Diff Lock Stuck, Please Help
Discussion in 'Technical Chat' started by wildforager, Feb 6, 2010.
  1. Feb 6, 2010 at 8:42 AM
    wildforager
    wildforager [OP] Active Member
    I have a 2010 Taco, and was just stuck in the driveway so decided to use the rear diff lock. Now the lock will not turn off. Any suggestions?
  2. Feb 6, 2010 at 8:46 AM
    swise
    swise TRIFECTA!!!
    ohio
    08 4x4 dbl cab, TRD offroad
    This is simplest things first, but I have to take mine out of 4lo, then drive forward 10 or 20 feet before it will unlock. sometimes you have to turn too.
  3. Feb 6, 2010 at 8:55 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Just move a few feet forward and back, push the button again... It is just binding from a turn in the wheels... If the light is blinking, you are out... If the light is solid, you are still locked. Same in L4, but you need to be in Neutral (not park) to disengage from L4 to H4.... IF you are a 4WD Off Road Tacoma.
  4. Feb 7, 2010 at 7:47 AM
    wildforager
    I must be doing something wrong b/c it keeps sticking. If I am in L4, and turn on the diff lock, then drive I cannot get it out. I stop the vehicle, put it in neutral, hit the button to unlock it, and nothing happens.
    I was debating if I should take it back and have the dealer look at it. To me it seems like it is having issues. I'm not sure though.
  5. Feb 7, 2010 at 11:16 AM
    David K
    Of course take it back... all we can do is tell you what works for us.
  6. Feb 7, 2010 at 11:30 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    The first few times I used mine it was difficult to get it to lock in and unlock. Once it took five minutes or so of rocking and turning while moving forward and backwards to get it to unlock. Now it pops in and out like a champ.:)
  7. Feb 7, 2010 at 12:34 PM
    blendedfamily
    blendedfamily Well-Known Member
    'Burque(sucks)
    I had the this problem when I first had my taco. Make sure you figure out whether the switch is turned on or off. I just go 4lo to n, then to 4hi, then hit the switch, back into d, drive forward and backward, and cut the wheel a bit from one side to the other. Should work.
  8. Feb 9, 2010 at 8:50 PM
    wildforager
    Oddly enough, moving the steering wheel from side to side seems to solve the issue for the most part.
    Thanks.
  9. Feb 9, 2010 at 9:18 PM
    David K
    Great to hear!
