Diff drops
Discussion in 'Suspension' started by TGurau, May 6, 2010.
  1. May 6, 2010 at 10:46 AM
    TGurau
    TGurau [OP] Well-Known Member
    Tibi
    Portland, OR
    '98 SR5 4x4
    3" OME Suspension lift. PEX motoring headlights.
    I have a '98 Taco and I want to get a lift. I'm stuck between the OME 3" lift w/ spacers, or the Toytec Ultimate lift. Any ideas? Also, I'm not sure if I need a front/rear diff drop. :confused:
  2. May 6, 2010 at 10:59 AM
    ToyoComp
    ToyoComp Addicted Mod'r
    Tampa, FL
    07 4x4 TRD Off Road DC
    Sway-A-Way Race Runner 2.5 coil over (3" lift) & 2.0 rear shocks on TSB springs, Total Chaos UCA, ToyTec differential drop, 8128 Pro Comp wheels, Toyo Open Country RT 285/70/17, DT Long Tube headers, TRD CAI & exhaust, Line-X coated Famous Fabrication front bumper, Demello Sliders and rear bumper, Wet Okole covers, Rigid LED spot, driving & fog, bed mat, debadged & EBC Stage 4 rotors and pads
    I'm not a fan of the spacer lifts so to me the Toytec lift, with its complete coilover replacement is a better system. As for the differential drop, seems like folks are split on whether this is needed or not but, it does make sense to decrease the angle of the half shafts once the lift is installed. I have the differential drop kit from Toytec and haven't had any issues. Good luck with your mods.
  3. May 6, 2010 at 11:04 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    The amount that they reduce the angel is around 2* or so, barely even noticeable. If you really want to save the CV's, swap out for some manual hubs.
  4. May 6, 2010 at 4:29 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    If you find that post lift your cv boots are rubbing or are just too close for comfort and easy and relatively inexpensive solution is the diff drop. One advantage to the coilover type lift is its adjustability. If your cv angles are too high you can adjust some lift out of it.
  5. May 7, 2010 at 9:02 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Numerous of people have 3" suspension lift w/o diff. drop kits and are running strong.
  6. May 8, 2010 at 1:51 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    if i were you i wouldnt go with a spacer lift. the toytec ultimate kit on the other hand is a good practical setup. it really depends on how much wheeling you do though but ill tell ya i know first hand that a spacer lift will give ya a shit ride when wheelin and on the road as well. ive got a front diff drop and havent had any troubles with my CVs but thats not to say you would have troubles without one.
