diff lock
Discussion in '1st Gen. Tacomas (1995-2004)' started by scyota03, Sep 1, 2011.
  1. Sep 1, 2011 at 7:03 PM
    scyota03
    scyota03 [OP] Well-Known Member
    sumter,southcarolina
    03 trd prerunner
    3 inch coil spiring spacer, front bull bar
    does anybody kno how to lock the diff lock on an 03 pre runner. i tried usin mine today and all it did was blink. and the owners manual only tells u how to lock it with a maual tranny. i gotta automatic
  2. Sep 1, 2011 at 7:06 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    Go to a full stop hit button and itll flash slowly go forward intill you hear it click.
  3. Sep 1, 2011 at 7:10 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    You have an 03-
    Were you in 4lo? It only works in 4lo, otherwise it just blinks without engaging
  4. Sep 1, 2011 at 7:11 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    o
    neeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeevermind
  5. Sep 1, 2011 at 7:12 PM
    BlueTaco07
    Cody
    Looking
    PRERUNNERS FTW!!!!!
  6. Sep 1, 2011 at 7:12 PM
    scyota03
    03 trd prerunner
    no konaborne i only got a pre runner. a 4x4 wasnt available when i was lookin for one. it kinda sucks but a locker is better than no locker
  7. Sep 1, 2011 at 7:15 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Yeah well maybe when the diff locks....:p
    Just keep playing with it & do it on dirt not pavement....:cool:
  8. Sep 1, 2011 at 7:16 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    sorry about that. Added another post under whipper.
    I'ma just walk away. To me, prerunners are like lasers. I dun kno how teh works.
    I wish I could go to TW meets :pout:
  9. Sep 1, 2011 at 7:19 PM
    BlueTaco07
    Cody
    Looking
    My locker works just fine, and it whoops ass :)
  10. Sep 1, 2011 at 7:19 PM
    BlueTaco07
    Cody
    Looking
  11. Sep 1, 2011 at 7:27 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
  12. Sep 1, 2011 at 7:30 PM
    PreRunner03
    PreRunner03 Hail State
    03 PreRunner Double Cab TRD
    I have experience with that model :anonymous: I just push the button at a complete stop. Wait a little bit. Move forward slowly. Listen for the click. Then I go play around.
  13. Sep 1, 2011 at 7:34 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    Prerunners........
  14. Sep 1, 2011 at 7:38 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
  15. Sep 1, 2011 at 11:42 PM
    Anthony250
    Anthony250 Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    How long can you run the locker?
  16. Sep 2, 2011 at 10:10 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Nothing 'limits' the use of the locker on the 4WD Off Road TRDs as far as speed goes, except it only can be engaged in low range... and who drives fast in low range (30 mph tops)?
    The truck only needs a locker if and when normal 2WD (Prerunners) or normal 4WD doesn't work to get you trough or up something. Actually the 2009+ Off Road 4WDs could do fine without the rear locker because of A-TRAC which gives more traction assist, as it works on the front axle, too.
    Soley because of loss of steering control when locked is why the 5 mph recommended limit, a safety concern... Heck, if you can go faster than 5 mph you don't need the locker on.
    Both tires get torque with an open differential... The locker saves you when one tire is on a loose surface or in the air... and the other one is still on firm ground. Helps when climbing steep grades with rocks or uneven surface.
    Without a locker or traction control, the loose tire will spin and the firm tire just sits there helpless.
  17. Sep 2, 2011 at 12:19 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    The only regret I have with the grey wire MOD is that I didn't do it sooner... probably the easiest,cheapest most effective MOD going...;)
  18. Sep 2, 2011 at 1:31 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    the only danger is do a ton of turning. as it puts stress on the axle because when you turn one wheel is making a smaller turn then the other. But when its locked and you do that it just stresses the axle. If i had one id only use it when i was about to attempt something i think id need it on..
  19. Sep 2, 2011 at 2:41 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    For most of my trailing I don't use locker except for the slow trickier stuff but I do the desert in winter & I'll tell ya its pretty sweet to drop into 4H when I'm 2wd -locked in sand & start to sink in a little, but not for a great distance or real high speed, but I don't lose all the momentum I would if I had to slow to a stop/engage 4L & have to regain momentum
  20. Sep 2, 2011 at 7:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :smack:
    pshhh yea okay...you had your locker on for half the freakin meet lol
