Diff Fill Plug
Discussion in 'Technical Chat' started by hoepuncher, Feb 22, 2010.
  1. Feb 22, 2010 at 12:24 PM
    hoepuncher
    hoepuncher [OP] Well-Known Member
    Hey Everyone,
    I can't seem to get out the fill plug to change my diff fluid...and i think i may have stripped the plug. Here are the pics....does anyone know if this plug is still ok to reuse and or remove? I hope i didnt strip it too much...
    Sorry for the blurry pics, it was taken from my iphone.
  2. Feb 22, 2010 at 12:29 PM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    how did you do that??? always use a boxed end wrench on bolys like that.. I would def replace it.. if a wrench wont grab it anymore use some vice grips just to get it off....
  3. Feb 22, 2010 at 12:30 PM
    SoutheastTaco
    steven
    columbia sc
    09 trd sport dc 4x4
  4. Feb 22, 2010 at 12:31 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2.
  5. Feb 22, 2010 at 12:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Looks like you werent using the correct size wrench...
  6. Feb 22, 2010 at 12:33 PM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    that bolt is the hardest bolt i've ever attempted to take off. holy crap batman.
  7. Feb 22, 2010 at 12:33 PM
    hoepuncher
    i dunno..i was using a 15/16 socket and tried my best but i ended up messing it up
  8. Feb 22, 2010 at 12:39 PM
    86ceeten
    86ceeten Well-Known Member
    Brian
    NW Florida
    08 TRD Off Road PreRunner
    Limo tint, 18x10 Diamo Karat, Toyo 285-60's, Rear TSB, 5100's all around, front at 2.5", Debadged, Sound System (evolving)
    It's a 24 millimeter. Mine was pretty tight, but was no problem to remove.
  9. Feb 22, 2010 at 12:41 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Mine was tight as shit. Ended up having to wack the ratchet a few times with a hammer to break it loose. After that, smooth sailing.
  10. Feb 22, 2010 at 12:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Only .007" diff between 15/16 and 24 mm. They are interchangable.
  11. Feb 22, 2010 at 12:50 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Go to the dealer and have them get it off and have them replace it with a new one. Most dealerships are more than happy to help with a stuck bolt and might not even charge to do it. Those bolts are a pain in the a** to get off the first time!
  12. Feb 22, 2010 at 12:52 PM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    When mine was stuck, I just used my big ass pipe wrench. I still re-use it just torque it to correct spec and you won't have this problem again.
  13. Feb 22, 2010 at 12:52 PM
    hoepuncher
    none of the dealers around my area have a new plug availabe...bummed. I hope pepboys/autozone have them.
  14. Feb 22, 2010 at 12:53 PM
    drew02a
    San Antonio, TX
    Not a chance.
    You should be fine re-using the plug at least temporarily while the dealer orders a new one.
  15. Feb 22, 2010 at 3:02 PM
    hoepuncher
    Ok I finally got it out and replaced the fluid. I think my dumbass tried to remove it with not having a good angle. I'll make sure to change the bolt when it arrives. Very frustrating day..
  16. Feb 22, 2010 at 3:03 PM
    drew02a
    San Antonio, TX
    That's why "they" say you should always remove the fill plug first.
  17. Feb 22, 2010 at 3:10 PM
    hoepuncher
    LOL that was the fill plug...drain plug was no problem
  18. Feb 22, 2010 at 3:24 PM
    kingston73
    kingston73 Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
  19. Feb 22, 2010 at 4:13 PM
    hoepuncher
    thanks for the link but the bolt came out fine my 2nd attempt...A new bolt is coming in once the dealer gets it.
    Thanks everyone for their input and advice!! :eek:
  20. Oct 26, 2010 at 3:34 PM
    05tacoSPORT
    05tacoSPORT Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    I have the same problem. :mad::mad::mad: 24mm socket and she spins WTF. I started with normal wrench then breaker bar, then on a impact and nothing. To top that off i hit the drain plug and (just to see if it was that damn tight) lost half of the oil:mad:(more pissed) So now what? I have a normal size set of vice grips and a 24in pipe wrench/ or do i spend more$ to fix my F up.
