Diff Drop Verdict?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Clay_916, Nov 13, 2015.
  1. Nov 13, 2015 at 9:29 AM
    Clay_916
    Clay_916 [OP] Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    What's the deal with these things? Do they work or not? Seeing way too many conflicting reviews.
  2. Nov 13, 2015 at 9:35 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Technically they lower the cv at the diff so sure it helps but its only being lower under half inch or so because the 1" diff drop only lowers front mount.
  3. Nov 14, 2015 at 5:34 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Its a minimal drop, but it does drop the diff helping with your angles. Plus its cheap and suoer easy to install.
  4. Nov 14, 2015 at 5:36 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Mine seemed to help a little but not all.
  5. Nov 14, 2015 at 5:50 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    If you have high speed vibrations (mine were limited to 50-60 mph) in the front as soon as you install your lift, it is quite likely those vibs are from your CV axles, particularly the boot fins are touching.
    I used a diff drop to lower the front of the diff just a tad. Enough that the vibs went away and the boot fins stopped touching. A diff drop is not a miracle cure for lifting too much tho.
    The fact remains, if you lift the front more that 2.5"s, you've gone beyond the sweet spot. Stay below that and your CV boots will last and you'll put less stress on all the IFS suspension components.
  6. Nov 14, 2015 at 6:30 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Think your vib was from bearing in diff not the cvs.
  7. Nov 14, 2015 at 6:33 PM
    Digiratus
    Roaming the PNW
    The RedHead
    No, definitely not. Diff drop installed, vibs went away. FWIW, I've put almost 70K on the truck since.
    No diff bushing issues.
  8. Nov 15, 2015 at 11:14 AM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    I'm not familiar with the rear diff mounts. Why isn't it possible to have some kind of drop kit that works on all of the mounts and not just the front?
