll know when/if that happens believe me lol
  2. Jan 17, 2019 at 2:03 PM
    ejewels
    ejewels [OP] Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    What are we talking short order? I'd imagine if it was that short... tons of people on here would be posting about failures constantly. I'm hoping I have some time? I read another post where someone got 70k on them, and another 15k.
  3. Jan 17, 2019 at 2:04 PM
    eon_blue
    Azusa, CA
    Depends on how badly it rubs and how much you drive I guess. When mine were rubbing after I first installed my Kings, I had my first blown boot within 2 months. Second one happens a few months after that, even after I lowered the lift (damage was already done I guess).
  4. Jan 17, 2019 at 2:08 PM
    ejewels
    CT
    Oh man. How many inches were you lifted? Did you replace them quickly after they tore? Sounds like I need to slide the boot clamp out sooner rather than later. I'm assuming thats an easy job I can just slide under the truck and do?
    And I never hear about this on here (or at least not something that seems to come up a lot). I wonder how many people are driving around with torn boots with a smallish lift.
  5. Jan 17, 2019 at 7:11 PM
    SweatyBiscuit
    SweatyBiscuit Well-Known Member
    Paul
    Northern AZ
    2016 Taco TRD OR
    Katzkin leather, heated seats, Popnloc, bed lights, remote start, bhlm....
    My truck was at the dealership for service and they recommended a front differential drop. I’ve got 2.5” Kings all around with about 2-2.5” of lift. They wanted just over $100 to install it so I told them I would look into it. They made a note on the service record.
    They lift a lot of Tacoma’s and said they do a diff drop and ecgs bushing on all of them. I already have the ecgs.
    Now I’m torn. Do I install a drop or do I go against their advice and run the risk that it will come back to haunt me in the future?
  6. Jan 17, 2019 at 7:14 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Haha you’re way overthinking it. Toss that bitch in and don’t look back.
  7. Jan 17, 2019 at 9:02 PM
    ejewels
    CT
    Wait so you recommend the drop? I thought most don’t do it. And sounds like it doesn’t really help the boots from rubbing
  8. Jan 17, 2019 at 9:17 PM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    I threw the drop in with my 2.5” ome lift. It definitely made the cv angles look healthier, but the boots will definitely last longer. Yes, boots are cheap, but pulling the axles and replacing the boots will eat up half a day if you know what you’re doing. If it’s your first time, it will obviously take significantly longer.
    Look at your boots. Do the ribs touch each other? If so, they will wear through each other much sooner than they would have if they weren’t. This is the sole factor that made me decide to just throw on the drop. And then I still did the boot slide mod because the boot ribs still ever so slightly touched.
    Search for the boot slide mod if you don’t know what that is. I definitely recommend it, if needed.
  9. Jan 17, 2019 at 9:22 PM
    ejewels
    CT
    Yeah one fin touches on each side. Started getting slight wear ring but I can clean it off with my finger so doesn’t seem deep, just shiny. Hoping I can get decent miles without them wearing through but I may just do the boot slide mod sooner than later. Seems super quick and easy. It’s tough because you hear so many opinions. Some people live with it and go 70k miles and some say 2 months. I’m thinking maybe hard wheeling may do that. Lately I’ve been mall crawling and commuting.
  10. Jan 17, 2019 at 9:29 PM
    Rujack
    The boot will definitely keep wearing itself out till it tears through. If yours are barely touching, I’d say do the drop and see if it fixes it. You don’t want them touching at all. Highway driving is probably worse with the boots like this as you’re generating more heat where the boots rub.
    The boot slide mod was actually a little more difficult than I expected. The two outer boots are stiff and not very pliable, so difficult to “slide”, then they want to spring back to their original position, which is frustrating when you’re trying to crimp or tighten a clamp and the thing keeps moving. It actually took quite a bit of force to slide them.
    The inners are softer, but more difficult to get your hands on to slide...
  11. Jan 17, 2019 at 9:38 PM
    RZRob
    RZRob Well-Known Member
    Robert
    Anaheim Hills
    I put the drop on mine as I'm lifted good and wanted to know I'd done the best I could to minimize wear on anything. I will say though that the diff drop caused me to have to modify my TRD skid plate mount (spacers and longer bolts).
    RZ Rob
    0DVR9bK-TS4TuFs8O7rkSRmN5823rejF3GhPH7TY_a9a8d88ebc36dbbf72a5862449c13a925486db89.jpg
    YHXtHA7JI6MRroqMun-xhE9IEUDrfCYDP_Y6Ttps_a0a785ccb9e71b5da571b8b9798e5bf96700fe95.jpg
  12. Jan 17, 2019 at 9:41 PM
    Rujack
    Shameless flash of your truck :thumbsup:
    RZRob[QUOTED] likes this.
  13. Jan 18, 2019 at 3:40 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I’m saying either way it doesn’t matter. If it makes you feel more comfortable with it in there, go ahead and put it in.
    ejewels[QUOTED][OP] likes this.
  14. Jan 18, 2019 at 4:16 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    I know a lot of people on here say diff drop doesn't do a thing/useless. But after I installed lift on mine, boots/fins were touching/rubbing. Installed diff drop, no more boot fin rubbing/touching.
    ejewels[OP] likes this.
  15. Jan 18, 2019 at 5:17 AM
    #35
    ejewels
    CT
    How much lifted were you?
  16. Jan 18, 2019 at 5:17 AM
    #36
    ejewels
    CT
    So what are the negatives to the diff drop?
  17. Jan 18, 2019 at 5:20 AM
    #37
    ejewels
    CT
    Thanks. I was just planning on the inners as my outters don’t seem to be touching. How high are you lifted?
  18. Jan 18, 2019 at 5:20 AM
    #38
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    None
    na8rboy and ejewels[QUOTED][OP] like this.
  19. Jan 18, 2019 at 5:22 AM
    #39
    na8rboy
    WI
    2" TRD pro suspension with 1/4" top plate.
  20. Jan 18, 2019 at 5:25 AM
    #40
    ejewels
    CT
    Which diff drop did you install? Maybe I’ll pick one up.
