Diff drop
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jrive01a, Nov 25, 2020.
  1. Nov 25, 2020 at 5:30 PM
    Jrive01a
    Jrive01a [OP] Well-Known Member
    2019 toyota tacoma
    I been running a 2” front leveling kit for a couple weeks and would like to know if I need a front diff drop to compensate for the cv shaft angles . I do see a slight difference in the cv axle angles but not sure if it’s ok to run like that or not . Have heard of vibration problems down the road and needle bearing failures.
  2. Nov 25, 2020 at 5:46 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    I do have one. Some are against them. I’m on a 2” Bilstein lift. My angles are fine no vibes. Been on lift for a while. I do have Ecg Bushing on hand if and when it happens.
    Good Luck OP
    Jrive01a[OP] likes this.
  3. Nov 25, 2020 at 5:49 PM
    Jrive01a
    2019 toyota tacoma
    What diff drop kit are you running. I think I will go ahead and put one on just to be on the safe side . Totter sells a 1” diff drop and have seen others but don’t specify the amount of drop. Unsure if 1” drop will be ok .
  4. Nov 25, 2020 at 5:50 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    I’ve done two different drops on lifted vehicles and noticed more vibration and rhythmic noise with them than I have without.
    I’ve run two lifted 4Runners, a Tacoma and a FJ and did the diff drop on one 4Runner and the Tacoma and not the others, ended up removing it on them and ran a 3” lift (OME) and haven’t seen a CV failure or boot failure yet.
    Evdunn, 71tattooguy and Jrive01a[OP] like this.
