Diff fluid leak after replacing cv axles
Discussion in '1st Gen. Tacomas (1995-2004)' started by kbauman92, May 27, 2013.
  1. May 27, 2013 at 9:50 PM
    kbauman92
    kbauman92 [OP] Well-Known Member
    Kyle
    North Bend
    98 tacoma ext cab
    King 2.5x6 RR coilovers eibach coils Light Racing UCA Spidertrax spacers Fiberwerx fenders
    i replaced both of my cv axles with the lifetime warranty ones from napa and after the install i noticed on the passenger side where the axle slides into the diff its leaking diff fluid, should i try to re-install that side? any advice would be appreciated
  2. May 28, 2013 at 4:28 AM
    04trd
    04trd Well-Known Member
    Cleveland Ohio
    2015 f150 lariat
    weather techs, 20precent tint, leveling kit, back flip bed cover, rhino liner
    check the seals, if the seal is bad its going to leak. make sure its not nicked and make sure the little metal spring is in tact
  3. May 28, 2013 at 10:43 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    read another thread concerning the same issue...
    OP replaced the cv's with aftermarket...
    and thought the cv's were not seating fully...
    as the seal on the passenger side began leaking.
    OP installed a new seal... no more leak.
  4. May 28, 2013 at 12:51 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    ya that was my thread, what happened was i bought auto zone axles and new seals from toyota. The driver side i pushed the seal all the way in to where it stopped witch is the correct way to install it. Now the passenger side all you have to do is make sure u slide it in flush with the front diff housing. it doesnt get pushed all the way in till it stops. So i pushed the seal in too far to the point the oil would just leak out of the diff. if OP has any questions just ask ive torn my axles out 10 times and got purdy good at putting them back together
  5. May 28, 2013 at 3:09 PM
    Itisreallycold
    Itisreallycold Active Member
    Minnesnowta
    Ol' Rusty
    This might be a dumb question. The Seals are inside of the differential and are what the cv axels fit into?
  6. May 28, 2013 at 5:09 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    The housing is where the axles slide into. The seals go into the housing witch make a seal for the oil so it doesn't leak out
  7. May 29, 2013 at 5:10 PM
    kbauman92
    Kyle
    North Bend
    98 tacoma ext cab
    thanks for the answers guys can i just pick up new seals from napa or do i need to order them, and is it pretty self explanatory to replace the seals, im gonna try to do it this week so i stop leaking fluid everywhere
