Diff Drop?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jblair, Apr 27, 2011.
  1. Apr 27, 2011 at 8:30 PM
    jblair
    jblair [OP] Well-Known Member
    Colorado
    99 taco 2.7L I4
    lift, big boy tires, deck plate, no more sway bar, painted stuff
    Why is it good? says the idiot. Why is it bad? says the slightly smarter idiot
  2. Apr 27, 2011 at 8:32 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Helps the CV angle when you do a suspension lift.
  3. Apr 27, 2011 at 9:07 PM
    jblair
    Colorado
    99 taco 2.7L I4
    would you need to do any with a 2" spacer lift?
  4. Apr 27, 2011 at 9:10 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    i would advise it, it's cheap insurance, i think toytech has them for about 30 bucks and you might find one cheaper.... it helps out the cv angles which you should keep parallel to the ground, or as much as possible. Of course if you're mall crawlin fug it!
    P.S. use the search button, their is alot of threads asking the same question
  5. Apr 27, 2011 at 9:16 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Do you have any vibrations after lifting? If your a 4x4, a 1" diff drop lowers the front of the diff enough to reduce or eliminate vibs caused by excesive cv axle angles. How do your axles look? Got a pic that shows the front axles? Any wear marks on your CV boots, particularly the inner boots?
  6. Apr 27, 2011 at 10:29 PM
    jblair
    Colorado
    99 taco 2.7L I4
    Sorry I did one really quick and didn't find anything helpful
    oh and it's there* :p
    But I'll look at the boots a bit, vibrations are nonexistent after a few years. I'll get a pic soon just for you haha
  7. Apr 28, 2011 at 2:26 AM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    after i lift my rig, i saw the angle on the cv axles are different on each side. I installed the diff drop and it changes the angles on the cv. but later on, i got
    a torn cv inner ball joint. i think either way even if you have the diff drop on,
    the cv axles will go bad no matter.
  8. Aug 24, 2011 at 9:33 AM
    The Happy Idiot
    The Happy Idiot Active Member
    Upstate NY
    01 V6 4x4 SR5
    Toyota was nice enough to give me a new frame. JBA cat-back, aFe dry drop-in w/ deckplate, Bilstein 5100's all around, Timbrens, Alcan 5-leaf packs, OME 881's, linear clutch pedal return spring (best $3.49 I ever spent)
    Just got 2"+ from some OME 881's w/ 5100's at 0 I put on in the spring. I opted for no diff drop at the time. I had a significant bro lean after the lift so I put in a .25" spacer. That CV boot and joint on the driver side just blew out. I'm thinking the extra .5" from the spacer pushed the CV angle beyond their limit? But, since they cancelled out a lean both CV angles should be the same, yes? I ordered a diff drop from wheelers.com. Oddly enough, my lift seemed to alleviate the vibrations I was having before doing it. We'll see what happens with the diff drop...
  9. Aug 24, 2011 at 3:36 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    pretty much..yea..
    diff drop kits help..but only for so long..
