diff drop ?
Discussion in 'Suspension' started by superbikedad, Dec 3, 2009.
  1. Dec 3, 2009 at 6:45 PM
    superbikedad
    superbikedad [OP] Active Member
    Jeff
    Lake Stevens, Washington
    07 sr5 trd dbl cb 4x4
    Bilstein 5100's, 1.75 lift front, 1' block rear,265/70/16
    Can I install a differential drop kit on 07 4x4 trd with bilstein 5100's set at 1.75 and will I hurt anything? I know most say you dont need it at that height but I do have some vibration and it goes away in 4wheel drive. I have not had alignment yet. that will be done Saturday. But if I still have vibration after the alignment I was thinking about doing the diff drop kit. Thanks for any and all advice.
  2. Dec 3, 2009 at 6:46 PM
    blendedfamily
    blendedfamily Well-Known Member
    'Burque(sucks)
    bump for this, i'm a total noob and am planning on lifting my truck this month...
  3. Dec 3, 2009 at 7:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You can give it a try. If it doesnt change anything, I would pull it off, and look for another source of the vibes.
  4. Dec 4, 2009 at 5:08 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    i got some vibes still.around 38 mph is the worst and its not that noticable anymore to me.it does go away in 4x4 like yours.i got the diff drop in/tried without,no differance.ive tried shimming cb,no luck.got about 10,000 miles on it and no problems.if i didnt like my set up so much i would of took it off cause i dont like shit that doesnt go right.it seems some get it and some dont.good luck.
  5. Dec 4, 2009 at 3:22 PM
    superbikedad
    Jeff
    Thanks for the response guys. I guess I will see what happens after the alignment. :)
  6. Jan 22, 2010 at 6:23 AM
    pascotaco
    pascotaco Member
    2009 Tacoma Access Cab 4X4 2.7
    Rear Springs TSB, Bilstein 5100's set at 1.75, 265/75r16 Hankooks, HELO HE791 MAXX6 16X8 Rims
    Vibration go away after the alignment?
  7. Jan 22, 2010 at 11:52 AM
    superbikedad
    Jeff
    Hey Pascotaco
    Truck drives worse after my alignment. Drove pretty good before the align and after the lift. Maybe I need to go have it looked at and re-aligned somewhere else. I did buy a diff drop kit. Havent installed it yet because Im not convinced some of my problems are not from the alignment. Just been real busy. I will post after new alignment and maybe with the diff drop installed. Probably going to be a few weeks before I can get everything done. But I kinda have gotten used to the way it drives. I guess its not that bad but its not right either. I will post as I play around with it a little more. Take care
